Home » Language IDEs » PHP Development Tools (PDT) » Code comments broken ?
Code comments broken ? [message #657117] Tue, 01 March 2011 11:08 Go to next message
I've downloaded a fresh release of eclipse, then updated it using the build in update tool to version:
Eclipse IDE for PHP Developers 1.3.1.20100916-1202
After the upgrade, I'm unable to comment block of code, using menu or keyboard shortcut.
I'm on mac, using 64 bit version.
Anyone else experienced this problem ?
Is there a way to fix it ?
Re: Code comments broken ? [message #657417 is a reply to message #657117] Wed, 02 March 2011 12:39 Go to previous messageGo to next message
Originally posted by: ng.tomo.at
yes, toggle comments is broken on windows too:
Eclipse IDE for PHP Developers 1.3.2.20110301-1807
Eclipse Platform 3.6.2.M20110210-1200
EPP PHP Feature 1.3.2.20110301-1807
Error Log does not show any errors.
Am 01.03.2011 17:08, schrieb Tomasz Rakowski:
> keyboard shortcut.
> Thanks
Re: Code comments broken ? [message #658834 is a reply to message #657417] Wed, 09 March 2011 18:24 Go to previous messageGo to next message
Sigh, I just updated to fix the compare editor not working bug and now Rolling Eyes . Oh well, yucky /* */ comments here I come Smile
If anyone finds a fix, that'd be lovely.
Re: Code comments broken ? [message #658837 is a reply to message #658834] Wed, 09 March 2011 18:38 Go to previous messageGo to next message
see this post: news://news.eclipse.org:119/ikhfao$fsb$1@news.eclipse.org
download url is http://sourceforge.jp/projects/pdt-tools/releases/51060
Am 01.03.2011 01:47, schrieb Toshihiro Izumi:
> I noticed another issue...
> Toggle Comment, Add/Remove Block Comment, they don't work in PHP Editor.
> I added bug fixed plugin org.eclipse.php.ui_2.2.1.v20101001-2300.jar.
> Try it when you were blown down by this malfunction.
Am 10.03.2011 00:24, schrieb Toby Lieven:
> :roll: . Oh well, yucky /* */ comments here I come :)
icon10.gif  Re: Code comments broken ? [message #673234 is a reply to message #658837] Sun, 22 May 2011 20:11 Go to previous messageGo to next message
I tried the listed repair and it worked perfectly. I can now toggle comments on the selected text using the [Source->Toggle Comments] menu item in Eclipse PDT. I can also toggle comments using Ctrl + /
I have updated the entire Eclipse PDT program earlier this year.
I have noticed this problem many many times.
The system I have is: Windows XP Home Edition on a Celeron CPU.
Here is what I did:
1) I went to the url listed in the message I am replying to. I can describe the
url as follows: It is at source forge dot jp projects pdt-tools releases 51060
At this url I left clicked the php ui jar file as
this filename: org.eclipse.php.ui_2.2.1.v20101001-2300.jar and saved the file
to my hard disk.
2) I moved the original file with the same name from the following location:
C:\Program Files\eclipse\plugins
to a different location on my hard disk for safe keeping
(although I did not need this file ever again).
3) I copied the download jar file to C:\Program Files\eclipse\plugins.
4) I opened up a command prompt window and typed the following:
C:\>cd\Program Files
C:\>cd eclipse
C:\>eclipse -clean
Now it is fixed and working perfect. Such a beautiful solution, I just wanted
a nice description for others. Thanks everyone for this wonderful solution.
Re: Code comments broken ? [message #725887 is a reply to message #673234] Fri, 16 September 2011 01:31 Go to previous message
it worked for me!
Previous Topic:UTF-8 - without BOM
Next Topic:CSS code editor assist suggest not working
Current Time: Sat Jul 26 02:49:55 EDT 2025
Powered by FUDForum. Page generated in 0.06836 seconds
