Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Advices for unit testing ?
[Acceleo] Advices for unit testing ? [message #495299] Wed, 04 November 2009 09:23 Go to next message
In the scope of my code generation project, I would like to perform automated unitary tests of the transformation results.
Does anyone has already experienced unit testing with M2T ?
What is the best way to perform that ?
Thank you for your answers
Sebastien
Re: [Acceleo] Advices for unit testing ? [message #495523 is a reply to message #495299] Thu, 05 November 2009 03:34 Go to previous messageGo to next message
--------------000502090709050006060101
Hi Sebastien,
We've never really unit tested the templates themselves, yet you can
take a look at the Acceleo unit tests for what we do to compare the
generation results and make sure it does not evolve/change between two
versions.
Laurent Goubet
Obeo
> Sebastien
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyLyI+T2JlbzwvYT4NCmVtYWls O2ludGVybmV0
OmxhdXJlbnQuZ291YmV0QG9iZW8uZnINCnVybDpodHRwOi8vd3d3Lm9iZW8u ZnINCnZlcnNp
b246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------000502090709050006060101--
Re: [Acceleo] Advices for unit testing ? [message #495602 is a reply to message #495299] Thu, 05 November 2009 08:41 Go to previous messageGo to next message
I usually recommend to write tests against the generated code.
This is far more robust compared to just comparing the text between two
versions of the generator.
Sven
> Sebastien
Re: [Acceleo] Advices for unit testing ? [message #495607 is a reply to message #495602] Thu, 05 November 2009 07:48 Go to previous messageGo to next message
--------------020800050100050502040204
Hi Sven,
This is only possible when what you generate is code, though Acceleo is
a text generator. Granted, when the target is code, the best bet is to
write unit tests against the target. Yet when the target is XML ...
Laurent Goubet
Obeo
> Cheers,
> Sven
>> Sebastien
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------020800050100050502040204--
Re: [Acceleo] Advices for unit testing ? [message #670923 is a reply to message #495602] Mon, 16 May 2011 04:22 Go to previous messageGo to next message
Is there any news about the unit test of templates?
I have developed a unit test to check one of my generators, but when I break my generator the unit test does not failed. No exception is thrown but I can find message in the log.
I use the following line to launch the generator :
new HtmlReport(benchmark, targetDirectory, new ArrayList<Object>()).doGenerate(null);
How should I call my generator to be able to get an exception when my generator fails? To be able to get those exceptions would be really use full to develop low cost unit tests.
I get such kind of Exception :
!ENTRY org.eclipse.ocl 4 10 2011-05-13 19:27:57.956
!MESSAGE Evaluation failed with an exception: index: 0, size: 10
!STACK 0
java.lang.IndexOutOfBoundsException: index: 0, size: 10
at org.eclipse.ocl.util.CollectionUtil.at(CollectionUtil.java:8 86)
at org.eclipse.ocl.EvaluationVisitorImpl.visitOperationCallExp( EvaluationVisitorImpl.java:1213)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitOperationCallExp(AcceleoEvaluationVisitor.j ava:1064)
at org.eclipse.ocl.ecore.impl.OperationCallExpImpl.accept(Opera tionCallExpImpl.java:390)
at org.eclipse.ocl.EvaluationVisitorImpl.visitPropertyCallExp(E valuationVisitorImpl.java:2061)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitPropertyCallExp(AcceleoEvaluationVisitor.ja va:1075)
at org.eclipse.ocl.ecore.impl.PropertyCallExpImpl.accept(Proper tyCallExpImpl.java:238)
at org.eclipse.ocl.AbstractEvaluationVisitor.visitExpression(Ab stractEvaluationVisitor.java:248)
at org.eclipse.ocl.EvaluationVisitorDecorator.visitExpression(E valuationVisitorDecorator.java:156)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 650)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitExpression(AcceleoEvaluationVisitor.java:96 3)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoForBlock(AcceleoEvaluationVisitor.ja va:402)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 613)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoFileBlock(AcceleoEvaluationVisitor.j ava:386)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 620)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.visitAcceleoTemplate(AcceleoEvaluationVisitor.ja va:832)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvalua tionVisitor.switchExpression(AcceleoEvaluationVisitor.java:1 600)
at org.eclipse.ocl.internal.evaluation.QueryImpl.evaluate(Query Impl.java:152)
at org.eclipse.ocl.ecore.QueryImpl.evaluate(QueryImpl.java:62)
at org.eclipse.acceleo.engine.generation.AcceleoEngine.doEvalua te(AcceleoEngine.java:265)
at org.eclipse.acceleo.engine.generation.AcceleoEngine.evaluate (AcceleoEngine.java:130)
at org.eclipse.acceleo.engine.service.AcceleoService.doGenerate Template(AcceleoService.java:765)
at org.eclipse.acceleo.engine.service.AcceleoService.doGenerate (AcceleoService.java:478)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator. generate(AbstractAcceleoGenerator.java:175)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator. doGenerate(AbstractAcceleoGenerator.java:154)
at org.eclipse.modisco.java.discoverer.benchmark.template.html. HtmlReport.doGenerate(HtmlReport.java:195)
at org.eclipse.modisco.java.discoverer.benchmark.Report.generat eHTML(Report.java:324)
at org.eclipse.modisco.java.discoverer.benchmark.Report.generat e(Report.java:102)
at org.eclipse.modisco.java.discoverer.benchmark.RunBenchmark.c reateReport(RunBenchmark.java:44)
at org.eclipse.modisco.java.discoverer.benchmark.tests.JavaDisc overerBenchmarkTest.test001(JavaDiscovererBenchmarkTest.java :50)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall( FrameworkMethod.java:44)
at org.junit.internal.runners.model.ReflectiveCallable.run(Refl ectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(Fr ameworkMethod.java:41)
at org.junit.internal.runners.statements.InvokeMethod.evaluate( InvokeMethod.java:20)
at org.junit.internal.runners.statements.FailOnTimeout$1.run(Fa ilOnTimeout.java:28)
!ENTRY org.eclipse.acceleo.engine 2 2 2011-05-13 19:27:57.956
!MESSAGE Invalid loop iteration at line 49 in Module htmlReport for block for (b.projects->at(0).discoveries). Last recorded value of self was org.eclipse.modisco.infra.discovery.benchmark.impl.MultiProj ectBenchmarkImpl @8966e9 (jvmMaxHeapInMiB: 0, processorName: null, processorDescription: null, processorCount: 0, processorCacheSize: null, systemMemory: null, osName: null, osVersion: null, osArchitecture: null).
!STACK 0
org.eclipse.acceleo.engine.AcceleoEvaluationException: Invalid loop iteration at line 49 in Module htmlReport for block for (b.projects->at(0).discoveries). Last recorded value of self was org.eclipse.modisco.infra.discovery.benchmark.impl.MultiProj ectBenchmarkImpl @8966e9 (jvmMaxHeapInMiB: 0, processorName: null, processorDescription: null, processorCount: 0, processorCacheSize: null, systemMemory: null, osName: null, osVersion: null, osArchitecture: null).
at htmlReport.htmlReport(MultiProjectBenchmark)(htmlReport.mtl: 49)
at htmlReport.htmlReport(MultiProjectBenchmark)(htmlReport.mtl: 17)
at htmlReport.htmlReport(MultiProjectBenchmark)(htmlReport.mtl: 14)
Re: [Acceleo] Advices for unit testing ? [message #671245 is a reply to message #670923] Tue, 17 May 2011 05:21 Go to previous messageGo to next message
The problems found by Acceleo are logged using the standard logging mechanism in Eclipse and they appear in the error log.
You can find here some documentation in order to listen to the errors logged by a specific eclipse plugin or by the complete Eclipse platform. Something like org.eclipse.acceleo.engine.AcceleoEnginePlugin.getLog().addL ogListener(...) and org.eclipse.acceleo.common.AcceleoCommonPlugin.getLog().addL ogListener(...) should do the trick if you want to listen to errors from the generation.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Acceleo wiki: http://wiki.eclipse.org/Acceleo
Blogs: http://stephanebegaudeau.tumblr.com & http://sbegaudeau.tumblr.com
Re: [Acceleo] Advices for unit testing ? [message #671324 is a reply to message #671245] Tue, 17 May 2011 10:15 Go to previous messageGo to next message
Thank you for your advice. It solve my problem.
Here is the patch to listen to the log of the Acceleo engine : https://bugs.eclipse.org/bugs/attachment.cgi?id=195859
Gregoire Dupe
Re: [Acceleo] Advices for unit testing ? [message #671582 is a reply to message #671324] Wed, 18 May 2011 07:54 Go to previous message
"but when I break my generator the unit test does not failed"
If you want to detect errors during the parsing of your generator, you may want to look at the test project org.eclipse.acceleo.parser.tests.
This utility class used for our test may help you. You can see how we are using it here.
We are checking for informations, warnings and errors during each steps of the compilation, like this:
checkCSTParsing(moduleFile, 0, 0, 0);
checkCST2ASTConvertion(1, 0, 0);
checkASTResolution(1, 0, 0);
checkASTDocumentationResolution(1, 0, 0);
You woudln't have to launch the generation for that.
Previous Topic:[Acceleo] Bug in Acceleo ?
Next Topic:XPand Multiplicity
Current Time: Fri Jul 18 22:10:08 EDT 2025
Powered by FUDForum. Page generated in 0.10480 seconds
