getting exception on adding the Recommenders nature [message #674243] |
Thu, 26 May 2011 05:22  |
Hi there,
after yesterdays demoCamp in Walldorf i thought i'll give codeRecommenders a try.
So added the updatesite, installed (did not report any errors), restarted.
Now i tried to add the "Recommenders" nature to some projects. Sadly the result is the following:
An internal error occurred during: "Building workspace".
com.ibm.wala.util.debug.UnimplementedError
Any idea what i am missing?
Using Helios SR2, BuildID: 20110301-1815
Here's the stacktrace from the eclipse log:
!ENTRY org.eclipse.core.jobs 4 2 2011-05-26 11:13:34.703
!MESSAGE An internal error occurred during: "Building workspace".
!STACK 0
at com.ibm.wala.util.debug.Assertions.UNREACHABLE(Assertions.java:46)
at com.ibm.wala.util.io.FileProvider.filePathFromURL(FileProvider.java:313)
at com.ibm.wala.util.io.FileProvider.getFileFromPlugin(FileProvider.java:150)
at com.ibm.wala.util.config.AnalysisScopeReader.read(AnalysisScopeReader.java:65)
at com.ibm.wala.util.config.AnalysisScopeReader.readJavaScope(AnalysisScopeReader.java:53)
at org.eclipse.recommenders.internal.rcp.analysis.cp.EclipseProjectPath.toAnalysisScope(EclipseProjectPath.java:347)
at org.eclipse.recommenders.internal.rcp.analysis.cp.EclipseProjectPath.toAnalysisScope(EclipseProjectPath.java:390)
at org.eclipse.recommenders.internal.rcp.analysis.WalaClassHierarchyService.make(WalaClassHierarchyService.java:77)
at org.eclipse.recommenders.internal.rcp.analysis.WalaClassHierarchyService.getClassHierachy(WalaClassHierarchyService.java:127)
at org.eclipse.recommenders.internal.rcp.analysis.RecommendersBuilder.analyzeCompilationUnit(RecommendersBuilder.java:180)
at org.eclipse.recommenders.internal.rcp.analysis.RecommendersBuilder.access$0(RecommendersBuilder.java:179)
at org.eclipse.recommenders.internal.rcp.analysis.RecommendersBuilder$1.visit(RecommendersBuilder.java:131)
at org.eclipse.core.internal.resources.Resource$2.visit(Resource.java:112)
at org.eclipse.core.internal.resources.Resource$1.visitElement(Resource.java:64)
at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:82)
at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86)
at org.eclipse.core.internal.watson.ElementTreeIterator.iterate(ElementTreeIterator.java:127)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:74)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:110)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:94)
at org.eclipse.recommenders.internal.rcp.analysis.RecommendersBuilder.performFullBuild(RecommendersBuilder.java:126)
at org.eclipse.recommenders.internal.rcp.analysis.RecommendersBuilder.build(RecommendersBuilder.java:95)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:629)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:172)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:203)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:255)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:258)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:311)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:343)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:144)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:242)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
FUDForum. Page generated in 0.12724 seconds
