Home » Archived » BIRT » PDF no wrapping in BIRT Report Designer 2.5.1(question about PDF no wrap BIRT 2.5.1)
PDF no wrapping in BIRT Report Designer 2.5.1 [message #674013] Wed, 25 May 2011 10:15 Go to next message
Hi all,
I'm developing some inventory reports in the BIRT Report Designer 2.5.1. Some of the descriptions for these inventory parts are pretty long, and I would like to show as much in a one-liner as possible, so I've been trying to clip them in the PDF-generated reports.
Most of the research I've done seems to involve making an external application using the BIRT API with wrapping (i.e. "options.setOption(IPDFRenderOption.PDF_TEXT_WRAPPING, true);") and preventing clipping, but in my case I'm trying to do the opposite; that is, make the text clip within the report designer.
I made a NoWrap style class with Whitespace set to No Wrapping, and the clipping works with the XLS and HTML formats. (Why doesn't it clip by simply setting No Wrapping in the Advanced properties for the object? That's another topic altogether.) But when it comes to the PDF, text output will stop on a space or hyphen in the PDF, which is undesirable.
index.php/fa/2839/0/
index.php/fa/2841/0/
index.php/fa/2840/0/
I've tried putting in the code I found in a few places under the Script screens (e.g. report/initialize, table/onCreate, row/onRender, etc.), but it's still not doing a no-wrap with clipping.
var options = new PDFRenderOption();
options.setOption(IPDFRenderOption.PDF_HYPHENATION, false);
options.setOption(IPDFRenderOption.PDF_TEXT_WRAPPING, false);
Does anyone know how to solve this issue?
Thanks in advance,
Larry
  • Attachment: birt_excel.jpg
    (Size: 34.37KB, Downloaded 1801 times)
  • Attachment: birt_pdf.jpg
    (Size: 27.34KB, Downloaded 1809 times)
  • Attachment: birt_web.jpg
    (Size: 32.01KB, Downloaded 1758 times)
Re: PDF no wrapping in BIRT Report Designer 2.5.1 [message #674076 is a reply to message #674013] Wed, 25 May 2011 14:09 Go to previous messageGo to next message
Larry
Can you try the attached report?
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.20"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.5.1.v20090903 Build &lt;2.5.1.v20090917-1447></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver</property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet"
name="Data Set" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">TEXTDESCRIPTION</property>
<text-property
name="displayName">TEXTDESCRIPTION</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">TEXTDESCRIPTION</property>
<property name="dataType">string</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">TEXTDESCRIPTION</property>
<property name="nativeDataType">12</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select
CLASSICMODELS.PRODUCTLINES.TEXTDESCRIPTION
from CLASSICMODELS.PRODUCTLINES]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>TEXTDESCRIPTION</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>4000</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>TEXTDESCRIPTION</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>TEXTDESCRIPTION</design:label>
<design:formattingHints>
<design:displaySize>4000</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
<style name="nowrap" id="23">
<property name="whiteSpace">nowrap</property>
<property name="display">block</property>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="9">
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<text-property
<expression
name="expression">dataSetRow["TEXTDESCRIPTION"]</expression>
</structure>
</list-property>
<column id="18"/>
<header>
<row id="10">
<cell id="11">
<label id="12">
<text-property
name="text">TEXTDESCRIPTION</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="13">
<cell id="14">
<grid id="19">
<property name="width">2in</property>
<column id="20"/>
<row id="21">
<cell id="22">
<data id="15">
<property
name="style">nowrap</property>
<property
name="resultSetColumn">TEXTDESCRIPTION</property>
</data>
</cell>
</row>
</grid>
</cell>
</row>
</detail>
<footer>
<row id="16">
<cell id="17"/>
</row>
</footer>
</table>
</body>
</report>
On 5/25/2011 10:15 AM, Larry H wrote:
> Hi all,
> Thanks in advance,
> Larry
> M_]C_X``02D9)1@`!`@$`2`!(``#_X14[17AI9@``34T`*@````@`!P$2``,`
> M```!``$```$:``4````!````8@$;``4````!````:@$H``,````!``(```$Q
> M``(````<````<@$R``(````4````CH=I``0````!````I````-``"OR````G
> M$``*_(```"<0061O8F4@4&AO=&]S:&]P($-3,R!7:6YD;W=S`#(P,3$Z,#4Z
> M,C4@,#DZ,#DZ,S```````Z`!``,````!``$``*`"``0````!````\*`#``0`
> M```!````6@`````````&`0,``P````$`!@```1H`!0````$```$>`1L`!0``
> M``$```$F`2@``P````$``@```@$`!`````$```$N`@(`!`````$``!0%````
> M`````$@````!````2`````'_V/_@`!!*1DE&``$"``!(`$@``/_M``Q!9&]B
> M95]#30`!_^X`#D%D;V)E`&2``````?_;`(0`#`@("`D(#`D)#!$+"@L1%0\,
> M#`\5&!,3%1,3&!$,#`P,#`P1#`P,#`P,#`P,#`P,#`P,#`P,#`P,#`P,#`P,
> M#`$-"PL-#@T0#@X0%`X.#A04#@X.#A01#`P,#`P1$0P,#`P,#!$,#`P,#`P,
> M#`P,#`P,#`P,#`P,#`P,#`P,#`P,_\``$0@`/`"@`P$B``(1`0,1`?_=``0`
> M"O_$`3\```$%`0$!`0$!``````````,``0($!08'"`D*"P$``04!`0$!`0$`
> M`````````0`"`P0%!@<("0H+$``!!`$#`@0"!0<&"`4###,!``(1`P0A$C$%
> M05%A$R)Q@3(&%)&AL4(C)!52P6(S-'*"T4,')9)3\.'Q8W,U%J*R@R9$DU1D
> M1<*C=#87TE7B9?*SA,/3=>/S1B>4I(6TE<34Y/2EM<75Y?569G:&EJ:VQM;F
> M]C='5V=WAY>GM\?7Y_<1``("`0($!`,$!08'!P8%-0$``A$#(3$2!$%187$B
> M$P4R@9$4H;%"(\%2T?`S)&+A<H*20U,58W,T\24&%J*R@P<F-<+21)-4HQ=D
> M154V=&7B\K.$P]-UX_-&E*2%M)7$U.3TI;7%U>7U5F9VAI:FML;6YO8G-T=7
> M9W>'EZ>WQ__:``P#`0`"$0,1`#\`[_\`YN?5[_RKP_\`V'J_])I?\W/J]_Y5
> MX?\`[#U?^DUHI+/]R?[TOM7T'C>K=$:/K!75@]/QJNGTT4Y&0[[+CFHM;<_[
> M8Q^[$OR;[K,-FRBG%NI].W9^^LIN)G78X8>B^ED9&2S(J:W#PJ[!B7TY5C,)
> MC[J,O%9]DOQJV/MS6U93_5KKO^S>JO1TE(.8D(@?C:"-2?"OPX7CNA]!Q[^H
> MUNS,>FW'/3\7(-?V+'KI-]OKUY36[\*K+;L]&JUM+[O5J]3]+_HV<^ZF_8QW
> MV:IM9NVY5MF#CU"AP=GM&,VX=+S-E=E5.':]]F%E/K_0?I_3S5ZBE)1^\RN_
> MP4(T"-[>!S\/'IZCGUU85-F.TTEKZ<&DMQL<OPV9M[FVX/J69;:KLC(Q;&6Y
> M^)D5_:/U:K[#Z5D;NFL&=C##QF9/3MM!?E6X&,UKO4R<BJTY%/V"O(MW8[*:
> M*;,'T*V?H,Z[]4N]=>@)(?>)5N?M41I6SP?U=Z;UFS*?U!M7V!]E%0S,EE./
> M5:\OP\3+L;14[#?8[(_:;[/5?;^J[/4QOL_JUU^C9JZG]8JV8+<S)R*\:_$P
> MKL_,]"OU*;+_`+;9D[&MQO2;^GKP,2SU:+?LN/9ZMGO_`%E=FD@<UFS$';\%
> M$6*>0Z9U3ZT6]0PJLGU?LUCZ6VN=0&2WTNH6^K;^B_0NRVU8%MS-WZID_J_Z
> M'UO277I)*.4KZ4GK?@`I)))!2DDDDE*22224\5U?K/UEHZSU"C%LM--;MN/3
> M72VPM9Z.);]HV_9?YG[0_)J];[;D>I;9Z/V+]%]HIU?JYF]:R<[*9U'?Z+*P
> MZG?6&`EV3GL'%=;M[,6K%J<S^17?_AUT"2>9B@*V%?VHK?Q-O__0]"/6NGCT
> MP[UV>JTN9OQKV\%[0QV^EOIVVNJ?Z%-GZ:__``++/5J5G#R:,VGU\<O]/<YG
> MZ2M]3MS":[&^G>VNSVO;M^BL+%Z-U_$MQWU5XGI8VXLQA:YM6]^[U+Z*V8.W
> M%LVO]/V>I[/5_P"Y>7ZNUT?'R,7I].+?6RMV.T5M].PV[FM`:+'V/IQ?TMGT
> MK/T2ES\GRL(WC/$;_P`X):>O]'YO\V@2D3K^2.WJV!1EUX=SWMOL#"(JL=6W
> MU7.IH]7)KK=CT^M;6ZNOUK6*.)USI68]E>/<XNL<UM8=58S?O9;=5;7ZM;/4
> MQ[J\7(]'*9^K6^E^CM5?,^K6-U#J>/U.UX#J6UMV^FPO_1/LN9Z.2YOVC&]1
> MUNS)])_Z>G]&H,^K-]0K=7U*W[1C&MN+:ZNMP954R^BNE]>UK;7[,RWU;OS_
> M`-$JWL8OW?Q*ZRW\3J>)F9-V-0+Q;CDBWU,>^I@(C1MV15539]+?^CL_F_TG
> MT$*SKO2JWWL=:^<<P]S:;7-<[>W'-6/8RMU>7>W(L9COHQ777>O^A_G4>K!M
> MHR'WUW2<BUMF2'M&H93]GVU;=OI[GUU6^[U%4?\`5^T^NQF=:RAUIR,:D,K(
> MIN-HS'6[W,]6YGVC?^B>_P#FK[JO]!Z`]C'^[^,E64U/6>EW-#J[C!],$&NQ
> MI!MMLPZV/8]C7UV?:J+J;:W_`*2A]?Z?TTL'K73.H.V8UK]^PV[+*;:G>F-G
> MZ79D5U/]-_JL]-W^%_P?\W8JU?U:V756G,M?J+,II:S]-8RZW.ILG;NH;5DY
> M%GZ.K_`^E2EB_5BGI_V0=-N.,W&J--WL:\W-/H-+K7O]S;-N*QC?W/\`1H^Q
> MBU]/EK+^7S*LWX)*_K)T2RC[17DE]<O`BNPN+F.II=6VKT_5=:ZW+QV4T[/5
> MO];]!ZBLLZEA/Z=9U(/<W%I;8^USZ[&/:*MWK;\>QC<AKV>F[]'Z7J+/K^J6
> M/2RKT,N^NW'K+*[/8??ZK<FJY[=FU[Z]GV?_`(7%_16?F*SC]$?7T_)Z;9DN
> MLQ\FNQI='O:^XVF\U;B^NNAK;6-QL?9^BV?GI>QB_=_$JLJL^L'2&!WZ6RPL
> M<UA951=:\N?4W,;LKIJLLL_5K&6V;&_HO\*F?]8>D,<YOK/<&@.%C*+GUOW-
> M9<QF-?54^G*M?5:RQE.-9;;_`-MV*'_-STI?A9EN/D;W/;<6LL(#Y8^K98S8
> MYC:_293_`*+[+C_X/U*[:UWU*Z<YK_1MLK<]HK)<&VM-;:L?&9593>U]5G]"
> MH>]SF^I9^FJ_F;GI'!BUJ/EJ4671OZOT[&KQK<BQ]+<QS64"RJQCBY[F4L;9
> M6]@LH_275M_3MK4'=>Z4UU@=99MI:7V6>A=Z;0W<-KK_`$O1]7V>RGU/6L_P
> M;/TC%%_U?HMHP*;;('3R-K:JV5UO'M_1&@-<RNK:S9LK0L?ZJ8%-%E9LLMR'
> MU-I;G/%9R&M8[U6;<CT_=^F:RY[+/T5EK/TE:7L8NWXR39;3.L=-=B_:S:YE
> M0N9CN%E=E;V6VOKIIJNHM8R^AUC[Z?YZMGZ.VN[^9_2(;NO=+:;1ON<*1-CF
> MX][F@[A4*Q8RES'WN>[V8[/T_P#P:=G0VG&LJR<A^1;?D5Y61:6M:'NK-6VK
> MTH-;*/1QJJ-G_3]7](J%?U.JJW>GEN+W4MI&1952_(ECFVUN.5Z;;'U[ZZ_5
> MQW_HK?ZZ'W?'V_&7[O\`WRK+<'UBZ00XBRZ*ZGWVG[-D16ROUO4^T'T?U>W]
> M5O;Z%VR]_P#H_P!)6BMZQ@/Q793'6;66MH=6ZFUEHM>6-JJ?C65MR:_4]:IW
> MOJ_FK/7_`)GWK/M^I]=U[\B[*]2Z^BVB^YU-1LFT7M=9C7%F_%_I.STF?H_2
> MHJ]3_"OLN'H;3B6MS+W95MM]>5=8YC`'.H-3Z:O1VN8VG;C5_P`O_"H^QBT]
> M/:]9?X2+.K8?U+`KLLKLN#75%XLEK@&FMC,BS<^-GMINK>HX_5NGY-E-=-KG
> MG)K;;4[T[`TM>WUF--KF"IESJ?TOV=[_`+1Z?^"5)W3^L5=6MSZ::+:G/<^N
> MJS)>R'.95CNM.S!M=[JL>O\`0>I8QGZ3](_]'Z5*KZO=7JLI?Z5);10S&`;F
> MVUV%M;/0'ZYCX%>372_^=?B5?H/M7ZS_`#BN1Y#DS'65'@!_G(?SG6/"CB/X
> M]OT7_]'K&=6Z@&8WJFI@R!DEN18ZREA;2TW8U_HO=;9C46L_27^K=8]E7T/I
> M_H[?3\K+R,1MUYASG.V.8'UM?6#^AO;1:^VVCUF>[TK+'_O_`.$06_5G"96:
> MF59+:C(-3<B\,]W\Y^B;=Z?Z3_">W])^>K6'TQF#1]GQ:7LJ#B\-)+M7?2]U
> MCG.5C++`8UC$A+BZQ$?3<_Z\_P!Z'I0+<_/ZQU#$ZI5C55^IAAN.[(>)+@<F
> MZW$9M?\`::W5_P`U^B]/`SO6L_1V_9:_TRA@]=S;K\.J\TN&<VB]KJ'O_1U9
> M%69>VAV^RSU,BMV!_2/T=60Q]OZI3Z2U'=/KLOKRGXK'Y%((IR'5M-C`9D57
> M.;ZM7TG?0>H/Z-AV564V=/H?3;8;K:G45EC[3S?966;++_\`AG_I%7'[4_P0
> MX.3U2S,S:LFZEU.,]K*Q2RUC_>QF0UUC[<K(9[66>G[*O?\`SOL_FE2MZ[U"
> MO+MQW&I@LM]'"<XO<W^?JP'9%N15>^F]M;K]V1A?Y,S<>_9B?I:[/MJUS@`E
> MA^S@&IP?7#0(<UCJ&.]O[E+W5,_X-1_9=!=>\X56_+&W*=Z3)N;&W9DNV_K#
> M=O\`IMZ7571S<?K6==<:C;C5#%D93[++&MN/VB_IP.#^D_0>_&W[;OMGZQ=5
> M@?\`=I5,/ZR]6SSB#&J:QV0X>M0YKGVU-;53D66VM?G85;*LAN1ZN+Z=F59]
> MEV?TF^VVC%WOV;5^@_4Z_P!4$8OZ)GZ$$;",;V_J_M;M_0[%&[I.+?L]?`IN
> M]/;Z?J4UOVAD^D*][';/2WN]+;_-I#QU4?#1S_VIU;'P>HY62^G(=A7&BJNA
> MME6XM?4Q^_U\NYNZS[1^B9OI]_\`.6H>+U_/NS7^M7]EP,9EMN8]T/?6VN[-
> MQ_TMK,W94_9@;OU?$ZC6^SU/YA;1Q7D.::9:\[G@M!#C^\\?GO\`;])R%9TK
> M'LN9D6X-5E]<^G<^FMSV[B7OV6.:7MWO>][_`.6ET'?O]%=_/\'#9]:,S)QF
> MOQG4575MOMRFWFW:UE53,RBL?I,:RI]E%WIY&0]MU5&13D>G5=Z:T^H=5NQ*
> M,/(:UQKR;6"YECG![*33=EW/9M^E?CLI^A_QJM9'3JLMS7Y>)7DOK(<QUU3+
> M'-+9+',=:U[F[-WM4F81K$,HCWOM^B#^DL+G6VB?HOL]2S_/25_:XN-]8<R^
> MNG(?;C4X]I;2[<]Y++'8G[5.:YYN8QV!6W_`>RW[+^M_;O\``IV=2^LEE>,V
> MM^,<K-M)QJ'57M<[%'I_KV2PYV_`8UKGV;+/7?\`IL+&_1Y=ME2UCTK'<278
> M-1)J^S$FFLDT?]Q?H_T7_NO_`#/\A!_YO=*@#]DXD-.X#[+3H>=W\WY)=5--
> MW6.I6U=+=B,#G]0-KKAK9LKI<&ES6OS,'\UWZ1_JY#_]'BVH74_K!G8?5+<:
> ML-?14R0',OEQ^S79[G?;FV,PV>GZ+/U/T?M5M/Z6M:9Z%T]Q<7=,QB76>LXG
> M'J)-FOZ9WZ/^=]W\[]-6'X?J3ZN.VS<0YV]C72YOT'.WAVYS/S'?F)*<''^L
> MG4,DT4`549&1LA[S:^MN\Y;J[!4RRJW(]?'PMN/0RZI_VSUJ_5_0^^Z.KWNZ
> M"WJ8+7V%K0YLVBLN]9N);[+Q3DL_/_17-]2M_P"C_2*]9TVJVMU5N'794]H8
> M^MU3'-<P'>VM['-V.K:]WJ-K^AZGO2;T^NH/V8S6-<UC7M#`&[:AMI;Z?\VU
> ME+?YOVI*<[.ZYDXUU]-;0]U5UE%8W.+B6UXME3W,WU_X3-_2>^IGI[/TE/\`
> M.J-7UD9]IIQ<FSTW^C99DV18`'UN]/TJF#UV^SW_`&G9?E,J?^BJOO\`YQ6[
> MN@8U]UM]M>0;;QMM+;[FAS3/Z$M9:UOH>[^8_F4F]`I8UK&?;6-8`UC6Y>2T
> M-:.&,:V_V,_DL5L3Y3@`,)\5:F/"/5P[_-);ZK?_TM[#SJJ\S#L-CZJJ06M<
> M"YHK;.0[)^TXS77,LNR_6Q?3V?:J_P!7];]!Z?IKI/J[8']*J;ZKKG5E['/>
> MYSW&'.+=]EOOL=L<SW*]^L_R/Q2_6?Y'XJ]S<Y2CZL?!K'7CC/\`SG_KQ;&N
> M_1Y[J73^JW=>Q<G%JL-#&XX%P<P5L++KGY>^<BK(9ZF.YC/T&+?]I_F;OT:K
> MX&%UK!=1D#`RW"I])RJ!D5/?=<*<VK+S6>ME,I=3=;?B?SUM-UNSU/L=7H+I
> MZ_M&P;=D?-2_6?Y'XJD+HUW7'Q[.5T[`KP.HY.1]EL8<VYK:G;C8&M=4V^[U
> M&^K970S[37:WV?X;^NJ67C_6BR_,O]']7R/;553D3<UM+JWXL56_9L6GU6,R
> M_7]/+>^Q^7CU6_H<;]'T7ZS_`"/Q2_6?Y'XH#I^"GG>HLZUET]0JKP<NL9S:
> MG5'U,?\`1AFUMU.T9S?TMFU_LK_5[?\`"9/\YZ<L3I_5Z\W%N;7=5B[Z&VT.
> ML:UM;*J,@.M%%5]U3=^38VF^BI]OJ?H+O^TZZ#]9_D?BE^L_R/Q2Z_4?V*Z'
> MR-^75Y7.Z1]8;*[MSKLBI]MSV8[362UASJ<FMGZ7)QV9'K83'^R^VO[/3^K_
> M`/`(N9A?66QN0_'Q]E%F(_#IH&1LN:TTEM=@QV'['7?]M_[4?M'U/LG_``BZ
> M7]9_D?BE^L_R/Q2Z#M90=RYG0:[L4VX[L6[$HN>^W%HM<VSTF-;178RRRJW)
> MJJ]?(?=?30RZWV>I9^C_`)E9]_3/K$_#MHH<]MK/M?I6VY!:7>OD.%+FW4^N
> MZNZGIWJ?9M]'I8]N11^C_0>SH_UG^1^*7ZS_`"/Q2/CV7#P[C[6MTK"?CT-M
> MO+QE75U?:&&UUK&O:W:]M/J?F[O^W%>0OUG^1^*7ZS_(_%$[K15"DJ2%^L_R
> M/Q2_6?Y'XH)2J%W\T_\`JG\BC^L_R/Q4;/M'ING9$&8GP24\[=U"MG6LFG(R
> M+*L<66$VM>^`'TT8PJJ:S<]EU=U5UG\WZ5?\]79ZMB%B=6;C_8+OM!MNIZ?Z
> M&15=9:*O7!Q=NYS:LC=8[9E[LKTKUU/ZS_(_%+]9_D?BM#W/0+PDQ$!_E(^J
> M/#/^K^D@7KKU+__9_^T:;E!H;W1O<VAO<"`S+C``.$))300E```````0````
> M`````````````````#A"24T$+P``````2D\``0!(````2```````````````
> MT`(``$`"`````````````!@#``!D`@````'``P``L`0```$`#R<!`&QL=6X`
> M````````````.$))30/M```````0`$@````!``$`2`````$``3A"24T$)@``
> M````#@`````````````_@```.$))300-```````$````>#A"24T$&0``````
> M!````!XX0DE-`_,```````D```````````$`.$))300*```````!```X0DE-
> M)Q````````H``0`````````".$))30/U``````!(`"]F9@`!`&QF9@`&````
> M```!`"]F9@`!`*&9F@`&```````!`#(````!`%H````&```````!`#4````!
> M`"T````&```````!.$))30/X``````!P``#_________________________
> M____`^@`````_____________________________P/H`````/__________
> M__________________\#Z`````#_____________________________`^@`
> M`#A"24T$`````````@`!.$))300"```````$`````#A"24T$,````````@$!
> M.$))300M```````&``$````".$))300(```````0`````0```D````)`````
> M`#A"24T$'@``````!``````X0DE-!!H``````TD````&``````````````!:
> M````\`````H`50!N`'0`:0!T`&P`90!D`"T`,0````$`````````````````
> M`````````0``````````````\````%H``````````````````````0``````
> M```````````````````0`````0```````&YU;&P````"````!F)O=6YD<T]B
> M:F,````!````````4F-T,0````0`````5&]P(&QO;F<``````````$QE9G1L
> M;VYG``````````!"=&]M;&]N9P```%H`````4F=H=&QO;F<```#P````!G-L
> M:6-E<U9L3',````!3V)J8P````$```````5S;&EC90```!(````'<VQI8V5)
> M1&QO;F<`````````!V=R;W5P241L;VYG``````````9O<FEG:6YE;G5M````
> M#$53;&EC94]R:6=I;@````UA=71O1V5N97)A=&5D`````%1Y<&5E;G5M````
> M"D53;&EC951Y<&4`````26UG(`````9B;W5N9'-/8FIC`````0```````%)C
> M=#$````$`````%1O<"!L;VYG``````````!,969T;&]N9P``````````0G1O
> M;6QO;F<```!:`````%)G:'1L;VYG````\`````-U<FQ415A4`````0``````
> M`&YU;&Q415A4`````0```````$US9V5415A4`````0``````!F%L=%1A9U1%
> M6%0````!```````.8V5L;%1E>'1)<TA434QB;V]L`0````AC96QL5&5X=%1%
> M6%0````!```````):&]R>D%L:6=N96YU;0````]%4VQI8V5(;W)Z06QI9VX`
> M```'9&5F875L=`````EV97)T06QI9VYE;G5M````#T53;&EC959E<G1!;&EG
> M;@````=D969A=6QT````"V)G0V]L;W)4>7!E96YU;0```!%%4VQI8V5"1T-O
> M;&]R5'EP90````!.;VYE````"71O<$]U='-E=&QO;F<`````````"FQE9G1/
> M=71S971L;VYG``````````QB;W1T;VU/=71S971L;VYG``````````MR:6=H
> M=$]U='-E=&QO;F<``````#A"24T$*```````#`````$_\````````#A"24T$
> M%```````!`````(X0DE-!`P`````%"$````!````H````#P```'@``!P@```
> M%`4`&``!_]C_X``02D9)1@`!`@``2`!(``#_[0`,061O8F5?0TT``?_N``Y!
> M9&]B90!D@`````'_VP"$``P("`@)"`P)"0P1"PH+$14/#`P/%1@3$Q43$Q@1
> M#`P,#`P,$0P,#`P,#`P,#`P,#`P,#`P,#`P,#`P,#`P,#`P!#0L+#0X-$`X.
> M$!0.#@X4%`X.#@X4$0P,#`P,$1$,#`P,#`P1#`P,#`P,#`P,#`P,#`P,#`P,
> M#`P,#`P,#`P,#/_``!$(`#P`H`,!(@`"$0$#$0'_W0`$``K_Q`$_```!!0$!
> M`0$!`0`````````#``$"!`4&!P@)"@L!``$%`0$!`0$!``````````$``@,$
> M!08'"`D*"Q```00!`P($`@4'!@@%`PPS`0`"$0,$(1(Q!4%181,B<8$R!A21
> MH;%"(R054L%B,S1R@M%#!R624_#A\6-S-1:BLH,F1)-49$7"HW0V%])5XF7R
> MLX3#TW7C\T8GE*2%M)7$U.3TI;7%U>7U5F9VAI:FML;6YO8W1U=G=X>7I[?'
> MU^?W$0`"`@$"!`0#!`4&!P<&!34!``(1`R$Q$@1!46%Q(A,%,H&1%*&Q0B/!
> M4M'P,R1BX7*"DD-3%6-S-/$E!A:BLH,')C7"TD235*,79$55-G1EXO*SA,/3
> M=>/S1I2DA;25Q-3D]*6UQ=7E]59F=H:6IK;&UN;V)S='5V=WAY>GM\?_V@`,
> M`P$``A$#$0`_`.__`.;GU>_\J\/_`-AZO_2:7_-SZO?^5>'_`.P]7_I-:*2S
> M_<G^]+[5]!XWJW1&CZP5U8/3\:KI]-%.1D.^RXYJ+6W/^V,?NQ+\F^ZS#9LH
> MIQ;J?3MV?OK*;B9UV.&'HOI9&1DLR*FMP\*NP8E].58S"8^ZC+Q6?9+\:MC[
> M<UM64_U:Z[_LWJKT=)2#F)"('XV@C4GPK\.%X[H?0<>_J-;LS'IMQST_%R#7
> M]BQZZ3?;Z]>4UN_"JRV[/1JM;2^[U:O4_2_Z-G/NIOV,=]FJ;6;MN5;9@X]0
> MH<'9[1C-N'2\S97953AVO?9A93Z_T'Z?T\U>HI24?O,KO\%"-`C>W@<_#QZ>
> MHY]=6%39CM-):^G!I+<;'+\-F;>YMN#ZEF6VJ[(R,6QEN?B9%?VC]6J^P^E9
> M&[IK!G8PP\9F3T[;07Y5N!C-:[U,G(JM.13]@KR+=V.RFBFS!]"MGZ#.N_5+
> MO77H"2'WB5;G[5$:5L\']7>F]9LRG]0;5]@?914,S)93CU6O+\/$R[&T5.PW
> MV.R/VF^SU7V_JNSU,;[/ZM=?HV:NI_6*MF"W,R<BO&OQ,*[/S/0K]2FR_P"V
> MV9.QK<;TF_IZ\#$L]6BW[+CV>K9[_P!979I('-9LQ!V_!1%BGD.F=4^M%O4,
> M*K)]7[-8^EMKG4!DM]+J%OJV_HOT+LMM6!;<S=^J9/ZO^A];TEUZ22CE*^E)
> MZWX`*22204I))))2DDDDE/%=7ZS]9:.L]0HQ;+336[;CTUTML+6>CB6_:-OV
> M7^9^T/R:O6^VY'J6V>C]B_1?:*=7ZN9O6LG.RF=1W^BRL.IWUA@)=DY[!Q76
> M[>S%JQ:G,_D5W_X==`DGF8H"MA7]J*W\3;__T/0CUKIX],.]=GJM+F;\:]O!
> M>T,=OI;Z=MKJG^A39^FO_P`"RSU:E9P\FC-I]?'+_3W.9^DK?4[<PFNQOIWM
> MKL]KV[?HK"Q>C=?Q+<=]5>)Z6-N+,86N;5O?N]2^BMF#MQ;-K_3]GJ>SU?\`
> MN7E^KM='Q\C%Z?3BWULK=CM%;?3L-NYK0&BQ]CZ<7]+9]*S]$I<_)\K"-XSQ
> M&_\`."6GK_1^;_-H$I$Z_DCMZM@49=>'<][;[`PB*K'5M]5SJ:/5R:ZW8]/K
> M6UNKK]:UBCB=<Z5F/97CW.+K'-;6'56,W[V6W56U^K6SU,>ZO%R/1RF?JUOI
> M?H[57S/JUC=0ZGC]3M>`ZEM;=OIL+_T3[+F>CDN;]HQO4=;LR?2?^GI_1J#/
> MJS?4*W5]2M^T8QK;BVNKK<&55,OHKI?7M:VU^S,M]6[\_P#1*M[&+]W\2NLM
> M_$ZGB9F3=C4"\6XY(M]3'OJ8"(T;=D554V?2W_H[/YO])]!"LZ[TJM]['6OG
> M',/<VFUS7.WMQS5CV,K=7EWMR+&8[Z,5UUWK_H?YU'JP;:,A]]=TG(M;9DA[
> M1J&4_9]M6W;Z>Y]=5ON]15'_`%?M/KL9G6LH=:<C&I#*R*;C:,QUN]S/5N9]
> MHW_HGO\`YJ^ZK_0>@/8Q_N_C)5E-3UGI=S0ZNXP?3!!KL:0;;;,.MCV/8U]=
> MGVJBZFVM_P"DH?7^G]-+!ZUTSJ#MF-:_?L-NRRFVIWIC9^EV9%=3_3?ZK/3=
> M_A?\'_-V*M7]6MEU5IS+7ZBS*:6L_36,NMSJ;)V[J&U9.19^CJ_P/I4I8OU8
> MIZ?]D'3;CC-QJC3=[&O-S3Z#2ZU[_<VS;BL8W]S_`$:/L8M?3Y:R_E\RK-^"
> M2OZR=$LH^T5Y)?7+P(KL+BYCJ:75MJ]/U76NMR\=E-.SU;_6_0>HK+.I83^G
> M6=2#W-Q:6V/M<^NQCVBK=ZV_'L8W(:]GIN_1^EZBSZ_JECTLJ]#+OKMQZRRN
> MSV'W^JW)JN>W9M>^O9]G_P"%Q?T5GYBLX_1'U]/R>FV9+K,?)KL:71[VON-I
> MO-6XOKKH:VUC<;'V?HMGYZ7L8OW?Q*K*K/K!TA@=^ELL+'-865476O+GU-S&
> M[*Z:K++/U:QEMFQOZ+_"IG_6'I#'.;ZSW!H#A8RBY];]S67,9C7U5/IRK7U6
> MLL93C66V_P#;=BA_S<]*7X69;CY&]SVW%K+"`^6/JV6,V.8VOTF4_P"B^RX_
> M^#]2NVM=]2NG.:_T;;*W/:*R7!MK36VK'QF564WM?59_0J'O<YOJ6?IJOYFY
> MZ1P8M:CY:E%ET;^K].QJ\:W(L?2W,<UE`LJL8XN>YE+&V5O8+*/TEU;?T[:U
> M!W7NE-=8'66;:6E]EGH7>FT-W#:Z_P!+T?5]GLI]3UK/\&S](Q1?]7Z+:,"F
> MVR!T\C:VJME=;Q[?T1H#7,KJVLV;*T+'^JF!3196;++<A]3:6YSQ6<AK6.]5
> MFW(]/W?IFLN>RS]%9:S])6E[&+M^,DV6TSK'378OVLVN94+F8[A9796]EMKZ
> MZ::KJ+6,OH=8^^G^>K9^CMKN_F?TB&[KW2VFT;[G"D38YN/>YH.X5"L6,I<Q
> M][GN]F.S]/\`\&G9T-IQK*LG(?D6WY%>5D6EK6A[JS5MJ]*#6RCT<:JC9_T_
> M5_2*A7]3JJMWIY;B]U+:1D654OR)8YMM;CE>FVQ]>^NOU<=_Z*W^NA]WQ]OQ
> ME^[_`-\JRW!]8ND$.(LNBNI]]I^S9$5LK];U/M!]']7M_5;V^A=LO?\`Z/\`
> M25HK>L8#\5V4QUFUEK:'5NIM9:+7EC:JGXUE;<FOU/6J=[ZOYJSU_P"9]ZS[
> M?J?7=>_(NRO4NOHMHON=34;)M%[768UQ9OQ?Z3L])GZ/TJ*O4_PK[+AZ&TXE
> MK<R]V5;;?7E76.8P!SJ#4^FKT=KF-IVXU?\`+_PJ/L8M/3VO67^$BSJV']2P
> M*[+*[+@UU1>+):X!IK8S(LW/C9[:;JWJ./U;I^39373:YYR:VVU.].P-+7M]
> M9C3:Y@J9<ZG]+]G>_P"T>G_@E2=T_K%75K<^FFBVISW/KJLR7LASF58[K3LP
> M;7>ZK'K_`$'J6,9^D_2/_1^E2J^KW5ZK*7^E26T4,Q@&YMM=A;6ST!^N8^!7
> MDUTO_G7XE7Z#[5^L_P`XKD>0Y,QUE1X`?YR'\YUCPHXC^/;]%__1ZQG5NH!F
> Path: news.eclipse.org!not-for-mail
> From: Larry H <forums-noreply@eclipse.org>
> Newsgroups: eclipse.birt
> Subject:
> =?utf-8?Q?PDF=20no=20wrapping=20in=20BIRT=20Report=20Designer=202?=
> =?utf-8?Q?.5.1?=
> Date: Wed, 25 May 2011 10:15:32 -0400
> Organization: Eclipse Community Forums
> Lines: 2169
> Message-ID: <irj2e0$r5f$1@news.eclipse.org>
> Reply-To: Larry H <forums-noreply@eclipse.org>
> NNTP-Posting-Host: 172.30.206.106
> Content-Type: text/plain; charset=utf-8; format=flowed
> X-Trace: news.eclipse.org 1306332416 27823 172.30.206.106 (25 May 2011
> 14:06:56 GMT)
> X-Complaints-To: news@news.eclipse.org
> NNTP-Posting-Date: Wed, 25 May 2011 14:06:56 +0000 (UTC)
> X-FUDforum: c7ed4ca4d6a4ff3b73a07e2176df25fb <674013>
> User-Agent: FUDforum
> Xref: news.eclipse.org eclipse.birt:41973
> Hi all,
> Thanks in advance,
> Larry
> M-ZIJ8,@9);D6.LI86TM-V-?Z+W6V8U%K/TE_JW6/95]#Z?Z.WT_*R\C$;=>8
> M<YSMCF!];7U@_H;VT6OMMH]9GN]*RQ_[_P#A$%OU9PF5FIE62VHR#4W(O#/=
> M_.?HFW>G^D_PGM_2?GJUA],9@T?9\6E[*@XO#22[5WTO=8YSE8RRP&-8Q(2X
> MNL1'TW/^O/\`>AZ4"W/S^L=0Q.J58U5?J88;CNR'B2X')NMQ&;7_`&FMU?\`
> M-?HO3P,[UK/T=OV6O],H8/7<VZ_#JO-+AG-HO:ZA[_T=615F7MH=OLL]3(K=
> M@?TC]'5D,?;^J4^DM1W3Z[+Z\I^*Q^12"*<AU;38P&9%5SF^K5])WT'J#^C8
> M=E5E-G3Z'TVV&ZVIU%98^T\WV5EFRR__`(9_Z15Q^U/\$.#D]4LS,VK)NI=3
> MC/:RL4LM8_WL9D-=8^W*R&>UEGI^RKW_`,[[/YI4K>N]0KR[<=QJ8++?1PG.
> M+W-_GZL!V1;D57OIO;6Z_=D87^3,W'OV8GZ6NS[:M<X`)8?LX!J<'UPT"'-8
> MZACO;^Y2]U3/^#4?V7077O.%5ORQMRG>DR;FQMV9+MOZPW;_`*;>EU5T<W'Z
> MUG77&HVXU0Q9&4^RRQK;C]HOZ<#@_I/T'OQM^V[[9^L758'_`':53#^LO5L\
> MX@QJFL=D.'K4.:Y]M36U4Y%EMK7YV%6RK(;D>KB^G9E6?9=G])OMMHQ=[]FU
> M?H/U.O\`5!&+^B9^A!&PC&]OZO[6[?T.Q1NZ3BW[/7P*;O3V^GZE-;]H9/I"
> MO>QVSTM[O2V_S:0\=5'PT<_]J=6Q\'J.5DOIR'85QHJKH;95N+7U,?O]?+N;
> MNL^T?HF;Z??_`#EJ'B]?S[LU_K5_9<#&9;;F/=#WUMKNS<?]+:S-V5/V8&[]
> M7Q.HUOL]3^86T<5Y#FFF6O.YX+00X_O/'Y[_`&_2<A6=*Q[+F9%N#59?7/IW
> M/IK<]NXE[]ECFE[=[WO>_P#EI=!W[_17?S_!PV?6C,R<9K\9U%5U;;[<IMYM
> MVM954S,HK'Z3&LJ?91=Z>1D/;=51D4Y'IU7>FM/J'5;L2C#R&M<:\FU@N98Y
> MP>RDTW9=SV;?I7X[*?H?\:K61TZK+<U^7B5Y+ZR',==4RQS2V2QS'6M>YNS=
> M[5)F$:Q#*(][[?H@_I+"YUMHGZ+[/4L_STE?VN+C?6',OKIR'VXU./:6TNW/
> M>2RQV)^U3FN>;F,=@5M_P'LM^R_K?V[_``*=G4OK)97C-K?C'*S;2<:AU5[7
> M.Q1Z?Z]DL.=OP&-:Y]FRSUW_`*;"QOT>7;94M8]*QW$EV#42:OLQ)IK)-'_<
> M7Z/]%_[K_P`S_(0?^;W2H`_9.)#3N`^RTZ'G=_-^27533=UCJ5M72W8C`Y_4
> M#:ZX:V;*Z7!I<UK\S!_-=^D?ZN0__1XMJ%U/ZP9V'U2W&K#7T5,D!S+Y<?LU
> MV>YWVYMC,-GI^BS]3]'[5;3^EK6F>A=/<7%W3,8EUGK.)QZB39K^F=^C_G?=
> M_._35A^'ZD^KCMLW$.=O8UTN;]!SMX=N<S\QWYB2G!Q_K)U#)-%`%5&1D;(>
> M\VOK;O.6ZNP5,LJMR/7Q\+;CT,NJ?]L]:OU?T/ONCJ][N@MZF"U]A:T.;-HK
> M+O6;B6^R\4Y+/S_T5S?4K?\`H_TBO6=-JMK=5;AUV5/:&/K=4QS7,!WMK>QS
> M=CJVO=ZC:_H>I[TF]/KJ#]F,UC7-8U[0P!NVH;:6^G_-M92W^;]J2G.SNN9.
> M-=?36T/=5=916-SBXEM>+94]S-]?^$S?TGOJ9Z>S])3_`#JC5]9&?::<7)L]
> M-_HV69-D6`!];O3]*I@]=OL]_P!IV7Y3*G_HJK[_`.<5N[H&-?=;?;7D&V\;
> M;2V^YH<TS^A+66M;Z'N_F/YE)O0*6-:QGVUC6`-8UN7DM#6CAC&MO]C/Y+%;
> M$^4X`#"?%6ICPCU<._S26^JW_]+>P\ZJO,P[#8^JJD%K7`N:*VSD.R?M.,UU
> MS++LOUL7T]GVJO\`5_6_0>GZ:Z3ZNV!_2JF^JZYU9>QSWN<]QASBW?9;[[';
> M',]RO?K/\C\4OUG^1^*O<W.4H^K'P:QUXXS_`,Y_Z\6QKOT>>ZET_JMW7L7)
> MQ:K#0QN.!<',%;"RZY^7OG(JR&>ICN8S]!BW_:?YF[]&J^!A=:P749`P,MPJ
> M?2<J@9%3WW7"G-JR\UGK93*74W6WXG\];3=;L]3['5Z"Z>O[1L&W9'S4OUG^
> M1^*I"Z-=UQ\>SE=.P*\#J.3D?9;&'-N:VIVXV!K75-ON]1OJV5T,^TUVM]G^
> M&_KJEEX_UHLOS+_1_5\CVU54Y$W-;2ZM^+%5OV;%I]5C,OU_3RWOL?EX]5OZ
> M'&_1]%^L_P`C\4OUG^1^*`Z?@IYWJ+.M9=/4*J\'+K&<VIU1]3'_`$89M;=3
> MM&<W]+9M?[*_U>W_``F3_.>G+$Z?U>O-Q;FUW58N^AMM#K&M;6RJC(#K115?
> M=4W?DV-IOHJ?;ZGZ"[_M.N@_6?Y'XI?K/\C\4NOU']BNA\C?EU>5SND?6&RN
> M[<Z[(J?;<]F.TUDM8<ZG)K9^ER<=F1ZV$Q_LOMK^ST_J_P#P"+F87UEL;D/Q
> M\?919B/PZ:!D;+FM-);78,=A^QUW_;?^U'[1]3[)_P`(NE_6?Y'XI?K/\C\4
> MN@[64'<N9T&N[%-N.[%NQ*+GOMQ:+7-L])C6T5V,LLJMR:JO7R'W7TT,NM]G
> MJ6?H_P"96??TSZQ/P[:*'/;:S[7Z5MN06EWKY#A2YMU/KNKNIZ=ZGV;?1Z6/
> M;D4?H_T'LZ/]9_D?BE^L_P`C\4CX]EP\.X^UK=*PGX]#;;R\95U=7VAAM=:Q
> MKVMVO;3ZGYN[_MQ7D+]9_D?BE^L_R/Q1.ZT50I*DA?K/\C\4OUG^1^*"4JA=
> M_-/_`*I_(H_K/\C\5&S[1Z;IV1!F)\$E/.W=0K9UK)IR,BRK'%EA-K7O@!]-
> M&,*JFLW/9=7=5=9_-^E7_/5V>K8A8G5FX_V"[[0;;J>G^AD5766BKUP<7;N<
> MVK(W6.V9>[*]*]=3^L_R/Q2_6?Y'XK0]ST"\),1`?Y2/JCPS_J_I(%ZZ]2__
> MV0`X0DE-!"$``````%4````!`0````\`00!D`&\`8@!E`"``4`!H`&\`=`!O
> M`',`:`!O`'`````3`$$`9`!O`&(`90`@`%``:`!O`'0`;P!S`&@`;P!P`"``
> M0P!3`#,````!`#A"24T$!@``````!P`$`````0$`_^$/S6AT='`Z+R]N<RYA
> M9&]B92YC;VTO>&%P+S$N,"\`/#]X<&%C:V5T(&)E9VEN/2+ON[\B(&ED/2)7
> M-4TP37!#96AI2'IR95-Z3E1C>FMC.60B/SX@/'@Z>&UP;65T82!X;6QN<SIX
> M/2)A9&]B93IN<SIM971A+R(@>#IX;7!T:STB061O8F4@6$U0($-O<F4@-"XQ
> M+6,P,S8@-#8N,C<V-S(P+"!-;VX@1F5B(#$Y(#(P,#<@,C(Z-#`Z,#@@("`@
> M("`@("(^(#QR9&8Z4D1&('AM;&YS.G)D9CTB:'1T<#HO+W=W=RYW,RYO<F<O
> M,3DY.2\P,B\R,BUR9&8M<WEN=&%X+6YS(R(^(#QR9&8Z1&5S8W)I<'1I;VX@
> M<F1F.F%B;W5T/2(B('AM;&YS.F1C/2)H='1P.B\O<'5R;"YO<F<O9&,O96QE
> M;65N=',O,2XQ+R(@>&UL;G,Z>&%P/2)H='1P.B\O;G,N861O8F4N8V]M+WAA
> M<"\Q+C`O(B!X;6QN<SIX87!-33TB:'1T<#HO+VYS+F%D;V)E+F-O;2]X87`O
> M,2XP+VUM+R(@>&UL;G,Z<W12968](FAT='`Z+R]N<RYA9&]B92YC;VTO>&%P
> M+S$N,"]S5'EP92]297-O=7)C95)E9B,B('AM;&YS.G!H;W1O<VAO<#TB:'1T
> M<#HO+VYS+F%D;V)E+F-O;2]P:&]T;W-H;W`O,2XP+R(@>&UL;G,Z=&EF9CTB
> M:'1T<#HO+VYS+F%D;V)E+F-O;2]T:69F+S$N,"\B('AM;&YS.F5X:68](FAT
> M='`Z+R]N<RYA9&]B92YC;VTO97AI9B\Q+C`O(B!D8SIF;W)M870](FEM86=E
> M+VIP96<B('AA<#I#<F5A=&]R5&]O;#TB061O8F4@4&AO=&]S:&]P($-3,R!7
> M:6YD;W=S(B!X87`Z0W)E871E1&%T93TB,C`Q,2TP-2TR-50P.3HP.3HS,"TP
> M-3HP,"(@>&%P.DUO9&EF>41A=&4](C(P,3$M,#4M,C54,#DZ,#DZ,S`M,#4Z
> M,#`B('AA<#I-971A9&%T841A=&4](C(P,3$M,#4M,C54,#DZ,#DZ,S`M,#4Z
> M,#`B('AA<$U-.D1O8W5M96YT240](G5U:60Z-$0P1#<U-T9$.#@V13`Q,3DP
> M,$%!,C)#,#DQ-D8T-D,B('AA<$U-.DEN<W1A;F-E240](G5U:60Z-$4P1#<U
> M-T9$.#@V13`Q,3DP,$%!,C)#,#DQ-D8T-D,B('!H;W1O<VAO<#I#;VQO<DUO
> M9&4](C,B('!H;W1O<VAO<#I)0T-0<F]F:6QE/2)S4D="($E%0S8Q.38V+3(N
> M,2(@<&AO=&]S:&]P.DAI<W1O<GD](B(@=&EF9CI/<FEE;G1A=&EO;CTB,2(@
> M=&EF9CI84F5S;VQU=&EO;CTB-S(P,#`P+S$P,#`P(B!T:69F.EE297-O;'5T
> M:6]N/2(W,C`P,#`O,3`P,#`B('1I9F8Z4F5S;VQU=&EO;E5N:70](C(B('1I
> M9F8Z3F%T:79E1&EG97-T/2(R-38L,C4W+#(U."PR-3DL,C8R+#(W-"PR-S<L
> M,C@T+#4S,"PU,S$L,C@R+#(X,RPR.38L,S`Q+#,Q."PS,3DL-3(Y+#4S,BPS
> M,#8L,C<P+#(W,2PR-S(L,S`U+#,Q-2PS,S0S,CLS03(U-4)#.$)!,D8U.#$Y
> M-31#.$,W,40Y,SDS1D%!,"(@97AI9CI0:7AE;%A$:6UE;G-I;VX](C(T,"(@
> M97AI9CI0:7AE;%E$:6UE;G-I;VX](CDP(B!E>&EF.D-O;&]R4W!A8V4](C$B
> M(&5X:68Z3F%T:79E1&EG97-T/2(S-C@V-"PT,#DV,"PT,#DV,2PS-S$R,2PS
> M-S$R,BPT,#DV,BPT,#DV,RPS-S4Q,"PT,#DV-"PS-C@V-RPS-C@V."PS,S0S
> M-"PS,S0S-RPS-#@U,"PS-#@U,BPS-#@U-2PS-#@U-BPS-S,W-RPS-S,W."PS
> M-S,W.2PS-S,X,"PS-S,X,2PS-S,X,BPS-S,X,RPS-S,X-"PS-S,X-2PS-S,X
> M-BPS-S,Y-BPT,30X,RPT,30X-"PT,30X-BPT,30X-RPT,30X."PT,30Y,BPT
> M,30Y,RPT,30Y-2PT,3<R."PT,3<R.2PT,3<S,"PT,3DX-2PT,3DX-BPT,3DX
> M-RPT,3DX."PT,3DX.2PT,3DY,"PT,3DY,2PT,3DY,BPT,3DY,RPT,3DY-"PT
> M,3DY-2PT,3DY-BPT,C`Q-BPP+#(L-"PU+#8L-RPX+#DL,3`L,3$L,3(L,3,L
> M,30L,34L,38L,3<L,3@L,C`L,C(L,C,L,C0L,C4L,C8L,C<L,C@L,S`[045#
> M,35&-#<Q0C$S-34Q-41%,S0U-C0W1#`X,4(S0S`B/B`\>&%P34TZ1&5R:79E
> M9$9R;VT@<W12968Z:6YS=&%N8V5)1#TB=75I9#HY130R.38S140W.#9%,#$Q
> M.3`P04$R,D,P.3$V1C0V0R(@<W12968Z9&]C=6UE;G1)1#TB=75I9#HY130R
> M.38S140W.#9%,#$Q.3`P04$R,D,P.3$V1C0V0R(O/B`\+W)D9CI$97-C<FEP
> M=&EO;CX@/"]R9&8Z4D1&/B`\+W@Z>&UP;65T83X@("`@("`@("`@("`@("`@
> M("`@("`@("`@("`@("`@("`@("`@("`@("`@("`@("`@("`@("`@("`@("`@
Re: PDF no wrapping in BIRT Report Designer 2.5.1 [message #674397 is a reply to message #674076] Thu, 26 May 2011 14:53 Go to previous messageGo to next message
Hello Jason,
Unfortunately I get the same results with the sample report.
Larry
xls:
index.php/fa/2858/0/
web:
index.php/fa/2857/0/
pdf:
index.php/fa/2859/0/
Re: PDF no wrapping in BIRT Report Designer 2.5.1 [message #674407 is a reply to message #674397] Thu, 26 May 2011 16:02 Go to previous messageGo to next message
I tried this with 2.6.2 and the results are much better.
Jason
Re: PDF no wrapping in BIRT Report Designer 2.5.1 [message #674413 is a reply to message #674407] Thu, 26 May 2011 16:32 Go to previous messageGo to next message
I see. The version of the facilities management software I'm writing these reports for is limited to BIRT 2.5.1, but we're going to upgrade that software to a newer version very soon, which is also supposed to have a later version of BIRT. So that's still good information to know.
Thanks for your replies, Jason! Smile
Re: PDF no wrapping in BIRT Report Designer 2.5.1 [message #674416 is a reply to message #674413] Thu, 26 May 2011 16:37 Go to previous message
Larry,
No problem. If you get a chance download the 2.6.2 build and see if it
meets your needs. If it does not you may need to log a bug. I just do
not want it to be an issue for you when you upgrade.
Jason
> Thanks for your replies, Jason! :)
Previous Topic:Exporting Table (dataset) to xls
Next Topic:store values ​​in a Data Set to another
Current Time: Sun Jul 27 08:19:20 EDT 2025
Powered by FUDForum. Page generated in 0.08895 seconds
