Home » Eclipse Projects » Rich Client Platform (RCP) » Only one instance of my RCP product
Only one instance of my RCP product [message #674627] Fri, 27 May 2011 11:43 Go to next message
I've developed an RCP product that actually is in beta test phase; now I have to limit the running copies of the product to only one per time:
  • how can I do this?
  • where I have to put the related code in my RCP product?
Thank you very much, any help is appreciated
Giovanni
Re: Only one instance of my RCP product [message #675049 is a reply to message #674627] Mon, 30 May 2011 03:00 Go to previous messageGo to next message
On 27/05/11 9:13 PM, Giovanni De Sossi wrote:
There isn't a Java/Eclipse API to do this. You need to do workarounds
like holding a lock on a file or binding to a port etc.
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
Re: Only one instance of my RCP product [message #675192 is a reply to message #675049] Mon, 30 May 2011 10:38 Go to previous messageGo to next message
Hi Prakash,
thank you very much, I'll try your suggestion.
Giovanni
Re: Only one instance of my RCP product [message #676978 is a reply to message #675049] Tue, 07 June 2011 03:22 Go to previous messageGo to next message
try this workaround:
Platform.getInstanceLocation().lock();
Re: Only one instance of my RCP product [message #676984 is a reply to message #676978] Tue, 07 June 2011 03:46 Go to previous messageGo to next message
Thank you Joerg, unfortunately it seems not to work......
Re: Only one instance of my RCP product [message #676998 is a reply to message #676984] Tue, 07 June 2011 04:58 Go to previous message
Originally posted by:
Presumably you are not using the lock API correctly. You should ensure
that you do it similarly to how class
org.eclipse.ui.internal.ide.application.IDEApplication does this within
its method checkInstanceLocation.
HTH & Greetings from Bremen,
Daniel Krügler
Previous Topic:Form Heading to Center
Next Topic:Editors tab order + menu text
Current Time: Sat Jul 26 23:35:12 EDT 2025
Powered by FUDForum. Page generated in 0.07116 seconds
