Home » Eclipse Projects » EclipseLink » EmbeddedObjects - fields not populated correctly(EmbeddedObjects - incorrect use of org.eclipse.persistence.internal.descriptors.PersistenceObjectAtt)
EmbeddedObjects - fields not populated correctly [message #670009] Thu, 12 May 2011 08:08 Go to next message
We have just moved over from toplink to eclipselink, and none of our embedded objects are being correctly populated on calls to em.find() (maybe others to). When debugging I can see that the correctly populated object has been returned from the db (and is in a cache?), but when building / copying/ cloning that object to return to the caller of em.find() it is failing to pull the value out of that object into the returned object. It appears that in here
(org.eclipse.persistence.internal.descriptors.PersistenceObjectAttributeAccessor.getAttributeValueFromObject(Object) ):
    public Object getAttributeValueFromObject(Object object) {
        return ((PersistenceObject)object)._persistence_get(this.attributeName);
the object passed in is the object containing the embedded object, yet this.attributeName is name of the field in the embedded object - in this case 'value' and returns null as there is no attribute named 'value' in the object passed in. I can only see that it would work if the embedded object itself was passed in, or if the attribute name was name of the embedded object.
in the calling method next down the stack frame the direct to field mapping is org.eclipse.persistence.mappings.DirectToFieldMapping[value- - >WSSDBA.WBR_USER.ACHOLLOOKUPONLY].
Something is not quite right with the weaving or something elseewhere, has anyone seen anything similar ?
Eclipselink 2.2.0.
I am trying to reproduce this is a standalone app/ ear but not having much look reproducing in such a scenario.
this	PersistenceObjectAttributeAccessor	PersistenceObjectAttributeAccessor  (id=4134)	PersistenceObjectAttributeAccessor	4134
	attributeField	Field	Field  (id=4156)	Field	4156
	attributeName	String	"value" (id=4096)	String	4096
	isReadOnly	boolean	false	boolean
	isWriteOnly	boolean	false	boolean
object	Object	User  (id=3760)	User	3760
	_persistence_fetchGroup	FetchGroup	null	null
	_persistence_inLiquidityGroup_vh	WeavedAttributeValueHolderInterface	ValueHolder  (id=3822)	ValueHolder	3822
	_persistence_listener	PropertyChangeListener	null	null
	_persistence_portfolio_vh	WeavedAttributeValueHolderInterface	ValueHolder  (id=3851)	ValueHolder	3851
	_persistence_primaryKey	Object	"WSS" (id=3852)	String	3852
	_persistence_session	Session	null	null
	_persistence_shouldRefreshFetchGroup	boolean	false	boolean
	acHolLookupOnly	JpaBoolean	JpaBoolean  (id=3853)	JpaBoolean	3853
		value	String	"0" (id=4172)	String	4172
	areaUnit	String	"0058" (id=3854)	String	3854
	aspClientId	int	0	int
	bankManager	JpaBoolean	JpaBoolean  (id=3855)	JpaBoolean	3855
	city	String	"ZAOPS" (id=3856)	String	3856
	cityUnit	String	"0054" (id=3857)	String	3857
	cmAllowCpwAdjustments	JpaBoolean	JpaBoolean  (id=3858)	JpaBoolean	3858
	cmAllowOverrideExtBals	JpaBoolean	JpaBoolean  (id=3859)	JpaBoolean	3859
	cmAllowOverrideWssBals	JpaBoolean	JpaBoolean  (id=3860)	JpaBoolean	3860
	cmCashAdjusmentsToBeReviewed	JpaBoolean	JpaBoolean  (id=3861)	JpaBoolean	3861
	cmTargetBalancingToBeReviewed	JpaBoolean	JpaBoolean  (id=3862)
Daemon Thread [p: thread-pool-1; w: 93] (Suspended (breakpoint at line 30 in PersistenceObjectAttributeAccessor))
	PersistenceObjectAttributeAccessor.getAttributeValueFromObject(Object) line: 30
	DirectToFieldMapping(DatabaseMapping).getAttributeValueFromObject(Object) line: 523
	DirectToFieldMapping(AbstractDirectMapping).valueFromRow(AbstractRecord, JoinedAttributeManager, ObjectBuildingQuery, CacheKey, AbstractSession, boolean) line: 1273
	DirectToFieldMapping(DatabaseMapping).readFromRowIntoObject(AbstractRecord, JoinedAttributeManager, Object, CacheKey, ObjectBuildingQuery, AbstractSession, boolean) line: 1325
	ObjectBuilder.buildAttributesIntoObject(Object, CacheKey, AbstractRecord, ObjectBuildingQuery, JoinedAttributeManager, boolean, AbstractSession) line: 344
	AggregateObjectMapping.buildAggregateFromRow(AbstractRecord, Object, CacheKey, JoinedAttributeManager, ObjectBuildingQuery, boolean, AbstractSession, boolean) line: 362
	AggregateObjectMapping.readFromRowIntoObject(AbstractRecord, JoinedAttributeManager, Object, CacheKey, ObjectBuildingQuery, AbstractSession, boolean) line: 1415
	ObjectBuilder.buildProtectedObject(boolean, ObjectBuildingQuery, AbstractRecord, AbstractSession, Object, ClassDescriptor, JoinedAttributeManager) line: 821
	ObjectBuilder.buildObject(boolean, ObjectBuildingQuery, AbstractRecord, AbstractSession, Object, ClassDescriptor, JoinedAttributeManager) line: 657
	ObjectBuilder.buildWorkingCopyCloneNormally(ObjectBuildingQuery, AbstractRecord, UnitOfWorkImpl, Object, ClassDescriptor, JoinedAttributeManager) line: 612
	ObjectBuilder.buildObjectInUnitOfWork(ObjectBuildingQuery, JoinedAttributeManager, AbstractRecord, UnitOfWorkImpl, Object, ClassDescriptor) line: 565
	ObjectBuilder.buildObject(ObjectBuildingQuery, AbstractRecord, JoinedAttributeManager) line: 497
	ObjectBuilder.buildObject(ObjectLevelReadQuery, AbstractRecord) line: 456
	ReadObjectQuery(ObjectLevelReadQuery).buildObject(AbstractRecord) line: 723
	ReadObjectQuery.registerResultInUnitOfWork(Object, UnitOfWorkImpl, AbstractRecord, boolean) line: 766
	ReadObjectQuery.executeObjectLevelReadQuery() line: 451
	ReadObjectQuery(ObjectLevelReadQuery).executeDatabaseQuery() line: 1080
	ReadObjectQuery(DatabaseQuery).execute(AbstractSession, AbstractRecord) line: 808
	ReadObjectQuery(ObjectLevelReadQuery).execute(AbstractSession, AbstractRecord) line: 1040
	ReadObjectQuery.execute(AbstractSession, AbstractRecord) line: 412
	ReadObjectQuery(ObjectLevelReadQuery).executeInUnitOfWork(UnitOfWorkImpl, AbstractRecord) line: 1126
	RepeatableWriteUnitOfWork(UnitOfWorkImpl).internalExecuteQuery(DatabaseQuery, AbstractRecord) line: 2842
	RepeatableWriteUnitOfWork(AbstractSession).executeQuery(DatabaseQuery, AbstractRecord, int) line: 1521
	RepeatableWriteUnitOfWork(AbstractSession).executeQuery(DatabaseQuery, AbstractRecord) line: 1503
	RepeatableWriteUnitOfWork(AbstractSession).executeQuery(DatabaseQuery) line: 1463
	EntityManagerImpl.executeQuery(ReadObjectQuery, LockModeType, AbstractSession) line: 781
	EntityManagerImpl.findInternal(ClassDescriptor, AbstractSession, Object, LockModeType, Map<String,Object>) line: 725
	EntityManagerImpl.find(Class<T>, Object, LockModeType, Map<String,Object>) line: 619
	EntityManagerImpl.find(Class<T>, Object) line: 498
	EntityManagerWrapper.find(Class<T>, Object) line: 291
	UserServiceEJB.getUserFullWithLazyProps(String, EnumSet<EnumUserLazyProps>) line: 104
	NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not available [native method]
	NativeMethodAccessorImpl.invoke(Object, Object[]) line: 39
	DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 25
	Method.invoke(Object, Object...) line: 597
	EJBSecurityManager.runMethod(Method, Object, Object[]) line: 1011
	SecurityUtil.invoke(Method, Invocation, Object, Object[], Container, SecurityManager) line: 175
	StatelessSessionContainer(BaseContainer).invokeTargetBeanMethod(Method, Invocation, Object, Object[], SecurityManager) line: 2929
	StatelessSessionContainer(BaseContainer).intercept(Invocation) line: 4020
	EJBObjectInvocationHandler.invoke(Class, Method, Object[]) line: 203
	EJBObjectInvocationHandlerDelegate.invoke(Object, Method, Object[]) line: 77
	$Proxy1079.getUserFullWithLazyProps(String, EnumSet) line: not available
	ReflectiveTie._invoke(String, InputStream, ResponseHandler) line: 154
	CorbaServerRequestDispatcherImpl.dispatchToServant(Object, CorbaMessageMediator, byte[], ObjectAdapter) line: 687
	CorbaServerRequestDispatcherImpl.dispatch(MessageMediator) line: 227
	CorbaMessageMediatorImpl.handleRequestRequest(CorbaMessageMediator) line: 1846
	CorbaMessageMediatorImpl.handleRequest(RequestMessage, CorbaMessageMediator) line: 1706
	CorbaMessageMediatorImpl.handleInput(RequestMessage_1_2) line: 1088
	RequestMessage_1_2.callback(MessageHandler) line: 223
	CorbaMessageMediatorImpl.handleRequest(MessageMediator) line: 806
	CorbaMessageMediatorImpl.dispatch() line: 563
	CorbaMessageMediatorImpl.doWork() line: 2567
	ThreadPoolImpl$WorkerThread.run() line: 555
index.php/fa/2724/0/index.php/fa/2724/0/
  • Attachment: el_vars.JPG
    (Size: 290.48KB, Downloaded 492 times)
Re: EmbeddedObjects - fields not populated correctly [message #670010 is a reply to message #670009] Thu, 12 May 2011 08:11 Go to previous messageGo to next message
the resulting object from em.find() is as below - where the embedded object has a value field of null instead of "0" as in the object shown above
user	User	User  (id=5028)	User	5028
	_persistence_inLiquidityGroup_vh	WeavedAttributeValueHolderInterface	UnitOfWorkQueryValueHolder  (id=5033)	UnitOfWorkQueryValueHolder	5033
	_persistence_listener	PropertyChangeListener	AttributeChangeListener  (id=5037)	AttributeChangeListener	5037
	_persistence_portfolio_vh	WeavedAttributeValueHolderInterface	UnitOfWorkQueryValueHolder  (id=5040)	UnitOfWorkQueryValueHolder	5040
	acHolLookupOnly	JpaBoolean	JpaBoolean  (id=5042)	JpaBoolean	5042
		_persistence_listener	PropertyChangeListener	AggregateAttributeChangeListener  (id=5052)	AggregateAttributeChangeListener	5052
		value	String	null	null
	bankManager	JpaBoolean	JpaBoolean  (id=5043)	JpaBoolean	5043
Re: EmbeddedObjects - fields not populated correctly [message #670056 is a reply to message #670010] Thu, 12 May 2011 10:12 Go to previous messageGo to next message
Can you include how you have mapped one of the classes that is not working.
Can you try disabling weaving, or just disabling internal weaving and confirm if the errors still occurs.
Also try the latest 2.3 build to see if the issue may have been resolved.
"eclipselink.weaving"="false"
or,
"eclipselink.internal.weaving"="false"
Re: EmbeddedObjects - fields not populated correctly [message #670064 is a reply to message #670056] Thu, 12 May 2011 10:50 Go to previous messageGo to next message
I'll try without the weaving / newer version of eclipselink in while, prob next week...
in the meantime :
the mapped superclass at the top of the heirarchy
@MappedSuperclass
public class UserTahoe extends TahoeEntity implements CloneAccessor,  Serializable{
    private static final long serialVersionUID = 3875580327768987028L;
    @Transient
    private String oprIDTransient;
etc
    private String areaUnit = " ";
    @ManyToOne(fetch=FetchType.LAZY)
    @JoinColumn(name="PORTFOLIO",insertable=false,updatable=false)
    private Portfolio portfolio;
    @Column(name="PORTFOLIO")
    private String portfolioId ;
etc
    @Embedded
    @AttributeOverride(name="value", column=@Column(name="ACHOLLOOKUPONLY"))
    private JpaBoolean acHolLookupOnly = new JpaBoolean(false) ;
    @Embedded
    @AttributeOverride(name="value", column=@Column(name="SUPERVISOR"))
    private JpaBoolean supervisor = new JpaBoolean(false) ;
    @Embedded
    @AttributeOverride(name="value", column=@Column(name="BANKMANAGER"))
    private JpaBoolean bankManager = new JpaBoolean(false) ;
the @Entity itself
@Entity
@Table(name="WBR_USER")
public class User extends UserTahoe implements  Serializable,   LiveFieldAccess, StatusFieldAccess {
etc
the embedded object
@Embeddable
public class JpaBoolean   implements Serializable  {
    private static final long serialVersionUID = -8018836031372234990L ;
    /** Value for use in query parameters to match true */
    public static final String TRUE = "1";
    /** Value for use in query parameters to match false */
    public static final String FALSE = "0";
    private String value;
Re: EmbeddedObjects - fields not populated correctly [message #671030 is a reply to message #670064] Mon, 16 May 2011 11:15 Go to previous messageGo to next message
If you can isolate a test, and it fails in the latest version please log a bug.
Note, that you could just use Boolean instead of JpaBoolean, and use a Converter to map it to a string, (or even use JpaBoolean through a converter instead of embeddable).
Re: EmbeddedObjects - fields not populated correctly [message #671510 is a reply to message #671030] Wed, 18 May 2011 03:29 Go to previous messageGo to next message
we could do, but we wrapped it in an embedded object some time ago to make it a bit easier to deal with different jpa providers/ databases. NB, it's not just this embeddable that is failing but all embeddables... Anyway I'm back on this today so will crack on and see what I can get....
Re: EmbeddedObjects - fields not populated correctly [message #671556 is a reply to message #671510] Wed, 18 May 2011 06:01 Go to previous messageGo to next message
Ok - still on 2.2 at moment - same behavour with static/dynamic weaving- with weaving turned off altogether though an exception is thrown as below. Now to try latest eclipselink
[#|2011-05-18T09:56:39.237+0000|WARNING|sun-appserver2 .1|org.eclipse.persistence.session.file:/rndvm/java/domainRN DVM/applications/j2ee-apps/Bedrock-ot-norcp-gf211-el220-DEV- r000000-20110518-102934/Bedrock.server.services.local_jar/_W SSJPA|_ThreadID=14;_ThreadName=p: thread-pool-1; w: 5;_RequestID=e97976eb-5cce-4f64-be0d-be09047da258;|
Local Exception Stack:
Exception [EclipseLink-26] (Eclipse Persistence Services - 2.2.0.v20110202-r8913): org.eclipse.persistence.exceptions.DescriptorException
Exception Description: Trying to get value for instance variable [value] of type [java.lang.String] from the object [biz.wss.interfaces.entities.user.User].  The specified object is not an instance of the class or interface declaring the underlying field.
Internal Exception: java.lang.IllegalArgumentException: Can not set java.lang.String field biz.wss.interfaces.entities.jpa.JpaBoolean.value to biz.wss.interfaces.entities.user.User
Mapping:  org.eclipse.persistence.mappings.DirectToFieldMapping[value- - >WSSDBA.WBR_USER.ACHOLLOOKUPONLY]
Descriptor:  RelationalDescriptor(biz.wss.interfaces.entities.jpa.JpaBool ean --> [DatabaseTable(WSSDBA.WBR_USER)])
        at  org.eclipse.persistence.exceptions.DescriptorException.illeg alArgumentWhileGettingValueThruInstanceVariableAccessor(Desc riptorException.java:645)
        at  org.eclipse.persistence.internal.descriptors.InstanceVariabl eAttributeAccessor.getAttributeValueFromObject(InstanceVaria bleAttributeAccessor.java:79)
        at  org.eclipse.persistence.mappings.DatabaseMapping.getAttribut eValueFromObject(DatabaseMapping.java:523)
        at  org.eclipse.persistence.mappings.foundation.AbstractDirectMa pping.valueFromRow(AbstractDirectMapping.java:1273)
        at  org.eclipse.persistence.mappings.DatabaseMapping.readFromRow IntoObject(DatabaseMapping.java:1325)
        at  org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildAttributesIntoObject(ObjectBuilder.java:344)
        at  org.eclipse.persistence.mappings.AggregateObjectMapping.buil dAggregateFromRow(AggregateObjectMapping.java:362)
        at  org.eclipse.persistence.mappings.AggregateObjectMapping.read FromRowIntoObject(AggregateObjectMapping.java:1415)
        at  org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildProtectedObject(ObjectBuilder.java:821)
        at  org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildObject(ObjectBuilder.java:657)
        at  org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildWorkingCopyCloneNormally(ObjectBuilder.java:612)
        at  org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildObjectInUnitOfWork(ObjectBuilder.java:565)
        at  org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildObject(ObjectBuilder.java:497)
        at  org.eclipse.persistence.internal.descriptors.ObjectBuilder.b uildObject(ObjectBuilder.java:456)
        at  org.eclipse.persistence.queries.ObjectLevelReadQuery.buildOb ject(ObjectLevelReadQuery.java:723)
        at  org.eclipse.persistence.queries.ReadObjectQuery.registerResu ltInUnitOfWork(ReadObjectQuery.java:766)
        at  org.eclipse.persistence.queries.ReadObjectQuery.executeObjec tLevelReadQuery(ReadObjectQuery.java:451)
        at  org.eclipse.persistence.queries.ObjectLevelReadQuery.execute DatabaseQuery(ObjectLevelReadQuery.java:1080)
        at  org.eclipse.persistence.queries.DatabaseQuery.execute(Databa seQuery.java:808)
        at  org.eclipse.persistence.queries.ObjectLevelReadQuery.execute (ObjectLevelReadQuery.java:1040)
        at  org.eclipse.persistence.queries.ReadObjectQuery.execute(Read ObjectQuery.java:412)
        at  org.eclipse.persistence.queries.ObjectLevelReadQuery.execute InUnitOfWork(ObjectLevelReadQuery.java:1126)
        at  org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.int ernalExecuteQuery(UnitOfWorkImpl.java:2842)
        at  org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1521)
        at  org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1503)
        at  org.eclipse.persistence.internal.sessions.AbstractSession.ex ecuteQuery(AbstractSession.java:1463)
        at  org.eclipse.persistence.internal.jpa.EntityManagerImpl.execu teQuery(EntityManagerImpl.java:781)
        at  org.eclipse.persistence.internal.jpa.EntityManagerImpl.findI nternal(EntityManagerImpl.java:725)
        at  org.eclipse.persistence.internal.jpa.EntityManagerImpl.find( EntityManagerImpl.java:619)
        at  org.eclipse.persistence.internal.jpa.EntityManagerImpl.find( EntityManagerImpl.java:498)
        at  com.sun.enterprise.util.EntityManagerWrapper.find(EntityMana gerWrapper.java:291)
        at  biz.wss.server.services.local.user.UserServiceEJB.getUserFul lWithLazyProps(UserServiceEJB.java:104)
[Updated on: Wed, 18 May 2011 06:23] by Moderator
Re: EmbeddedObjects - fields not populated correctly [message #671630 is a reply to message #671556] Wed, 18 May 2011 10:21 Go to previous messageGo to next message
cant replicate in separate project at moment - guess I have to make effort and move all 800 or so entities from real project into the test one, will take some time though so no one hold their breath....
Re: EmbeddedObjects - fields not populated correctly [message #671684 is a reply to message #671630] Wed, 18 May 2011 12:56 Go to previous messageGo to next message
still no luck - could it be be down to transactions (inside/ outside of) or caching in some way ?
Re: EmbeddedObjects - fields not populated correctly [message #671940 is a reply to message #671684] Thu, 19 May 2011 07:59 Go to previous messageGo to next message
My guess is it is probably related to caching or your usage of your objects in your persistence context.
You could try disabling caching by setting shared to false, to see if that is related.
Also ensure you are not reusing the same aggregate for many owners, and ensure you are not mixing managed and detached objects in the same transaction.
Re: EmbeddedObjects - fields not populated correctly [message #673603 is a reply to message #671940] Tue, 24 May 2011 04:36 Go to previous messageGo to next message
Yeap - this is down to caching somehow - if I comment out all eclipselink.cache.shared.entityName=false properties in the persistence.xml then all is well, if I put the property back in for an entity that has no embedded objects in then it is still ok, as soon as I put the property back for an entity with an embedded object referenced somewhere in that class/ superclass/ referenced class then it fails for everything that also has a reference to that same type of embedded object. BUT cant reproduce in a standalone ear no matter how hard i try...... same occurs in 2.2.0-rc3, 2.2.0, 2.3.0-rc1. The exact same thing under toplink has no issues. We must have some odd config somewhere
Re: EmbeddedObjects - fields not populated correctly [message #673747 is a reply to message #673603] Tue, 24 May 2011 11:45 Go to previous messageGo to next message
Are you mixing shared and none shared cached objects? i.e. do you have a reference from a shared cache object to a shared=false object?
This could be an issue with our new protected cache support in 2.2. Please log a bug for the issue with as much details as you have.
Can you try the 2.1 release, does it work in that version?
Does it work with the shared cache off for everything?
Re: EmbeddedObjects - fields not populated correctly [message #673999 is a reply to message #673747] Wed, 25 May 2011 09:32 Go to previous messageGo to next message
yeap - that's it - if I have just
<property name="eclipselink.cache.shared.Country" value="false"/>
then it fails , if I have
<property name="eclipselink.cache.shared.default" value="false"/>
<property name="eclipselink.cache.shared.Country" value="false"/> <--- redundant
then'its ok - ie the same as if no eclipselink.cache.shared.EntityName=false entries
will try with the different versions and file a bug report with a matrix on how it behaves...
Re: EmbeddedObjects - fields not populated correctly [message #674026 is a reply to message #673999] Wed, 25 May 2011 10:55 Go to previous message
see https://bugs.eclipse.org/bugs/show_bug.cgi?id=347168
Previous Topic:Passing parameters to be used in Customizer
Next Topic:Eclipselink cache coordination throwing NoClassDefFoundError
Current Time: Wed Nov 05 09:37:58 EST 2025
Powered by FUDForum. Page generated in 0.06745 seconds
