Home » Archived » Test and Performance Tools Platform (TPTP) » AGR problems with Search dialog
AGR problems with Search dialog [message #67220] Thu, 20 April 2006 15:16 Go to next message
Originally posted by: aaijaz.parasoft.com
Hello All,
I am using TPTP 4.2 I2 stable build.
I have recorded a test case that performs the following function:
- (From the main menu) Search> Search
- Press Cancel button on the resulting dialog.
Here is the macro that was generated by AGR.
<macro version="0.1" >
<shell descriptive="..."
id="org.eclipse.ui.internal.WorkbenchWindow" return-code="-1" >
<command descriptive="Search... Ctrl+H" type="select"
contextId="menus"
widgetId=" org.eclipse.ui.internal.ActionSetContributionItem#{{Se&a mp;arch-Se&amp;arch...&#x9;Ctrl+H}}-{{0.8}}{{3|0}}-{ {0.6}}{{true}}-{{0.1}}{{4}}-{{0.1}}{{first}}-{{0.2}}{{&a mp;File...}}-{{0.2}} "
<shell descriptive="Search"
id="org.eclipse.search.internal.ui.SearchDialog" return-code="0">
<command descriptive="Cancel" type="select" contextId="shell"
widgetId="org.eclipse.swt.widgets.Button#{{1}}-{{1.0}}" />
</shell>
</shell>
</macro>
Upon executing this test, I see the search dialog opening up. The cancel
button is, however, never selected and the test terminates with the
following error:
org.eclipse.core.runtime.CoreException
A time-out occurred while running command MacroCommand [select, line 3].
This is likely caused by the presence of an unexpected dialog or the
absence of an expected dialog.
The type of the search dialog is
org.eclipse.search.internal.ui.SearchDialog which is not a native dialog
that according to section 1.2 of the guide (Known Limitations and
Workarounds) cannot be recorded.
Has anyone else faced a similar problem? I'd appreciate if you have any
pointers or workarounds for me to pursue.
Thanx!
Adil
Re: AGR problems with Search dialog [message #67409 is a reply to message #67220] Fri, 21 April 2006 11:17 Go to previous message
Hmmm. Odd problem.
I found out that if you actually change the tab and click on cancel, it
works.
Here's the macro:
<shell descriptive="Java - AutoGUITest - Eclipse S..."
contextId="menus"
&amp;arch...&#x9;Ctrl+H}}-{{0.8}}{{3|0}}-{{0.6}}{{tr ue}}-{{0.1}}{{6}}-{{0.1}
}{{first}}-{{0.2}}{{&amp;File...}}-{{0.2}}" />
id="org.eclipse.search.internal.ui.SearchDialog" return-code="0" >
<command descriptive="Java Search" type="choice-select"
contextId="shell" widgetId="org.eclipse.swt.widgets.TabFolder#1"
choiceId="item#1"/>
</shell>
</shell>
</macro>
I've opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=137965 to further
investigate the problem.
Thanks.
"Adil Aijaz" <aaijaz@parasoft.com> wrote in message
news:e28mht$41d$1@utils.eclipse.org...
> Hello All,
> contextId="menus"
&amp;arch...&#x9;Ctrl+H}}-{{0.8}}{{3|0}}-{{0.6}}{{tr ue}}-{{0.1}}{{4}}-{{0.1}
> </shell>
> </shell>
> </macro>
> following error:
> Thanx!
> Adil
Previous Topic:Filter Set locations
Next Topic:TPTP 4.2 I2 Stable Build Available
Current Time: Fri Nov 14 12:23:51 EST 2025
Powered by FUDForum. Page generated in 0.05714 seconds
