Home » Eclipse Projects » Remote Application Platform (RAP) » Problem with progress monitor
Problem with progress monitor [message #672214] Fri, 20 May 2011 06:48 Go to next message
Hi all,
I m developing a rap application and running it through jboss5,
I call a service from Jboss which takes time to populate data in rap ui.and i m running this service in same thread.and i dont want to use progress monitor as it creates a new thread so to show long operations is there any way apart from progress monitor?
I would appreciate any feedback
Thanks in advace:)
Re: Problem with progress monitor [message #672806 is a reply to message #672214] Sun, 22 May 2011 06:28 Go to previous messageGo to next message
> I m developing a rap application and running it through jboss5, I call a
I suppose with "same thread" you mean the UIThread, right?
If you run long-running code in the UI Thread, the request is blocked and
UI cannot be updated. If you want to run long running code in the
background, i.e. while the UI is still responsive, I'm afraid there is no
alternative to a background thread.
I think the best solution to this problem would be to call remote methods
asynchronously, i.e. with a callback that is notified when the work is
finished. But not sure if this is possible with your backend.
Regards, Ralf
Ralf Sternberg
Twitter: @EclipseRAP
Re: Problem with progress monitor [message #672809 is a reply to message #672214] Sun, 22 May 2011 06:28 Go to previous messageGo to next message
Regards, Ralf
Ralf Sternberg
Re: Problem with progress monitor [message #672854 is a reply to message #672214] Sun, 22 May 2011 06:28 Go to previous messageGo to next message
Regards, Ralf
Ralf Sternberg
Re: Problem with progress monitor [message #672859 is a reply to message #672214] Sun, 22 May 2011 06:28 Go to previous messageGo to next message
Regards, Ralf
Ralf Sternberg
Re: Problem with progress monitor [message #672875 is a reply to message #672214] Sun, 22 May 2011 06:28 Go to previous messageGo to next message
Regards, Ralf
Ralf Sternberg
Re: Problem with progress monitor [message #672882 is a reply to message #672214] Sun, 22 May 2011 06:28 Go to previous messageGo to next message
Regards, Ralf
Ralf Sternberg
Re: Problem with progress monitor [message #672910 is a reply to message #672214] Sun, 22 May 2011 06:28 Go to previous messageGo to next message
Regards, Ralf
Ralf Sternberg
Re: Problem with progress monitor [message #672945 is a reply to message #672214] Sun, 22 May 2011 06:28 Go to previous messageGo to next message
Regards, Ralf
Ralf Sternberg
Re: Problem with progress monitor [message #672953 is a reply to message #672214] Sun, 22 May 2011 06:28 Go to previous messageGo to next message
Regards, Ralf
Ralf Sternberg
Re: Problem with progress monitor [message #673050 is a reply to message #672214] Sun, 22 May 2011 06:28 Go to previous messageGo to next message
Regards, Ralf
Ralf Sternberg
Re: Problem with progress monitor [message #673056 is a reply to message #672214] Sun, 22 May 2011 06:28 Go to previous messageGo to next message
Regards, Ralf
Ralf Sternberg
Re: Problem with progress monitor [message #673070 is a reply to message #672214] Sun, 22 May 2011 06:28 Go to previous messageGo to next message
Regards, Ralf
Ralf Sternberg
Re: Problem with progress monitor [message #673125 is a reply to message #672214] Sun, 22 May 2011 06:28 Go to previous messageGo to next message
Regards, Ralf
Ralf Sternberg
Re: Problem with progress monitor [message #674179 is a reply to message #672806] Wed, 25 May 2011 23:19 Go to previous message
Hi Ralf,
Thanks for your response
Can u please elabrote it with an example?
Previous Topic:Non-serializable attribute org.eclipse.rwt.internal.service.SessionStoreImpl
Next Topic:Integration of custom widgets in existing application
Current Time: Mon Sep 15 11:15:58 EDT 2025
Powered by FUDForum. Page generated in 0.06418 seconds
