Class diagram observations [message #671333] |
Tue, 17 May 2011 10:43  |
Here are some more observations and possible bugs I have found when using the class diagrams. Is anyone else seeing this?
I have the Papyrus persective open with the Properties view below the class diagram.
Initially "<Model> model" is shown in the Properties view.
I created a new class in a blank diagram and dropped a couple of properties into the AttributeComnpartment so I have Property0, Property1 and Property2 in order.
As I said in an earlier post I cannot type in the Edit Label otherwise Eclipse locks up so I need to use the Property editor. So I left click on the class which bolds the outline and then right click to bring up the context menu and select "Show Properties View". Nothing happens. This might be expected since the Properties view is already displayed but if that is true, then the class properties should be displayed as soon as I select it. Now if I left click on the diagram background, the class properties are displayed. Since I cannot find any documentation, I'm not exactly sure how this is supposed to work but the way it is now is not intuitive.
Now that I have the class properties displayed, I go to the OwnedAttribute window, select Property2 and click the edit button. This brings up a dialog improperly titled "Create a new Element". I change the attribute name to abc and click OK. (As an aside, the Cancel but is greyed out. Why?) The dialog disappears and the attribute name is changed in the diagram but it still has the original name in the Properties view.
Now I use the up arrow in the OwnedAttribute window to move Property2 (which should be called abc) to the top of the list. Each click of the button moves Property2 up the list 1 place but the attributes in the class diagram never move. When Property2 is moved up the fist time its name changes to abc.
There appears to be some basic update problem.
This is using v0.8.0 of Papyrus with Eclipse SDK3.7.0 on a Windows Vista platform.
FUDForum. Page generated in 0.04578 seconds
