Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Can Acceleo do something like JET's c:dump
[Acceleo] Can Acceleo do something like JET's c:dump [message #672255] Fri, 20 May 2011 09:11 Go to next message
I'm an Acceleo noob. I'm looking to use it as a replacement for some of our simpler JET templates to get a feel for the language/environment.
My question is can Acceleo do something similar to the JET c:dump whereby on a template match the exact input and its contents can be transferred to the output. My use case is an Ecore/XML model is the input and I want todo some minor manipulations on the outer most element before directly copying the inner contents to the output text model. This is quite easy in JET.
I see Acceleo supports "Generation Patterns" but this isn't exactly what I had in mind as this exposes all my metamodel to the M2T transform making maintenance an issue.
Thanks!
Ronan
Re: [Acceleo] Can Acceleo do something like JET's c:dump [message #673299 is a reply to message #672255] Mon, 23 May 2011 03:30 Go to previous messageGo to next message
Hi Ronan,
Acceleo does not have something similar to the JET c:dump, you could always try to use some Java services to get the content of the XML of your model but since they are no equivalent in Acceleo, you won't find a "nice" solution to this very specific problem.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Acceleo wiki: http://wiki.eclipse.org/Acceleo
Blogs: http://stephanebegaudeau.tumblr.com & http://sbegaudeau.tumblr.com
Re: [Acceleo] Can Acceleo do something like JET's c:dump [message #673323 is a reply to message #673299] Mon, 23 May 2011 04:59 Go to previous message
Hi Stephane,
Aha I see! I have tried that out now.
Thanks!
Ronan
Previous Topic:Acceleo 3.x - differences between ant task launcher and acceleo launcher
Next Topic:Extending the given function operators for Acceleo
Current Time: Fri Jul 25 06:53:53 EDT 2025
Powered by FUDForum. Page generated in 0.03849 seconds
