Home » Archived » BIRT » Bar chart x-axis labels changed to letters after upgrade
Bar chart x-axis labels changed to letters after upgrade [message #674396] Thu, 26 May 2011 14:38 Go to next message
I've recently upgraded from Eclipse 3.4 to 3.6.2. I'm using the BIRT chart engine standalone in some SWT code I have. I have several bar charts that prior to upgrading showed the numeric values of the data along the x-axis (with type AxisType.LINEAR_LITERAL). After upgrading, all these charts are showing a character (or set of characters) instead of a number. Example...1 would show as N, and higher numbers would show as something like NLMM, etc. The data being charted is simple integer values for both x/y values (think of a size/frequency distribution chart). Both data sets are NumberDataSet instances.
Has something in the API changed? What should I be looking at to fix this?
[Updated on: Thu, 26 May 2011 14:41] by Moderator
Re: Bar chart x-axis labels changed to letters after upgrade [message #674402 is a reply to message #674396] Thu, 26 May 2011 15:05 Go to previous messageGo to next message
Can you post the code?
Jason
Re: Bar chart x-axis labels changed to letters after upgrade [message #674405 is a reply to message #674402] Thu, 26 May 2011 15:40 Go to previous messageGo to next message
Here is the code to create one of the charts:
ChartWithAxes chart = ChartWithAxesImpl.create();
chart.setDimension(ChartDimension.TWO_DIMENSIONAL_LITERAL);
// CUSTOMIZE THE PLOT
Plot p = chart.getPlot();
p.getOutline().setVisible(false);
chart.getTitle().setVisible(false);
chart.getLegend().setVisible(false);
// CUSTOMIZE THE X-AXIS
xAxisPrimary = chart.getPrimaryBaseAxes()[0];
xAxisPrimary.setType(AxisType.LINEAR_LITERAL);
xAxisPrimary.getMajorGrid().setTickStyle(TickStyle.BELOW_LITERAL);
xAxisPrimary.getTitle().setVisible(true);
xAxisPrimary.getTitle().getCaption().setValue("Size");
xAxisPrimary.getTitle().getCaption().getFont().setSize(10);
xAxisPrimary.getLabel().getCaption().getFont().setSize(8);
xAxisPrimary.getLabel().getCaption().getFont().setRotation(-90);
// CUSTOMIZE THE Y-AXIS
yAxisPrimary = chart.getPrimaryOrthogonalAxis(xAxisPrimary);
yAxisPrimary.getMajorGrid().setTickStyle(TickStyle.LEFT_LITERAL);
yAxisPrimary.setType(AxisType.LOGARITHMIC_LITERAL);
yAxisPrimary.getScale().setMin(NumberDataElementImpl.create(1));
yAxisPrimary.getTitle().getCaption().setValue("Count");
yAxisPrimary.getTitle().getCaption().getFont().setSize(10);
yAxisPrimary.getLabel().getCaption().getFont().setRotation(0);
yAxisPrimary.getLabel().getCaption().getFont().setSize(8);
// CREATE THE CATEGORY BASE SERIES
seCategory = SeriesImpl.create();
// CREATE THE PRIMARY VALUE ORTHOGONAL SERIES
ss1 = (BarSeries) BarSeriesImpl.create();
ss1.getLabel().setVisible(false);
// WRAP THE BASE SERIES IN THE X-AXIS SERIES DEFINITION
SeriesDefinition sdX = SeriesDefinitionImpl.create();
xAxisPrimary.getSeriesDefinitions().add(sdX);
sdX.getSeries().add(seCategory);
// WRAP THE PRIMARY ORTHOGONAL SERIES IN THE X-AXIS SERIES DEFINITION
SeriesDefinition sdY = SeriesDefinitionImpl.create();
yAxisPrimary.getSeriesDefinitions().add(sdY);
sdY.getSeries().add(ss1);
And later on when I set the data into the chart (both sizeList and countList contain a list of Long values):
// INITIALIZE A COLLECTION WITH THE X-SERIES DATA (size)
NumberDataSet categoryValues = NumberDataSetImpl.create(sizeList);
// INITIALIZE A COLLECTION WITH THE PRIMARY Y-SERIES DATA (count)
NumberDataSet orthoValues1 = NumberDataSetImpl.create(countList);
seCategory.setDataSet(categoryValues);
ss1.setDataSet(orthoValues1);
Re: Bar chart x-axis labels changed to letters after upgrade [message #674415 is a reply to message #674405] Thu, 26 May 2011 16:36 Go to previous messageGo to next message
Any chance you could try with doubles instead of longs? I think the
NumberDataSet processing only supports the following:
if ( iDataType == IConstants.NUMERICAL )
if ( oContent instanceof Collection )
iContentType = IConstants.COLLECTION;
co = (Collection) oContent;
else if ( oContent instanceof double[] )
iContentType = IConstants.PRIMITIVE_ARRAY;
da = (double[]) oContent;
else if ( oContent instanceof Double[] )
iContentType = IConstants.NON_PRIMITIVE_ARRAY;
dda = (Double[]) oContent;
else if ( oContent instanceof BigNumber[])
iContentType = IConstants.BIG_NUMBER_PRIMITIVE_ARRAY;
cnda = (BigNumber[])oContent;
else if ( oContent instanceof Number[])
iContentType = IConstants.NUMBER_PRIMITIVE_ARRAY;
nda = (Number[])oContent;
Jason
> // CUSTOMIZE THE X-AXIS xAxisPrimary = chart.getPrimaryBaseAxes()[0];
> // CUSTOMIZE THE Y-AXIS yAxisPrimary =
> // CREATE THE CATEGORY BASE SERIES seCategory = SeriesImpl.create();
> yAxisPrimary.getSeriesDefinitions().add(sdY); sdY.getSeries().add(ss1);
Re: Bar chart x-axis labels changed to letters after upgrade [message #674418 is a reply to message #674415] Thu, 26 May 2011 16:53 Go to previous messageGo to next message
I tried, doesn't make a difference. I even tried turning all the x-values into their string equivalents and changed the x-axis type to TEXT_LITERAL and it's still showing the bizarre lettering for the scale values instead of the string values in the data.
Re: Bar chart x-axis labels changed to letters after upgrade [message #674436 is a reply to message #674418] Thu, 26 May 2011 18:02 Go to previous messageGo to next message
Take a look at this example. You should be able to switch the axis type
from LINEAR to TEXT or back and set the cat values to either:
or
seCategory.setDataSet(orthoValues2);
Jason
import java.awt.Graphics;
import java.awt.Graphics2D;
import java.awt.image.BufferedImage;
import java.io.BufferedWriter;
import java.io.FileWriter;
import org.eclipse.birt.chart.api.ChartEngine;
import org.eclipse.birt.chart.device.EmptyUpdateNotifier;
import org.eclipse.birt.chart.device.IDeviceRenderer;
import org.eclipse.birt.chart.device.IDisplayServer;
import org.eclipse.birt.chart.device.IImageMapEmitter;
import org.eclipse.birt.chart.factory.GeneratedChartState;
import org.eclipse.birt.chart.factory.IGenerator;
import org.eclipse.birt.chart.model.Chart;
import org.eclipse.birt.chart.model.ChartWithAxes;
import org.eclipse.birt.chart.model.attribute.ActionType;
import org.eclipse.birt.chart.model.attribute.AxisType;
import org.eclipse.birt.chart.model.attribute.Bounds;
import org.eclipse.birt.chart.model.attribute.IntersectionType;
import org.eclipse.birt.chart.model.attribute.LegendItemType;
import org.eclipse.birt.chart.model.attribute.Position;
import org.eclipse.birt.chart.model.attribute.TickStyle;
import org.eclipse.birt.chart.model.attribute.TriggerCondition;
import org.eclipse.birt.chart.model.attribute.impl.BoundsImpl;
import org.eclipse.birt.chart.model.attribute.impl.ColorDefinitionImpl;
import org.eclipse.birt.chart.model.attribute.impl.TooltipValueImpl;
import org.eclipse.birt.chart.model.attribute.impl.URLValueImpl;
import org.eclipse.birt.chart.model.component.Axis;
import org.eclipse.birt.chart.model.component.Series;
import org.eclipse.birt.chart.model.component.impl.SeriesImpl;
import org.eclipse.birt.chart.model.data.BaseSampleData;
import org.eclipse.birt.chart.model.data.DataFactory;
import org.eclipse.birt.chart.model.data.NullDataSet;
import org.eclipse.birt.chart.model.data.NumberDataSet;
import org.eclipse.birt.chart.model.data.OrthogonalSampleData;
import org.eclipse.birt.chart.model.data.SampleData;
import org.eclipse.birt.chart.model.data.SeriesDefinition;
import org.eclipse.birt.chart.model.data.TextDataSet;
import org.eclipse.birt.chart.model.data.Trigger;
import org.eclipse.birt.chart.model.data.impl.ActionImpl;
import org.eclipse.birt.chart.model.data.impl.NullDataSetImpl;
import org.eclipse.birt.chart.model.data.impl.NumberDataSetImpl;
import org.eclipse.birt.chart.model.data.impl.SeriesDefinitionImpl;
import org.eclipse.birt.chart.model.data.impl.TextDataSetImpl;
import org.eclipse.birt.chart.model.data.impl.TriggerImpl;
import org.eclipse.birt.chart.model.impl.ChartWithAxesImpl;
import org.eclipse.birt.chart.model.layout.Legend;
import org.eclipse.birt.chart.model.layout.Plot;
import org.eclipse.birt.chart.model.type.BarSeries;
import org.eclipse.birt.chart.model.type.impl.BarSeriesImpl;
import org.eclipse.birt.core.framework.PlatformConfig;
* Test decription:
* </p>
* Chart script: BeforeDrawLegendItem()
* </p>
public class StandaloneChart {
private static String OUTPUT = "output/Standalone.png"; //$NON-NLS-1$
private static String OUTPUT_HTML = "output/Standalone.html"; //$NON-NLS-1$
* Comment for <code>serialVersionUID</code>
private static final long serialVersionUID = 1L;
* A chart model instance
private Chart cm = null;
* The swing rendering device
private IDeviceRenderer dRenderer = null;
private IDisplayServer dServer = null;
private GeneratedChartState gcs = null;
* execute application
* @param args
new StandaloneChart();
System.out.println("Finished");
* Constructor
public StandaloneChart() {
PlatformConfig pf = new PlatformConfig();
pf.setProperty("STANDALONE", true);
//Returns a singleton instance of the Chart Engine
ChartEngine ce = ChartEngine.instance(pf);
//Returns a singleton instance of the Generator
IGenerator gr = ce.getGenerator();
try {
//device renderers for dv.SWT, dv.PNG, dv.JPG
//dv.PDF, dv.SVG, dv.SWING, dv.PNG24, div.BMP
dRenderer = ce.getRenderer("dv.PNG");
dServer = dRenderer.getDisplayServer();
} catch (Exception ex) {
ex.printStackTrace();
//cm = new AfterDatasetFilled().GetChartModel();
cm = StandaloneChart.createStackedBar();
//cm = StandaloneChart.createGrouponY();
//cm = StandaloneChart.createStockChart();
//cm = StandaloneChart.createTest();
BufferedImage img = new BufferedImage(600, 600,
BufferedImage.TYPE_INT_ARGB);
Graphics g = img.getGraphics();
Graphics2D g2d = (Graphics2D) g;
//Look at IDeviceRenderer.java for all properties
//like DPI_RESOLUTION
//FILE_IDENTIFIER
//FORMAT_IDENTIFIER
//UPDATE_NOTIFIER
dRenderer.setProperty(IDeviceRenderer.GRAPHICS_CONTEXT, g2d);
dRenderer.setProperty(IDeviceRenderer.FILE_IDENTIFIER, OUTPUT);
//$NON-NLS-1$
//Set the bounds for the entire chart
Bounds bo = BoundsImpl.create(0, 0, 600, 600);
bo.scale(72d / dRenderer.getDisplayServer().getDpiResolution());
try {
gcs = gr.build(dServer, cm, bo, null, null, null);
//gcs.getRunTimeContext().setActionRenderer( new MyActionRenderer());
//have to have this line if you want the image map generated
dRenderer.setProperty(IDeviceRenderer.UPDATE_NOTIFIER,
new EmptyUpdateNotifier(cm, gcs.getChartModel()));
gr.render(dRenderer, gcs);
String im = ((IImageMapEmitter) dRenderer).getImageMap();
BufferedWriter out = new BufferedWriter(new FileWriter(OUTPUT_HTML));
out.write("<html>");
out.newLine();
out.write("<body>");
out.newLine();
out.write("<div>");
out.newLine();
if( im != null){
out.write("<map name='testmap'>");
out.write(im);
out.write("</map>");
out.newLine();
out
.write("<img id=myimage src='standalone.png'
usemap='#testmap'></img>");
out.newLine();
out.write("</div>");
out.newLine();
out.write("</body>");
out.newLine();
out.write("</html>");
out.newLine();
out.close();
System.out.println(im);
} catch (Exception e) {
e.printStackTrace();
public static final Chart createStackedBar()
ChartWithAxes cwaBar = ChartWithAxesImpl.create();
cwaBar.setType("Bar Chart"); //$NON-NLS-1$
cwaBar.setSubType("Stacked"); //$NON-NLS-1$
// Plot
cwaBar.getBlock().setBackground(ColorDefinitionImpl.WHITE());
cwaBar.getBlock().getOutline().setVisible(true);
Plot p = cwaBar.getPlot();
p.getClientArea().setBackground(ColorDefinitionImpl.create(255,
255,
225));
// Title
cwaBar.getTitle()
.getLabel()
.getCaption()
.setValue("Stacked Bar Chart"); //$NON-NLS-1$
// Legend
Legend lg = cwaBar.getLegend();
lg.setItemType(LegendItemType.CATEGORIES_LITERAL);
//Add Script
cwaBar
.setScript("function beforeGeneration( cm, icsc )"
+ "{importPackage(Packages.org.eclipse.birt.chart.model.attribute); "
importPackage(Packages.org.eclipse.birt.chart.model.attribute.impl); "
+ " cm.getLegend().getOutline( ).setStyle(
LineStyle.DASH_DOTTED_LITERAL );"
+ " cm.getLegend().getOutline( ).setColor(
ColorDefinitionImpl.GREEN() );"
+ " cm.getLegend().getOutline( ).setVisible( true );} ");
// X-Axis
Axis xAxisPrimary = cwaBar.getPrimaryBaseAxes()[0];
xAxisPrimary.getOrigin().setType(IntersectionType.MIN_LITERAL);
// Y-Axis
Axis yAxisPrimary = cwaBar.getPrimaryOrthogonalAxis(xAxisPrimary);
yAxisPrimary.setType(AxisType.LINEAR_LITERAL);
yAxisPrimary.setLabelPosition(Position.RIGHT_LITERAL);
yAxisPrimary.getLabel().getCaption().getFont().setRotation(45);
// Data Set
TextDataSet categoryValues = TextDataSetImpl.create(new String[] {
"Item 1a", "Item 2", "Item 3", "Item 4", "Item 5" }); //$NON-NLS-1$
//$NON-NLS-2$ //$NON-NLS-3$ //$NON-NLS-4$ //$NON-NLS-5$
NumberDataSet orthoValues1 = NumberDataSetImpl.create(new double[] {
25, 35, 15, 5, 20
NumberDataSet orthoValues2 = NumberDataSetImpl.create(new double[] {
5, 10, 25, 10, 5
NullDataSet ortho = NullDataSetImpl.create(5);
SampleData sd = DataFactory.eINSTANCE.createSampleData();
BaseSampleData sdBase = DataFactory.eINSTANCE.createBaseSampleData();
sdBase.setDataSetRepresentation("");//$NON-NLS-1$
sd.getBaseSampleData().add(sdBase);
OrthogonalSampleData sdOrthogonal1 = DataFactory.eINSTANCE
.createOrthogonalSampleData();
sdOrthogonal1.setDataSetRepresentation("");//$NON-NLS-1$
sdOrthogonal1.setSeriesDefinitionIndex(0);
sd.getOrthogonalSampleData().add(sdOrthogonal1);
OrthogonalSampleData sdOrthogonal2 = DataFactory.eINSTANCE
sdOrthogonal2.setDataSetRepresentation("");//$NON-NLS-1$
sdOrthogonal2.setSeriesDefinitionIndex(1);
sd.getOrthogonalSampleData().add(sdOrthogonal2);
cwaBar.setSampleData(sd);
// X-Series
Series seCategory = SeriesImpl.create();
sdX.getSeriesPalette().shift(0);
// Y-Series
BarSeries bs1 = (BarSeries) BarSeriesImpl.create();
bs1.setDataSet(orthoValues1);
//bs1.setDataSet(ortho);
bs1.setStacked(true);
bs1.getLabel().setVisible(true);
bs1.setLabelPosition(Position.INSIDE_LITERAL);
bs1.setRiserOutline(ColorDefinitionImpl.TRANSPARENT());
Trigger tr1 = TriggerImpl.create(TriggerCondition.ONMOUSEOVER_LITERAL,
ActionImpl.create(ActionType.SHOW_TOOLTIP_LITERAL,
TooltipValueImpl.create(200, null)));
Trigger tr2 = TriggerImpl.create(TriggerCondition.ONCLICK_LITERAL,
ActionImpl.create(ActionType.URL_REDIRECT_LITERAL, URLValueImpl
.create("https://www.google.com", null, "component",
"value", "")));
bs1.getTriggers().add(tr1);
bs1.getTriggers().add(tr2);
sdY.getSeriesPalette().shift(0);
sdY.getSeries().add(bs1);
return cwaBar;
Re: Bar chart x-axis labels changed to letters after upgrade [message #674629 is a reply to message #674436] Fri, 27 May 2011 11:46 Go to previous messageGo to next message
I found the line in my original code that is causing the problem:
If I set any rotation at all on the x-axis labels the chart will start spitting out letters instead of numbers along the x-axis. Left un-rotated, it behaves as expected. It would seem there has been a bug introduced somewhere along the line in the chart engine...
Re: Bar chart x-axis labels changed to letters after upgrade [message #675427 is a reply to message #674629] Tue, 31 May 2011 09:55 Go to previous messageGo to next message
This does appear to be a bug with the SWT device renderer. Can you log
a bug for it?
Jason
Re: Bar chart x-axis labels changed to letters after upgrade [message #1721296 is a reply to message #675427] Tue, 26 January 2016 07:08 Go to previous message
In BIRT examples InteractiveCharts class change the following method with code below and then run SWTInteractiveCharts , it will work.
protected static final Chart createCBChart( )
ChartWithAxes cwaBar = ChartWithAxesImpl.create( );
cwaBar.getBlock( ).setBackground( ColorDefinitionImpl.WHITE( ) );
cwaBar.getTitle( )
.getLabel( )
.getCaption( )
.setValue( "Click \"Items\" to Call Back" ); //$NON-NLS-1$
cwaBar.setUnitSpacing( 20 );
Legend lg = cwaBar.getLegend( );
LineAttributes lia = lg.getOutline( );
lg.getText( ).getFont( ).setSize( 16 );
lia.setStyle( LineStyle.SOLID_LITERAL );
lg.getInsets( ).set( 10, 5, 0, 0 );
lg.getOutline( ).setVisible( false );
lg.setAnchor( Anchor.NORTH_LITERAL );
lg.setItemType( LegendItemType.CATEGORIES_LITERAL );
// X-Axis
Axis xAxisPrimary = cwaBar.getPrimaryBaseAxes( )[0];
xAxisPrimary.setType( AxisType.TEXT_LITERAL );
xAxisPrimary.getMajorGrid( ).setTickStyle( TickStyle.BELOW_LITERAL );
xAxisPrimary.getOrigin( ).setType( IntersectionType.VALUE_LITERAL );
xAxisPrimary.getTitle( ).setVisible( true );
// Y-Axis
Axis yAxisPrimary = cwaBar.getPrimaryOrthogonalAxis( xAxisPrimary );
yAxisPrimary.getMajorGrid( ).setTickStyle( TickStyle.LEFT_LITERAL );
yAxisPrimary.setType( AxisType.LINEAR_LITERAL );
// yAxisPrimary.getLabel( ).getCaption( ).getFont( ).setRotation( 90 );
// Data Set
TextDataSet categoryValues = TextDataSetImpl.create( new String[]{
"Item 1", "Item 2", "Item 3"} ); //$NON-NLS-1$ //$NON-NLS-2$ //$NON-NLS-3$
NumberDataSet orthoValues = NumberDataSetImpl.create( new double[]{
25, 35, 15
// X-Series
Series seCategory = SeriesImpl.create( );
seCategory.setDataSet( categoryValues );
SeriesDefinition sdX = SeriesDefinitionImpl.create( );
sdX.getSeriesPalette( ).shift( 0 );
xAxisPrimary.getSeriesDefinitions( ).add( sdX );
sdX.getSeries( ).add( seCategory );
// Y-Series
BarSeries bs = (BarSeries) BarSeriesImpl.create( );
bs.setDataSet( orthoValues );
bs.setRiserOutline( null );
bs.setSeriesIdentifier( "Callback" ); //$NON-NLS-1$
bs.getLabel( ).setVisible( true );
bs.setLabelPosition( Position.INSIDE_LITERAL );
bs.getTriggers( )
.add( TriggerImpl.create( TriggerCondition.ONCLICK_LITERAL,
ActionImpl.create( ActionType.CALL_BACK_LITERAL,
CallBackValueImpl.create( String.valueOf( bs.getSeriesIdentifier( ) ) ) ) ) );
SeriesDefinition sdY = SeriesDefinitionImpl.create( );
yAxisPrimary.getSeriesDefinitions( ).add( sdY );
sdY.getSeries( ).add( bs );
return cwaBar;
Previous Topic:how to make footer in BIRT
Next Topic:Joint DataSet
Current Time: Sun Jul 27 14:15:28 EDT 2025
Powered by FUDForum. Page generated in 0.05773 seconds
