Home » Eclipse Projects » Virgo » java.lang.VerifyError and Virgo
java.lang.VerifyError and Virgo [message #671666] Wed, 18 May 2011 12:06 Go to next message
I'm developing a web application on Virgo that uses Spring Http converters. This causes the project to depend on Rome to produce RSS and ATOM feeds. Those dependencies are available in the EBR, so I think I'm good there. When I try to load my ATOM feed, I'm getting a java.lang.VerifyError for a method call inside a Rome class:
May 18, 2011 9:57:56 AM org.apache.catalina.core.StandardWrapperValve invoke
    SEVERE: Servlet.service() for servlet rest threw exception
    java.lang.VerifyError: (class: com/sun/syndication/io/impl/Atom10Generator, method: serializeEntry signature: (Lcom/sun/syndication/feed/atom/Entry;Ljava/io/Writer;)V) Incompatible argument to function
     java.lang.Class.forName0(Native Method)
     java.lang.Class.forName(Class.java:247)
     com.sun.syndication.io.impl.PluginManager.getClasses(PluginManager.java:136)
     com.sun.syndication.io.impl.PluginManager.loadPlugins(PluginManager.java:87)
     com.sun.syndication.io.impl.PluginManager.<init>(PluginManager.java:55)
     com.sun.syndication.io.impl.PluginManager.<init>(PluginManager.java:46)
     com.sun.syndication.io.impl.FeedGenerators.<init>(FeedGenerators.java:47)
     com.sun.syndication.io.WireFeedOutput.getFeedGenerators(WireFeedOutput.java:53)
     com.sun.syndication.io.WireFeedOutput.outputJDom(WireFeedOutput.java:262)
     com.sun.syndication.io.WireFeedOutput.output(WireFeedOutput.java:211)
     com.sun.syndication.io.WireFeedOutput.output(WireFeedOutput.java:190)
     org.springframework.http.converter.feed.AbstractWireFeedHttpMessageConverter.writeInternal(AbstractWireFeedHttpMessageConverter.java:95)
     org.springframework.http.converter.feed.AbstractWireFeedHttpMessageConverter.writeInternal(AbstractWireFeedHttpMessageConverter.java:1)
     org.springframework.http.converter.AbstractHttpMessageConverter.write(AbstractHttpMessageConverter.java:181)
     org.springframework.web.servlet.mvc.annotation.AnnotationMethodHandlerAdapter$ServletHandlerMethodInvoker.writeWithMessageConverters(AnnotationMethodHandlerAdapter.java:975)
     org.springframework.web.servlet.mvc.annotation.AnnotationMethodHandlerAdapter$ServletHandlerMethodInvoker.handleResponseBody(AnnotationMethodHandlerAdapter.java:933)
     org.springframework.web.servlet.mvc.annotation.AnnotationMethodHandlerAdapter$ServletHandlerMethodInvoker.getModelAndView(AnnotationMethodHandlerAdapter.java:882)
     org.springframework.web.servlet.mvc.annotation.AnnotationMethodHandlerAdapter.invokeHandlerMethod(AnnotationMethodHandlerAdapter.java:428)
     org.springframework.web.servlet.mvc.annotation.AnnotationMethodHandlerAdapter.handle(AnnotationMethodHandlerAdapter.java:414)
     org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:790)
     org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:719)
     org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:644)
     org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:549)
     javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
     javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
     org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
     org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
     org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
     org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
     org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
     org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
     org.eclipse.virgo.web.tomcat.ApplicationNameTrackingValve.invoke(ApplicationNameTrackingValve.java:29)
     org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:555)
     org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
     org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
     org.apache.coyote.http11.Http11NioProcessor.process(Http11NioProcessor.java:886)
     org.apache.coyote.http11.Http11NioProtocol$Http11ConnectionHandler.process(Http11NioProtocol.java:721)
     org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:2256)
     java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
     java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
     java.lang.Thread.run(Thread.java:680)
I'm really not sure what could be causing this, and everything I read about java.lang.VerifyError makes it seem like it may be hard to track down.
The following two lines from that trace are what is making me wonder if the problem has something to do with Virgo/OSGi:
only because every time I've seen problems related to Class.forName() it seems to be an OSGi related issue.
If you have any ideas what could possibly be going on here, I'd really appreciate your input.
Aaron
Re: java.lang.VerifyError and Virgo [message #673828 is a reply to message #671666] Tue, 24 May 2011 17:11 Go to previous messageGo to next message
Looks like a combination of ClassCast and Java late binding, but I cannot be 100% sure without debugging the code.
Perhaps you have the same class in two different bundles and this causes the issue to appear.
If you can check which loader is used to load com/sun/syndication/feed/atom/Entry or java/io/Writer this should shed some light on the root cause.
Re: java.lang.VerifyError and Virgo [message #673842 is a reply to message #673828] Tue, 24 May 2011 18:59 Go to previous message
Check your WAR's WEB-INF/lib and make sure you don't have any classes duplicated between the WAR and the non-WAR OSGI bundles you loaded in (for ROME).
Previous Topic:Class Cast Exception for same class
Next Topic:war works in Tomcat, fails in Virgo with "packageImports must not contain duplicate items"
Current Time: Sun Jul 27 07:34:26 EDT 2025
Powered by FUDForum. Page generated in 0.04346 seconds
