Home » Modeling » GMF (Graphical Modeling Framework) » [SOLVED] ArrangeAll with a Left to right layout
[SOLVED] ArrangeAll with a Left to right layout [message #674614] Fri, 27 May 2011 10:52 Go to next message
The default Arrange-All behaviour is to lay the diagram from top to bottom.
How do I get it to lay the diagram/nodes from left to right?
Thank you.
[Updated on: Wed, 01 June 2011 09:05] by Moderator
Re: ArrangeAll with a Left to right layout [message #675558 is a reply to message #674614] Tue, 31 May 2011 16:32 Go to previous messageGo to next message
Originally posted by: Roy Benjamin
On 5/27/2011 7:52 AM, boualem wrote:
> The default Arrange-All behaviour is to lay the diagram to from to bottom.
> Thank you.
<extension id="leftToRightProvider"
name="LeftToRightProvider"
point="org.eclipse.gmf.runtime.diagram.ui.layoutProviders">
<layoutProvider
class="com.zardoz.trading.diagram.layout.LeftToRightLayoutProvider">
<Priority name="High" />
</layoutProvider>
</extension>
You'll need to provide a subclass of: LeftRightProvider
Re: ArrangeAll with a Left to right layout [message #675768 is a reply to message #675558] Wed, 01 June 2011 09:05 Go to previous message
Solution/suggestion works.
Thank you.
Smile
Previous Topic:Generating Eclipse view instead of editor
Next Topic:reference based links: using both the link diagram and the property sheet
Current Time: Wed Jul 23 18:37:17 EDT 2025
Powered by FUDForum. Page generated in 0.03864 seconds
