Home » Eclipse Projects » Virgo » Accessibility of kernel classes
Accessibility of kernel classes [message #671267] Tue, 17 May 2011 06:26 Go to next message
Hello everyone.
For my Virgo based application I would like to use a Virgo class that does the reading of the descriptor file for me. The class is XMLRepositoryCodec (from org.eclipse.virgo.repository-3.0.0.M03.jar) and it is used in virgo_home/lib/kernel.
I have two problems with this:
1) I wonder if classes in the kernel region are visible to the applications in the user region;
2) I have not been able to find a way to access the Virgo classes via Maven, i.e. to locate a suitable Maven repository that distributes them.
Any idea?
TIA,
B.
Re: Accessibility of kernel classes [message #671669 is a reply to message #671267] Wed, 18 May 2011 12:14 Go to previous messageGo to next message
The visibility is controlled using the org.eclipse.virgo.kernel.userregion.properties file in config.
The file currently has imports for:
org.eclipse.virgo.repository;version="0",\
org.eclipse.virgo.repository.*;version="0",\
The Maven repo should be available on http://build.eclipse.org/rt/virgo/maven/bundles/ but I'm afraid the publishing is not switched on.
Re: Accessibility of kernel classes [message #671878 is a reply to message #671669] Thu, 19 May 2011 04:56 Go to previous message
Hristo Iliev wrote on Wed, 18 May 2011 17:14
Hi Hristo,
Are there plans to start keeping the Maven repo current and starting to publish?
Joel
Previous Topic:StackOverflowError during import resolution
Next Topic:Problem with migrating bundles to Virgo
Current Time: Sat Jul 26 19:14:21 EDT 2025
Powered by FUDForum. Page generated in 0.06239 seconds
