birt-viewer frameset SLOW [message #674432] |
Thu, 26 May 2011 17:53  |
Hi!
I'm facing a very strange issue while running the birt-viewer application in Tomcat 6/7 on Ubuntu 10.04 (AMD 64bit).
Rendering the very basic sample report (test.rptdesign) takes around 2 minutes, when I use the "frameset" URL:
/frameset?__report=test.rptdesign
It's very fast (< 1sec) rendering the same report with the "run" URL:
It seems, the problem is related to some component(s) in the frameset UI, but I don't see why. I tried Tomcat 6, Tomcat 7, several versions of the birt runtime,
different Java version (SUN, OpenJDK), but without any luck. It's always the same behaviour: the UI gets loaded up to a certain point, then it seems to hang. No
data is being transfered for up to 100 seconds and then suddenly the report appears. During this time, I can see no trace of activity (using top) on the Linux server.
I'm using birt since years and installed the birt-viewer in many different environments but never faced a similar issue. It's
driving me crazy!
Maybe someone here has some suggestion. Any ideas are welcome!
Oli
Re: birt-viewer frameset SLOW [message #674437 is a reply to message #674432] |
Thu, 26 May 2011 18:12   |
Oli
After you run it initially, if you run it again does it take a long
time? Can you check the web-inf/platform/configuration directory? After
running do you have files in this directory other than the config.ini?
Jason
On 5/26/2011 5:53 PM, forums-noreply@eclipse.org wrote:
> Hi!
> the birt runtime, different Java version (SUN, OpenJDK), but without any
> point, then it seems to hang. No data is being transfered for up to 100
> driving me crazy!
> Oli
Re: birt-viewer frameset SLOW [message #675447 is a reply to message #675131] |
Tue, 31 May 2011 10:42  |
The viewer AJAX code used in the /frameset mapping uses web services to
connect back to the server, but it should not be connecting outside.
Jason
On 5/30/2011 7:36 AM, forums-noreply@eclipse.org wrote:
> After doing some testing, my best guess is, that this problem somehow
> relates to a network issue. Some component in the birt viewer might do a
> network operation (name resolution etc.), that blocks processing and
> finaly fails after a certain timeout. This could be due to some firewall
> restriction or even a missconfiguration on network level.
> Does that make sense? Is there any component in the birt viewer
> frameset, that connects to the outside network when opening a report?
> Oli
FUDForum. Page generated in 0.06625 seconds
