Home » Eclipse Projects » Plugin Development Environment (PDE) » Class.forName in plugin developement
Class.forName in plugin developement [message #674012] Wed, 25 May 2011 10:14 Go to next message
i am developing plug-in eclipse wich contains an wizard.This wizard lets the user to enter a class name with package name in current project and in treatment i need to do Class.forName("Class entred") but it dont work.Class Not found.
I think that the use of Class.forName in Plugin developement is not allowed.so how to do that?
Thinks for your help
Re: Class.forName in plugin developement [message #674587 is a reply to message #674012] Fri, 27 May 2011 08:53 Go to previous message
I am using Class.forName() in my Plug-In Project and it works just fine, so either your class is actually not available, or there is a miss spell or something similiar.
It sounds like you'd want to check for classes in the Workscpaces (??) since there is a wizard that let's someone do that. You could look into the code of JDT and see how they do it with their creation-wizards. I think the Java model already contains all the classes that are available and you can easily query that model to check if you class exists.
Kind regards,
-- artur
Previous Topic:Templates and Template Preferences
Next Topic:Get Class Location
Current Time: Mon Jul 21 03:40:27 EDT 2025
Powered by FUDForum. Page generated in 0.99682 seconds
