Home » Modeling » Papyrus » Forum participation(concern)
Forum participation [message #671705] |
Wed, 18 May 2011 14:13  |
Are there any developers who monitor this forum or is it just users trying to help each other?
I have posted a couple of messages, filed a bug and made an offer to help over the last week any have received only one reply from a fellow user trying to help. Perhaps this is normal? Should I expect to wait 2 or 3 weeks for responses?
Looking back over past forum messages, I see many that never get an answer. This is guarenteed to dissuade users from adopting Papyrus. Is there a project leader, a project coordinator, or similar that we can contact?
As it stands right now, with basic deficiencies (yes, I know it is still in the incubation stage), no useful documentation and very limited user support, I am hesitant to invest too much time into learning this tool. Is Papyrus going the way of UML2? I'd be very happy if someone can tell me otherwise.
Steve
Re: Forum participation [message #677091 is a reply to message #677065] |
Tue, 07 June 2011 10:48   |
If the developers do not participate the forum or even much in the developers mailing list (most of the messages there are votes), and there are few, if any knowledegable non-developers who can answer questions, what is the point in having a forum or even in having the project be open source?
I am trying to contribute and would like to do more. I have written bugs, made comments, asked for feedback, all with minimal response. I have installed the source but without any developers guides or architecture documentation, it is very difficult to get started.
For instance, I started to look at the Save issue. I found a function called hasDirtyEditors() in the fileDirtyEditorChange.java. This calls editor.isDirty() and editor is a IMultiDiagramEditor type but I can't find the class definition of IMultiDiagramEditor or the code for isDirty() so I'm stuck. I am no java expert so I need some guidance but as I said earlier, I'm hesitent to spend too much time on this if it is going to fall on deaf ears.
The developers themselves have said they need to do a better job of keeping up with the forum. I want to encourage them to follow through.
Steve
Re: Forum participation [message #677145 is a reply to message #677091] |
Tue, 07 June 2011 13:15   |
Steve,
Comments below.
All good questions... It would be nice to see questions answered with
some regularity, but no one is being paid for that, so the motivation
needs to be purely about helping others for the sake of helping others...
Yes, there's just so much source code...
It sounds like you're "just" analyzing static source code. I'd strongly
encourage you to do dynamic analysis. I.e., set a breakpoint and see
what's really happening at runtime. Then you'll know exactly which
implementation class is being called. Things like Ctrl-Shift-T to find
a class, looking at the inheritance hierarchy to find implementations of
it, are other useful techniques.
> ears.
When I first started on Eclipse, the folks working on the platform were
the "golden boys" who were protected by what seemed like a "cone of
silence." It was mostly necessary to figure everything out by myself.
I've even managed to poke around JDT to push for a fix to an annoying
Javadoc problem (that messed up EMF's @model annotations). It's
frustrating but where there's a will there's a way.
Yes, me too. I personally spend a lot of time on the forums helping on
as many as possible. But itemis pays me to make the modeling project
successful so my helpful behavior is encouraged and rewarded. (Formerly
IBM paid me. They'd have preferred I spent less time being so helpful,
but I didn't let that stop me.)
> Steve
Re: Forum participation [message #677161 is a reply to message #677150] |
Tue, 07 June 2011 14:20   |
Hi Steve
Have you checked the Wiki? If nothing else, with so many Papyrus
committers, they must need instructions that new contributors can use.
If you want to reverse engineer, I would match up with the RC4 release,
hopefully RC4 sources plugins. When I tried, I found many more plugins
than contribute to the code base.
Ed Willink
On 07/06/2011 18:58, Steve Blackwell wrote:
> Hi Ed,
>> strongly encourage you to do dynamic analysis. I.e., set a breakpoint
>> and see what's really happening at runtime. Then you'll know exactly
>> which implementation class is being called. Things like Ctrl-Shift-T
>> to find a class, looking at the inheritance hierarchy to find
>> implementations of it, are other useful techniques.
> In order to be able to do dynamic analysis, I would need to be able to
> build and run the code in debug. Since there are no build instructions
> (right?), I haven't been able to do that. Project->Build All is greyed
> out. There is clearly some setup that has to be done.
> If anybody has been able to build from SVN, could you write some
> step-by-step instructions?
> Steve
Re: Forum participation [message #682266 is a reply to message #677150] |
Fri, 10 June 2011 14:13   |
Steve,
That's a good point. I'm not sure if Papyrus builds an SDK with source
bundles. If they did, you'd not have to rebuild it to do source-level
debug it. Papyrus really ought to provide an SDK if Papyrus hopes to be
extensible and all Eclipse projects are expected to support
extensibility, not just provide an end-point tool...
> Hi Ed,
> Steve
Current Time: Wed Jul 23 15:33:44 EDT 2025
Powered by FUDForum. Page generated in 0.07347 seconds
