JDK 7 support in eclipse 3.7 available? [message #667702] |
Sun, 01 May 2011 10:28  |
is eclipse 3.7 supposed to support JDK 1.7 or not?
I am confused because I can set in the Project the JDK Compliance level
to 1.7 making me think it is supported, but on the other hand when I
click on the checkbox next to "Use compliance from execution environment
'JavaSE-1.7' on the Java Build Path" it says "The 1.7 compiler
compliance level is not yet supported.
BTW the reason I am asking is that I tried to use a switch with a string
argument and even when compiler compliance is set to 1.7 it is marked as
an error and I wonder if I shall file a bug report or not.
claudio
(no subject) [message #672964 is a reply to message #668864] |
Sun, 22 May 2011 09:02  |
> > Project Properties->Java Compiler
> > where you can select 1.7.
> No, you cannot set 1.7 as the compliance level even in project specific
> settings. (I just verified this)
I see it now. I still have 1.7 visible because I operate on a project
for which I had set 1.7 in an earlier version of eclipse. When I create
a new project the highest I can set is indeed 1.6.
Also once I change my old project to 1.6 and apply the change, changing
back to 1.7 is not possible anymore. So I saw it only because my project
still was set to 1.7.
Sorry for causing confusion,
claudio
(no subject) [message #672966 is a reply to message #668864] |
claudio
(no subject) [message #672971 is a reply to message #668864] |
claudio
(no subject) [message #672992 is a reply to message #668864] |
claudio
(no subject) [message #673040 is a reply to message #668864] |
claudio
(no subject) [message #673063 is a reply to message #668864] |
claudio
(no subject) [message #673140 is a reply to message #668864] |
claudio
(no subject) [message #673146 is a reply to message #668864] |
claudio
FUDForum. Page generated in 0.21041 seconds
