Home » Language IDEs » PHP Development Tools (PDT) » No folding, no code completion... this used to work... what happened?
No folding, no code completion... this used to work... what happened? [message #67205] Fri, 14 March 2008 16:35 Go to next message
Originally posted by: jacob.datajoe.com
A while back my folding and code completion just stopped working for
some unexplainable reason... I have folding enabled everywhere... I have
code completion enabled... My partner is using the same environment as I
am and his is working fine... Please help... I don't even know where to
go from here!
Re: No folding, no code completion... this used to work... what happened? [message #67235 is a reply to message #67205] Sat, 15 March 2008 01:47 Go to previous messageGo to next message
Hello Jacob !
I have this problem due damaged ".project" file.
Copy "...workspace/project_name/.project" file from your partner and
restart PDT for testing...
Boyd
Em Fri, 14 Mar 2008 14:35:48 -0600
Jacob Fogg <jacob@datajoe.com> escreveu:
> go from here!
Re: No folding, no code completion... this used to work... what happened? [message #67304 is a reply to message #67235] Mon, 17 March 2008 11:46 Go to previous messageGo to next message
You are the MAN! If you were anywhere close by, I'd come over and take
you out to lunch!
Thanks!
Jacob
J. A. Boyd wrote:
> Hello Jacob !
> Boyd
>> go from here!
How does PDT corrupt .project files? (was Re: No folding, no code completion... this used to work... [message #69637 is a reply to message #67304] Tue, 29 April 2008 14:11 Go to previous message
Originally posted by: codeslave.ca.ibm.com
How does a .project file get damaged, anyway? I've been using Eclipse
for 4 years and I've never seen that happen. (But I stopped using PDT a
while ago and switched back to PHPeclipse, so maybe that's why.)
What is PDT doing with .project files that they can get corrupt? Isn't
that more-or-less static information that's only ever written to once in
a blue moon if you add a new nature or builder, create the project in
the first place, or import it from some source where it doesn't already
exist?
BTW, there's also this hack if you need to shoehorn an existing project
to work w/ PDT:
http://wiki.eclipse.org/IRC_FAQ#How_do_I_manually_assign_a_p roject_Nature_or_BuildCommand.3F
Nick
> you out to lunch!
> Thanks!
> Jacob
> J. A. Boyd wrote:
>> Hello Jacob !
>> Boyd
>>> have code completion enabled... My partner is using the same
>>> environment as I am and his is working fine... Please help... I
>>> don't even know where to go from here!
Previous Topic:PDT dependecies
Next Topic:PDT falling behind on purpose?
Current Time: Fri Oct 24 10:21:48 EDT 2025
Powered by FUDForum. Page generated in 0.04350 seconds
