Home » Eclipse Projects » Rich Client Platform (RCP) » How to add a progress bar as a component in a view
How to add a progress bar as a component in a view [message #671956] Thu, 19 May 2011 08:58 Go to next message
hello,
i am new to eclipse rcp
I could declare a progress bar and add it to my view but i want to perform a task at background
can i know how to add a progress bar and set timer so that i could run a process at background of my application.
problem: progress bar implementation
Kind Regards,
raghav
Re: How to add a progress bar as a component in a view [message #671977 is a reply to message #671956] Thu, 19 May 2011 09:49 Go to previous messageGo to next message
In RCP you can use Jobs and the ProgressView and/or a ProgressMonitorDialog to run background tasks. But if you want to embed a progress bar, have a look at org.eclipse.jface.wizard.ProgressMonitorPart.
PW
Re: How to add a progress bar as a component in a view [message #673996 is a reply to message #671977] Wed, 25 May 2011 09:26 Go to previous messageGo to next message
hi
kindly can someone provide a snippet or a pseudo-code of adding a progress bar.upon button click i wish to show progress in a view and perform background operation.
Re: How to add a progress bar as a component in a view [message #674300 is a reply to message #673996] Thu, 26 May 2011 09:09 Go to previous messageGo to next message
We pointed you to code. What did you try? Did it work? What environment are you trying to host the progress bar in?
See http://wiki.eclipse.org/FAQ_How_do_I_find_a_particular_class_from_an_Eclipse_plug-in%3F to make sure you can see all the source code, and check for uses of that class.
PW
Re: How to add a progress bar as a component in a view [message #674556 is a reply to message #674300] Fri, 27 May 2011 06:59 Go to previous message
i resolved the problem i used a normal progress bar of org.eclipse.swt.widgets
thanks a lot
Previous Topic:how to open a new view and close existing view
Next Topic:Perspective is still visible even after uninstalling eclipse plugin
Current Time: Sun Aug 31 12:09:05 EDT 2025
Powered by FUDForum. Page generated in 0.04574 seconds
