Home » Archived » B3 » B3 version for Eclipse 3.6.0
B3 version for Eclipse 3.6.0 [message #673988] Wed, 25 May 2011 08:34 Go to next message
I'm looking for a version of B3 (specifically: beelang, beelang.ui, build, core, util, backend, p2) for Eclipse 3.6.0 (the GA version, not SR1 or SR2).
I understand B3 is not distributed on an update site, so I must build it from source.
But I have found no tag or branch that seem to correspond to Eclipse 3.6.0 on the B3 svn.
Maybe I can checkout a specific revision. If so, which revision of B3 should I take in order to have a version that compiles with Eclipse 3.6.0 and is stable?
[Updated on: Wed, 25 May 2011 08:36] by Moderator
Re: B3 version for Eclipse 3.6.0 [message #674004 is a reply to message #673988] Wed, 25 May 2011 09:29 Go to previous message
The trunk is for 3.6.x and there are no other branches.
I guess you could say that the trunk is stable as there is no work going
on at the moment :)
- henrik
On 5/25/11 2:34 PM, Nicolas Bros wrote:
> SR1 or SR2).
> from source.
Previous Topic:Updated description for setting up development environment
Next Topic:example use of the p2 model in b3
Current Time: Sat Jul 26 00:40:13 EDT 2025
Powered by FUDForum. Page generated in 0.07146 seconds
