Home » Language IDEs » Java Development Tools (JDT) » No projects found to import(Problem with importing java project)
No projects found to import [message #674806] Sat, 28 May 2011 12:04 Go to next message
Hi, I'm new on this forum. I have a problem with importing java project because when I try to select File > Import > General > Existing project into Workspace, it returns "No projects found to import". The project is already locates in workspace. It contains folders with only java files.
I'm using Eclipse IDE for Java Developers
Version: Helios Service Release 2
Build id: 20110218-0911
Can someone help me?
Thanks in advance.
Re: No projects found to import [message #675057 is a reply to message #674806] Mon, 30 May 2011 04:02 Go to previous messageGo to next message
Eclipse looks for a file called .project to identify if it is an eclipse project. It also doesn't show up if the project name is already in the workspace
Re: No projects found to import [message #675110 is a reply to message #675057] Mon, 30 May 2011 06:38 Go to previous messageGo to next message
Thanks. So, is it possible to load a folder that contains only java files without .project? I need to use refactoring function on these files.
Re: No projects found to import [message #675128 is a reply to message #675110] Mon, 30 May 2011 07:27 Go to previous message
Create a project and then import the file system or create a new linked folder (On the new folder dialog box, click on advanced to see options to create links).
Previous Topic:JVM terminated. Exit code=13
Next Topic:C++ DLL not working on Eclipse JDT.
Current Time: Fri Jul 25 21:21:25 EDT 2025
Powered by FUDForum. Page generated in 0.05125 seconds
