True subreport? [message #671615] |
Wed, 18 May 2011 09:40  |
I have been trying to display data from one data set that is referenced in another data set. I followed the subreport example, but that only allows tables to be linked. My inner data set needs a parameter supplied from a table in the outer data set.
I tried using a hyperlink, passing data from a row in the outer table via a parameter to a query in the linked report, but I don't see a way to display that data inside the outer table, only in the whole window. Is there a way to do it?
(no subject) [message #671988 is a reply to message #671970] |
Thu, 19 May 2011 10:08  |
Colin,
The binding tab is on the table when it is placed in the report.
Can you post your report?
Jason
On 5/19/2011 8:57 AM, Colin wrote:
> I don't see a binding tab on the data set. The binding tab is on the array;
> my parameters are used in the beforeOpen script of the data set and do not
> appear in the table's data set parameter dialog.
> Colin
> Jason Weathersby<jasonweathersby@windstream.net> wrote:
>> Colin,
>> The inner data set has a binding tab, which has a data set parameters
>> button that allows the inner dataset's query parameters to be linked to
>> the outer data row. Is this what you want?
>> Jason
>>> outer data set.
>>> to do it?
FUDForum. Page generated in 0.04423 seconds
