Home » Language IDEs » Java Development Tools (JDT) » Instance Highlighting
Instance Highlighting [message #671515] Wed, 18 May 2011 03:52 Go to next message
When editing a Java class, if you click a variable, then all instance of the variable are highlighted else where in the class.
When I try this on a JSP page it doesn't work, even within a block of Java.
Should it? Is there some way of getting this functionality?
Tom
[Updated on: Wed, 18 May 2011 03:55] by Moderator
Re: Instance Highlighting [message #671579 is a reply to message #671515] Wed, 18 May 2011 07:43 Go to previous message
> class.
> block of Java.
> functionality?
JSP editor is different from the Java editor and is part of the WTP
project. Which eclipse download are you using ? (you can tell the file
name which you downloaded)
Previous Topic:Extending Java Editor
Next Topic:Code drill down and coming back up
Current Time: Thu Jul 24 22:24:22 EDT 2025
Powered by FUDForum. Page generated in 1.06142 seconds
