Home » Archived » BIRT » cannot override report parameter list from rptlibrary
cannot override report parameter list from rptlibrary [message #671314] Tue, 17 May 2011 09:21 Go to next message
In the Copy of DateRangeParameters.rptdesign file, data explorer view, select "Parameter Group - Date Range" > "Report Period", then remove some value in the "List of value", press ok button and save, then run the report, the remove value still show!!
in fact, after I remove some values in "List of value", press ok button and save, I try to re-select "Parameter Group - Date Range" > "Report Period" in "Data Explorer" view, and the deleted value still show!! why?
my birt designer is 2.2.1
thank in advance
Re: cannot override report parameter list from rptlibrary [message #671388 is a reply to message #671314] Tue, 17 May 2011 13:14 Go to previous messageGo to next message
Can you cut and paste the xml for the report into your message?
Jason
> thank in advance
> begin 644 reportParam.doc
> MT,\1X*&Q&N$`````````````````````/@`#`/[_"0`&```````````````%
> M````&P(`````````$```'0(```$```#^____`````!8"```7`@``&`(``!D "
> M```:`@``___________________________________________________ _
> M___________________________________________________________ _
> M_______________________LI<$`"4`)!```^%*_````````$```````!@``
> M.0D```X`8FIB:A!6$%8````````````````````````)!!8`,A```'(\`0! R
> M/`$`.0$```````````````````````````````````````#__P\```````` `
> M``#__P\```````````#__P\``````````````````````(@``````$(!``` `
> M````0@$``$(!````````0@$```````!"`0```````$(!````````0@$``!0`
> M`````````````%8!````````_@,```````#^`P```````/X#````````_@, `
> M``P````*!```#````%8!````````>@8``#H!```B!````````"($````````
> M(@0````````B!````````"($````````(@0````````B!````````"($````
> M````^04```(```#[!0```````/L%````````^P4```````#[!0```````/L %
> M````````^P4``"0```"T!P``4@(```8*```X````'P8``!4`````````````
> M````````````0@$```````!Q!0`````````````````````````````B!`` `
> M`````"($````````<04```````!Q!0```````!\&``````````````````! "
> M`0```````$(!````````(@0``````````````````"($````````-`8``!8`
> M``#5!0```````-4%````````U04```````!Q!0``%@```$(!````````(@0 `
> M``````!"`0```````"($````````^04``````````````````-4%````````
> M``````````````````````````````````````````````````````````` `
> M````<04```````#Y!0``````````````````U04``````````````````-4%
> M````````0@$```````!"`0``````````````````````````````````````
> M````````````````````````````````````````````U04````````B!`` `
> M`````!8$```,````H$+I%Y04S`$``````````/X#````````AP4``"X```#5
> M!0``````````````````^04```````!*!@``,````'H&````````U04 `````
> M```^"@```````+4%```*````/@H```````#5!0``````````````````5@$`
> M``````!6`0```````$(!````````0@$```````!"`0```````$(!````````
> M`````````````````````#X*``````````````````!"`0```````-4%```D
> M````(@0``#````!2!```(@```-4%````````=`0``!P```"0!```X0``````
> M````````````````````````````````````````(@0````````B!`````` `
> M`"($````````'P8````````?!@```````%8!````````5@$``(0!``#:`@``
> M)`$`````````````OP4``!8```!6`0```````%8!````````V@(```````` "
> M``$!``````````````````````````````````````````````````````` `
> M``````````````````````````````````````````````````````$-#7) E
> M;6]V92"386QLE"P@DW1O9&%YE"!F<F]M('1H92!S=&%T:6,@;&ES=`T!#0UP
> M<F5S< R!/:R!B=71T;VX@86YD('-A=F4@=&AE(&9I;&4N#4=O('1O( 'AM; "!S
> M;W5R8V4@=&%B+`T!#71H92!P87)A;65T97(M9W)O=7`@;F%M93TB1&a mp;%T92!2
> M86YG92(@:&%S(&YO="!O=F5R<FED92$A#5)U;B!T:&4@<F5P;W)T+ "!S=&EL
> M;"!S:&]W()-A;&R4+""3=&]D87F4("AI;B!#:&EN97-E*2$A#0U3;R!H;W <@
> M=&\@<F5M;W9E('1H92!S=&%T:6,@=F%L=64@<V\@;6%K92!I= "!D:69F97)E
> M;G0@9G)O;2!T:&4@;&EB<F%R>2!R97!O<G0@<&%R86UE=&5R/PT`````````
> M``````````````````8```$(```""```"@@```L(```."```#P@``!$(```2
> M"```%P@``!@(```N"```+P@``%0(``!5"```:@@``&L(``!P"```@`@``(0(
> M``"%"```D0@``*4(``"F"```P`@``,$(``#$"```Q0@``,<(``#("```S0@`
> M`,X(``#?"```X`@``#D)``#W\NWI[>GMZ>WI[=_MZ>W5[;ZGD'GMZ>WI[ >GM
> MZ>WI[>GM````````````````````````````````````````````````````
> M```````````````````````````````````````M%6CM$HT`%FCM$HT`0BH "
> M0TH4`$M(``!/2@,`44H#`%Y*`P!A2A0`<&@J`/\`+15H[1*-`!9H[1*-`$(J
> M`4-*%`!+2```3TH#`%%*`P!>2@,`84H4`'!H`````"T5:.T2C0`6:.T2C0! "
> M*@Q#2A0`2T@``$]*`P!12@,`7DH#`&%*%`!P:'\`?P`M%6CM$HT`%FC M$HT`
> M0BH/0TH4`$M(``!/2@,`44H#`%Y*`P!A2A0`<&@_?W\`$@-JFFX"`!9H[1*-
> M`%4(`6\H`0`2`VH3Y`$`%FCM$HT`50@!;R@!``86:.T2C0``"19H[1*-`&\H
> M`0D6:)EY'@!O*`$/`VH`````%FCM$HT`50@!`"(`!@```@@```,(```N"```
> M,`@``#$(``!4"```:@@``&P(``"E"```W@@``-\(```Y"0``_0``````````
> M`````/T```````````````#]````````````````_0```````````````/T `
> M``````````````#]````````````````_0```````````````/T```````` `
> M``````#]````````````````_0```````````````/T```````````````# ]
> M```````````````````````````````````````````````````````!``` `
> M#``&```Y"0``_@``````````````````````````````````````````````
> M```````````````````"`0$!,``QD&@!,E`"`!^P@BX@L,9!(;`(!R*P "`<C
> MD*`%))"@!26P```7L%,#&+#@`PR0J0$`````````````````````````````
> M```````````````````````````````````````````````3Y`$`1`!D``` `
> M``````H`````````````````"E``+94!E0$`````````````````````````
> M``````````````````\`!/`P````L@0*\`@````!!`````H``",`"_`,````
> M!$$!````_P$```@````0\`0```````"`8@`'\(_C`0`&!@"]<CI? "_@ET"Z!
> M]R%()U/_`&OC`0`!````1```````,C``;A[P8^,!``"]<CI?"_@ET "Z!]R%(
> M)U/_B5!.1PT*&@H````-24A$4@``!58```,`"`(```!`7*N5`````7-21T(`
> MKLX<Z0``_\I)1$%4>%[LG0>`%$76QWO")I:T9!1)*F9%0<6,"3WES/D,Z)E/
> M#&<.IZ!B/B-^9L]3[]0[`R;.<"K&`T5%,1"4(&%A6<(N[.[D_EY/+451W=-3
> MW=.3_TT[]E17O7KUJYK9>:]>5?LNG?BKMO%16QNLJ`Q6ZII6X:,[U7[CM2KH
> M\P6-?`'->.OSMY?1$\:%]%82B+<@``(@H$[@O$<7^WP!RJ]'JY)?.L9WCG%4
> M5AO750$M&-!B<7KU!0)Z7-=B"<WOU^A+*?EU9!RQ]=]0ZK4B9^D3,`85#A#8
> M0,`7`0T0V(B`+GY+T'5\H[MA]HZ&3:46B6F5R3\Y$;]6&332M)A Q1I-_L "KH
> M-W3R1S.]1G4MO.RQ*WH#-0B```BX(Q#7Z"M%T^D[QO8(QXQLTA$*)R)Q?TMS
> M2$Q?^M52WY\FS**D0)6_JJHB$$Q4=*H,!@-D^_OI7?)7=(>`(2[H][6_=Z <[
> M2H$`"(!`.@)G/[3$^.VTZ1:^VIJ.U?ZJ:J-`#9G\U5H'^AZJUFJ2O\<"R5]6
> M9/6G.A+<%Y"N1MPO'P(V`Z9\(*"E(@%\46`\F`E(7Q0T2.(QXX\.?TT%K2TJ
> MWVE.N@S6M&AKF^.1F3]IS>N>NF-+,`<!$``!>P+Q6$(TNNFMF)_-OC.GP$;I
> M)@<!]PB$$GHDID>;8_%(+!&-M[1$FW];Z_O3^!]I,JVVUN</!OU5?A_9^GZ:
> M@:-_9/3[C#B`@-^?#`1@'@$<(``"()`-`E<^6>^KZQOL4!NKB%=4=^I8F8P_
> M2GH!JI+1`#310M/__*"W[*#)&!P@``(@``(@D"$!"B]C!_M;P][&UD^ >D3-:
> M^G/CCVF)]7^)*&>X/4R@74AX?<%U+<9O]O#R5FW1_#LN1SA`AKV$XB "0'P*Z
> MKG>NT`;UI$GS]=&I^L9V>'*JWOB/7MAU\OZLI:&U.MG7AB'M6LC/B]N:8Q1W
> MGQ02T;O4^@?UJ:JNY&'Y2IK,^+EYP:*6UE71Z+JP[ZQ+OJWI5EG=(1"L#/C6
> M"_(9]K_&W0'&MZ'XT]M$WHC%77](-/+32Z@5!$"@J`B,?VJ)UJ6/%@CYNM49
> MWV[K)V+\%4%R3VJ^BF!%,*SK`=WXL@OZ=;JN\AE?P2R1I=!;2M3C&KW $C(4!
> M.$``!$`@)8%$Q")F$KS*F8"_TD>C0J\R_JS$?1MFWGQM<5]4]P6B6CR >B`9U
> M^C,3#6@5<0K\]U4DEZT9?WC6>Z-IRHXFS?2@UAIJ7\@63!H,H39M]1HM4G/C
> MV37E#!EM!X$B)5#7P;=IMZJOYB3:0L:D>HP\@`D]3HY"'WTQ&&UB)G`L3F:^
> M<1VE/-%XAV#XJ+VJEZ_3F^+&[]),A"Q;&U\3]>D)O7NM?[L>X?`/T_6VUD0T
> MHAFJQ`U5Z(=Q4A5#`W(_Q&+&_TG+&$W^1R.5';H<>.0/2ZI^_+&9OIU\?SC_
> MZV[=*ZL[5?BJVUT:2?N_W05`4D1'@+G/1./?6(B+OZ=%.JZA-@CDE<"MSRVC
> M14=:EVX;M*`)%V,!DI_<`>0(8.F&.R#%H2=BOI@0),"^CW&```B```B`@&L "
> MB61\?X)B;W5?<IUM(IZ@MT8BG_UB@;ETM$?H&G=]\1BY!8S=`5@VVL@F'-76
> MA;2%"ZZ_=3?7ZJ`@"(!`O@B,W+[3^]_$.M<8"U%#$3U$IG?<L+C))J >O!.-;
> M0=?HZX&^!N)D=,?U:%0+1Q*A4*A*;SIC]*9?+C+"A#(4\K]Y+;0&X,#A=6U?
> MO.>K[41!`8EP2*>(HZ0J.JU<(H.?V?_LFO2C[Z)H-!$.MX5":_V5FQYSSAOO
> M+`NO;C5<`+U[5@4JR9U)&_[YM6#RFXN\`,F(`)I<,Q*-7][)70#7[\O%+7^C
> MT<;WX(;N:$_)5_^@7A``@6(C<-NC"[4^FVJ^)JVZ4[ON517&1=(+D/SF,1P!
> M[;?\R5OL8#_.DH>/ONEH6H8=&Z^;*C8>T#=+!.`5RA)8B`6!$B)@WB* "?NC&
> M]0I?XLQ]*F\ZN=LFW5-ZHBTIG'?WPK]-7ADE1P!%G41;C3R+YE][RWXEA`Q -
> M`8&R('#`3IW?G!KKV\U'<^VA,/GT]&B<?(*&V<_L;CJ3=K=AC)/I39_Z2-(%
> MT-J\XLI3-Y\RMX4P92CDPQ^:2,A!NW5K^>C-8,^^9+$GPFU:)&3$),3(%4% >
> M`)U^#QM+$-I=`.2%)'=D+!$)A]I"C>O:MCWGRLFOSVM<$S=<`#V[502J*RC\
> MB38N'=)=VZE+O%J/MD3U;^>L6AF.1R+Q6$4PTK%39?=N@>KDPES#T;G!\M <W
> MN#]]1I58"5`6'P0T$@0\(W#[X[\9LKK4^&HK]:H.QK7)!<`KV^`+2)K]QM=1
> M/.'3*?X_^:5$">P''/N.P@$"(``"(``"B@3X9@#L25?L]ZTQ^9\X=_^JB4 >U
> M-/WKD<2:E8G6%IIVHQA?G4)PR3T=,YX'D`P(IC6ZR0T`:+U`)!0+M:WKW'/`
> MA*>O?JW3X_^JUWQ1+=2JQ5JTU>NNN7D?18V0#01`H$`('#BTZ\N?& "X`FA8G
> M^Y_">E@4@.$"6#\'3_/_R2\`(Y$6!!@3\)%0V]H55_QA\(>SU]*M#(5\, "/I
> M`MBC6\N[KP1Z]C$6OD;"=!IV/LU^,=\#.222?HCD$B7#2T%OR4<0CD0;6]JV
> M/?OR-R?]LFJ-GHP"Z$)/-*D(U`;WVC2Q\^`:?U5@X?*6G^8W+UW:'(E$PY%(
> M6SC:%@[[.G?J,G!`;9T1J6OL;[!^0F7#M'_R)S=<``4R4J$&"!0+@=OO^9_6
> M>5.3"Z#"V)$I&05@K/67-CJA+U=R`;1;_NQ7VOKF2B&:Q4(! >F:;`/=69[LB
> MR"\6`A@2Q=)3N=>3NP#B%`.;H*C^Q!N;K[SWZD"O3>CY6(EU3?&U:XR?W9%(
> M\J<V3;(9O[8U<@K03_!8Q/A1'FJ-M:Q=T]2TM*+33G^;MNDA7QLN@#4AS;]2
> M:_CYFMO&Y+Y-J!$$0"`3`@<.JWMI2K1'%^/;P=A@G^;=C2A[(^P_3DM16=!]
> M,AR`?H<:00&&%S&1B(7#ZU9<=O+@#W]J-EP`*80\<DTOLV['7[-,$O+!C#6T
> M)NF@/;NM^\]+@;KNQ@_A:&2G@X8/V'G(I!L?3^X(8&ACV/\)VB! `/^:!J^=_
> M_NTW+_Z'G`"1>&)E2VB;LRY[<]+<#2X`7U5%_SK]L*W]G3;M$JZNGO=;TZ)%
> M33__N"P2B83"Y`*(M+:%V]I"E=VZ#=AE:'7'6OKA;2B:]`*<=JB\N^G?WZK/
> M!+&CLF>,[BOE=U0[*^ZHB+IZ-KI)MY@"]FVQ+&*O#"]BV4`7`EEU]F+5^=CD
> M-*-@F7E#[#M.+"ZV/7O=[8*)J(SKOLB<MB63##]6HE8JHFX?-UW;I)=66^NO
> M#B8Z\R@`PP7@"P3HVZ;]7R`Y+9-<C=F>1#/_?-J?4OG,/Y_)R1P0)(`` ")0J
> M`;@`2K5G,VF7$5#FU^AYV(;Q;_Q=H?^8"Z!AW+E5V^Y"?Y7B3:O)"T`3_GHD
> M:L0"Q&GK0%H0K!NQN)0S&J8?Y7JX+=ZZKJFI:=;RE<=/;_#M\C\MZM=:FY@+
> MX+H[S\I$1Y0%`1#(/8$#AG;YYX>QNDX^LKO)RC8^[N3Q,UP`AL5-B__9S+\1
> M@)]<56_\1_/D\7#(<`$,FC)K':6D$O+X]18N@&.N7BX)^>!;PP5P\)[=UK[U
> M0J!+5YW6),1B1UQS&J/QVK4/)P,2#*<DG<<^>`U+?^5/MY)&D;C >V)IT`;QF
> MN`"2,VR5E;07P-`N%*$47;$JM+2A)12*MK6&:?[?L/]#$3+^Z6P-A>M_G4^G
> M\7U(QC^=QH]O[;G)AGYT//OVLF??7$87]*.??K)[?I)8LV16HU'[FVYJ9Z4 \
> M5Y4)-(].ELZ,(E:U2,RF+;P(E\E%V=#F`BT;*%;GJ-?LQ7H"TXR"$1,!)C\5
> M%L-,Q"NUB]'S1$-)B`LF7)E4XR$;>DHRN7TNC2*G'RO+SR:K2T44']4)?_+I
> M?\8J@`KZ4CIR8/2-@U9]_;OZ+T8M^;\!/XSO]>VU7::?5CMS1VU1QT2H/?*?
> MOL/,#WPG%RU.$)`(F+^1D0("(``"(@'#[$_ZFMOM_^2]*$WE&>O_]9:UB77-
> MB9:U-,-/%KX>"NFA-MJ16V]9EUC;'&]>$V]:%5_71'GTUK5&!C(+:#O;0'*3
> MFLKD+C:)+NMKHXIP@@`(%!4!8[<_%EG?ON8_D?`9&P$:-G]RZWUC*HI2V)F,
> M`C"6R!N6A[%_`/O(IQ!RYOB&TV]:_H>_+#_Q^N7'7;N<&?]F(3YZN&!2 "$WR
> MTY:#S/'P^OBGV1?+T;?_R=#&B$!(</O_U0MO3A9@ZABJL,SM.VS1PPKKJN.M
> MC2T+EZQ=MFQM?3VM`E@3HOA_LO]#83+^6T-)+T!;>`FY`/@7F-_8-W"C/Q_Y
> M?@X7LS=._WV?0OBCQBU\4H9?,]VX723>4M%9+*B2OR3SE!*$#,>#)_TK#E1+
> M@;GX6.D5Y(PT]DR.5VH1^K$5N&['EGL/C@_=JD-;AZJ9*R,-X40H3`N 9PAVC
> MJW;1?]XY_'WWZ,KD+ZKUB_^YZL(S2CWA`R$E0@`^$1"0"-`31G""@$B`'H@M
> M'N0(B&](H;G]Q+HU\>;5B9;FC@<<W?.&AQ,M+7I+2Z)E7;RE.=&\)K%V=:)I
> MU:9/OM_E#Q<G70`QVJ_;%TP:_WK2P6W\[JXLD6]4-`,$RI(`&=TQBOMAAG;R
> M08#)U_4V?_O\>'*B/'DK&0T@'US(PU?U?/3:GD_>T.MO-_5Z=GSO?]S2^Z4)
> MO9DW@0Y[(<9.`Q2-D%3E];\\QNHX^NY+*1#AF/NO9F]?O6`<\UB0%X`Y(8PO
> MH:3Y;^P%L$GO6G]%X(PAS8O[&[/3QM:GQCX"U$)Z]$GR-;FY`%W$$A3ZM'95
> MO&>[:NM;=.JA1O0""P<X[3!C7<!S;[6'!IPVNGV9`$OA;UE1<S: >*.44X?%2
> M+)'EE$1)U=GK8ZF&6*.DK?F638J->N928N:T!2T145M$YF:!EJQ4LJ7J+W.7
> MB1UD[G%I2*1%9PE?@I-*2"J>J8:EY2CEPE7&L-.!9]\0D9Y-[>8>%SM+_)B(
> M,,W" 18SJ'RM)CKE_TX[JK7?[3-NLBQ:LTKITT&HJ:*7EOGU#_W=PN'O_SC;K
> MDA8F>LSJN&NDHM9X1!,[R`W[@KPRB))])RQE]_5_;<(NI!3^UCR0>!&IH*,O
> M`60&`1`H1`)\`Y%"5`XZY96`^%@9^@%-?S[>&E#_IR,J-ANDT1-JPA&R_YE^
> M2R\X@A;_:Q3\3UL`1".;O?052U]T[([TD.YUT<2<E4W'?/Z;;_>96FNK1H'`
> MP7FT$.#Z.\_.:_-0.0B`@&,"^P_M]/0[T<X=R+/7_M`]PT!.K@*@N2=C,[[D
> M*UL(0"=9W7XRF&.1R+K&RT\9..5GXXD`DI"'K^QIUN.8ZQM(R*3; >XV^ND$2
> M\N$WS11P<-">=<VO/NVO[6)$O!H.`[+;8V2Z'SWA0E'::Q?=O/X9@>0`\$7B
> MVLK6R-9G7_[6J[_0$P'61P$$C<7]';_X^8M79[S_PE>3G_W\U2<_>NG_WG_N
> M_K>>NNNU_YOPXGTW_?VNZYZ8<,4C#]SVHC'S;P3?"F>R0C+^F?W__-L-1L2#
> MS\=^^M-;X^[HWI3"KJ5$GBU53DH7"S+A_&`"S6_-M4LIW%8Q:\LTM-16JCWM
> MVU3J619DF4DQKBK/)L)AB:)Z_)H'>+!>X+6;:?"[8EUIH;&JQ1'&*K*4+R8R
> MI);94C$4:['O=$L)$L-4*-*.4I4Q;(_:7`571AH>8D/2?B[,'RNI][FTM*+,
> M`-4_5N(XM!]F4H]L-#QHAJ0BN0M`,K+H_"W7548C]NN2.C;]VKGY%RKAIST "
> MC%@KBHWR^TYNWXBDMN^M=+)6=/BT/42*F_IB"F5C;\G:EPQ^0YWU[@,FS9Q!
> M'*7>7EOJXVT5D`8"94V`XHUP@H!(P/;SH$?#"=K_+TRF?G3Y-6>PO)L\\H:Q
> M(5AR_> T&^__(K2F%E@$;DWE\,]MX\J%:+`J@J,*?H2T(@`!;VD\&OV'J)X W\
> M]AE^MGB(EI\&DBM0*9J53B/%6`Z;\/D3],H^\^VS\!L)H1OGWM[PQPD -8VYI
> M..WFAE/&&V9RNQ#CZT(60DN+DC_U?<EG#R:_>8SO&::+_MJU#_+OL$F73C#T
> M(5V,Q0/L5S);#B`L!*`?T'23'EVX;L]M]CQFZ,$G[WK8Z7L=<_;^)UYX\&F7
> MCO[C54=?>/U)EXT_XZK;SKG^G@LNN>XDBOZGI4WT8YM.VC*%3O$[\_EW&HP$
> M=B:/4P]?O\.!D+BA$"\MW972S6\WKD6JU+)V0[>D/G3!SG854RDF5LJR\DJ3
> M%R2*G](M"WW,#=Q8VL8@M8U()G-R_2V%;[@KJLJO4_=%.PJIBHT+LMHWJ+2^
> MRWF*2NTIAX29@\C*BOQ&'6=?W#1.+(>!RU&JAEJJ,>7@EQIB*3S%F+3F;_D9
> M2276IG:A4I6.MH:9K%<<U;(HIEB<OEFT+;M&5=8E5:^>E_RN#02"0 >/_QE?@
> MAL5(K?N<108\=P2(7U/B-66CDZ=P[T"J_&DSI"KH+CW'U;E3$J5```1`H!0(
> M,'>`>*P/,F-I]"S`1/)Q@#3QM^R2XUGBID__EQZ]U>^%:>SMHB.VU.*4@;80
> M("_`^K7`^D;Q_VEGCY`!!$"@\`B02V_]$@#:E=JPI@T+FUG$R0ER>DW:[0$R
> MNRD&@(Q_X]2-&_S82$CRA^O&0I*_9"?=:D0'F(60)#]ME6T\J(1F_I,/(F&+
> M_`U/A._HVR_FWUY'W7^]427I8\SRD[KDCJ1':%-.GR]H?!TE?RZ3.)]O931 0
> M]\/\>6]\_:]'/WCNP7>>O/OU_YOP[_MN^L>=USYSR^6/W7C)@]?]Z;ZKSKW[
> M@T]^-?P<`2H4H%,T]?_YGK$TEQ8%D(>`G4P/2F>GF,COBA<VU](M7H4YG56:
> MJG9)29Z9\O-;3.=4VHI5\Z;Q_.)=28+E6RD_)R:1)*H,K(W^O,EBH^QIB#F 9
> M)FQ-!ZM%Q&BIIZBDN:`E4LLA88;&4K@:9KQFS24A7!^I7:)DAM1 2 <W/S;:A:
> M#A5IV(L=)^IFTQ#+&E-]<"Q[GS-)*TI]W*K@LOS(F[\?)%&&DI656I4O[@]T
> MJ/`MWV%0Y>:]:S;MUGO;38<?NL/!)^]^V!G[''GV`2=<\+O3+CGZK"M/./^&
> M/UQZ_JZL:<DCH.D;N2/9+'KK/N?12?L+FB;5C4T'UR<:%TQ*2_T-E+[Q*532
> M?ME>,%EJ@QPFC26*U^);GLYS2A+X6U$?>VDFA27]\18$0``$0$"=`#D"_,9)
> MNP`:/^C;)R42H5:-'@08-9X&;BR7]>E++SJ2?5'W>^YS=K'DF*W]_N3D'^TH
> MJ,=\"3K7>Q$Z^;6::BU82]E2_>Q!.@B`0,$2(%L]KANG\>&GCS&9W2PRFN]`
> M35\5Y`@PP@$,JSYAG+2>W_`"&.OOF6DL"4G*$848WR-^WU'C&X^XJ=$LQ-A >
> MA-8A4*5)D]Z(-J*GEB:%''5+^RJ`UZ^]EWT='7;'E>0",.(&C"\EPPM@!`*L
> MGREK_S_]<OXI7!.KJAS0L[9[E9_M_&?L`DC/`J2-`)//!0R'HP.VV7+(SCLF
> M0P#H85T^.JDYR<B&]H/]RC]E5'?I)S.EF!/-/ZLS3V&U<-.1" >2ULPL;)5E9
> MJ7CF6HD2S+5;PK%4,BU#T69.I;;KOC`73$625\V[PXS4M1HJW<'KM:S%?ABH
> MR%?,HS+P%,>#2HTJO:\BQYS'\F-E+TI]5!MR*CL:L9&5U89S,1XD2UYQ7=+M
> MXU_2`LF=EL@!0-]#0?IR:_<")"UYX^CPZ6-T3_^7X4_=*")@?2++XSNYD >5/
> MK@LPBFPXD^E,X/KE`!ND&9+IRU`H3GG$ZLP9>$5TP>[:Y[>_:Z&PJ#RN.0%W
> MHQ^E0``$RHX`39$ES\J@%B2CG6V>18^DC5(4@!:-&/&WQN]O8QYPZ?F' <CQ+
> M3]J!_=1FO_P-%X">C-2EHX+^/"4#`6(M6D7GE'&CJ:(:D0X"()!O`F2H&_OE
> M)4^RZA^[NL?C5_=X\IH>?[NVY]^OZ_G\]3U?O*&GX0Y(.@4H$(!>UT <!)/T%
> M2?TE(<;OP&1<OU$J&0Y@?$O8"='ID:5&9IV6`"17`5`T@D\_ <CS-=1G'&S<\
> M2'??N/INXUNGIOJ(!\:Q9Z<9(0#&DTY((Y^?OH[8=H#]!]3YJOS^&O]656L'
> M5K2N7-7RO]E+I\]>O*II'3T.@!X*0(\&-.S_;;?8[>!]^VTQ<,/?@F2])^W;
> ME:>\\,&JDP_LQM[2-;U*;\44GL<RD1>T$245%.MEUS:UBZJR*L0:+5/,\C >@
> M2'%E;H6DF"4KJ79+W>P;*,$W"TS5$6:D-GTJ-EH%8*HA88.1`60%^6%)E >>4
> M^E%L.Y>3:I2F[5#SP%!!+0U%<Z/,8\\\3LS*IR(CX4HE*M7@5/]8\=$K\K1A
> MFVHL;;WW#*U/5ZUS1ZW6IU55DB4_;=2"IB'&M'S:W4FO_&@+ID8\FOS >I/U1
> M7ZBC_Y-AS(WVUI%_LDRD;#Q=S$/7XDC@>5@BN\L2V4%UF8O;9."*21>I!')W
> MADUU*D,7>4``!$``!-(0$!X!0/MX\<SZJST6'3\LT+.OOZK&F..C+;GHR;3Q
> M:-^'WA`%+CMA*_IK9*P42-H):R/:G)6M1TY?Z=M[H18)::L26M5";?D/-]W[
> M!W0$"(!`<1'8;]O:^UZ-=*SQ55(0O%][ZAIYPIN:<_QM*V.ZC^T70)L%TB9]
> M>C@<7]?XES$#/YG;2ADR%#)E9G)/P5TZKGGV/E^'CA323[/Q1]S</O__QE\F
> MDI%/"P1\QAD=?>>UC/";%UU'^Q:&HOK*4'RK/_WE[=?G+Z]O;7<!D/WOJ_'3
> M<P%Z^ML&^M<&H^'FUK9G7_]J?OW*4#32M4^O3;<9,F27[;MVZ\ID)1]RF+P@
> MYR:Y%OAV)_2#/=UQTDCCI_.+4U:GRYC3^Y)6A:ED6B(%I79I(+5DGE_.J6K /
> MKU9I!Z=-AG'7K]#ZT[,`JK4NY"4U7`!_WWWIMC5KOYZWZLLE:UKIT:1&7%*H
> M/2Z)`I/"87ID*;DF6[<Z,K[%`4RR\5#6Y*\U_1_&MH*&67[@)1T^ >("NZ4)_
> MOA-+W.`7./`2(_/Z=#$/78O:BGG:O_>LI%F*$JLSZV#V!?!Z+76VO"MIFTE'
> MH"P(E!<!\=GOY=5RM%:!`'_63,SX9:N_VN6WH[8/].CKK^[@H]UGZ+>OGNC[
> MP*M,T+)S]^WS^"=&MM;FAC.&DN^`GJ1%^X2O#27FK@[__ILUOOU_TZ+D$HAI
> ML;G:BKGC[FO?1T!!#V0!`1`H"`+[;EU[SRN1VJID>%!`>\;*!7#<':O8 <P%B
> MQ@ZA="82M('HNA4WD0M@7ALU0Q*2G/4WEA4D]PXU3C*LZ2LGE9`I/QHN@)$[
> M=UKSS#V^FEI?107M#;#3D0<,&+[=FS=.-/8HI-E^8X]`<@$8(4BC[[KAMR^^
> M^OZ?KR9B\7`TT1C2M[[HQK<D%T"@-J!5^NGQJ(8N1I"_$5=K//;`ZC">02BD
> MZ\;&B,DI.+[Q:8K..G&?KOS.2Y^N*8@N7:^$J!NE%9IZ]JRX\@6 EM@I2*0]K
> M9D&U0B*?WS%L67MA]K[ZI_NF:QJT?IVUVJ#6A?8"H`U&*_?NOO;6'9 >UK6[Z
> M\.?Z.<O6)-<E&:N3C'5)1EP2!2;%0KVVB>Q\LEYMN!1]]%V;/,@1D/A;NPN@
> M[=`_LVO_F:T\D5O==-?(;\I,;@)VBQ]BGO9:UI<2I5F*LLR0*@J`>RA(85$W
> M*;]T5])6'7NYY60>(AP@``(@H$2`K>%?[PC0_]5YX>@A@>Y]_,;/[DH*!.C[
> MX&M,SK(+#M3B$5\\TONI]AT!&X[>A!ZI'8O&UX7BLU=%COB^Q7?` <BT2,:("
> MDBZ`\0^>H*0#,H$`"!0,@7VWZG#7OR+5E;[*"MU8'D3F>]+\93ORT<]06O;/
> ME@D8#PX@%X`1)Z0G:`,1<@&<.>C3!4D70&9"/DX^67#DT(ZKG[K+5UVC!8T'
> M:2>?4LAL<%*([?S7[@(P%B+%R!41;W<!A+6M+[KIK4GS-D0!!#H$_1U\%-G@
> M"^J6]C_;;)L=U#8Z)"^`4?7Z$(#D4[UP@``(@(`2@1NO6:GUZ:#5TNG3.E=1
> M&?)!GCUXQ8G]5ZYK6FNY+BG<>]OX-H=JO;8@#ZOQY9/\5J)OO\03&^VZS*HW
> M(@(.O4K_V\8;,I\9$5-\PENZYGI+>2S3I4:RXE)U]B#$VMEV`Z+"YKOBT@!1
> M6R7<R`0"(``"(&!)(":DTAP:^[&;C!;1_U6[8-0`PP5`P;<559L\.IEEK;]@
> ME+'@GUP`B8@_%NKY]^]9>L/AW>*16%-;8LZ:Z!$_A'V'K-"B"<,+T#9?6_3=
> M^(EP`6`(@D"1$=AW2.WM+[31<M7*(&V);RS;-S;F3^Z(E]QG+^D%,%P`QF/_
> M*`C(<`'$:2%`R-?:>-,?-_]T@3&[DZ&03V:UD+D]<FBGE4_<[JNL-/;V)Q >`
> M\?2_]=/PQK;_QFEX`4@)XWFEAAZ)>-Q8"!#1MKUXW%NO_FIR`=!R`&J/L <D?
> M;5K8WC&B\<^2F`N`'\Q/RM*8%P`N@"(;U%`7!/)*H-T%T+5*ZQ34JJK(_J=O
> M(CT8V*-;TZG]EV]2V=K6UFJL2UJVLB4<#7?<I*GG]HG^N_@Z&JNP8KI?9U&:
> MFO%S38\&.KQYF[DU;:.OHL2:M^X2;U&BF"*^9?G9(>6Q3)=JM*S.GK%E[;QJ
> M\]U46N6U)U$Y"!03`3VVT3-$BDEUZ)HM`BR@C`9&\H)Y!.A7+RTT>Z%Z_OY]
> M`W6]_+4=?975=6=<WF'?P^K//<@P`8R=_Z/D`O#%0A0+T/.?<T/O/MM\_]A8
> M*-K<&IO=%#]R5MQWZ!KC:0)M?FW=/&WYEW`!9*L#(1<$LD9@]\$U3[S9W!JF
> MWZ>T%P`%`;1//I'Y;43#&]\%?B.8GQX9D*"9*>-A(#3WKD7#78+-EYZ\Q:?S
> M#1=`AD(^248!C-BF9M6_'M':6@S[/V`\@<#849`]@I1FPW3:CI1>R?ZGF3%Z
> M-1X<D(CKH;C>4MUUF[,N?>L5LPN`10'0$PN2X0W,"Y#6!4!YN!>`!P)DC3\$
> M@P`(E!J!FZZBA0!=M:XU6J>`5D7NS("O@K[4DGOR&U]!1@+ML$S7QJ:F+,C(
> M6/K?'FT43T[1T!>ND6'C9SB7&BFT!P1`P#L""5J;C0,$4A'@PR.YT$Q_KG+>
> M/CT#7>I\-1W]5=44?)N<=J/)/^,WOT]G+H`PN0",300C(3T2B84CS:WQV6OU
> MHV8G#!>`'M6:-2W\B[9X.EP`&'<@4'0$NG<(].C@^_>'R]>N"]-D.3.YZ:^(
> ML?4_L_R-Z2C:)83FX(W?I,;S]^+Q+AT2)Q^T26.K;U4R:C43(2O6:JO:DD( Z
> M![;HV+3H/R^'US;3K+U1H_&,`)U-WS,-C&\G8]=2\@(8>L;I9W/'K@,./VEN
> M0^VB60W"=H"U@4`-+<'U^P()XS49"T!.!6.=0_+@00$DCAP;8K>Q7][)'^7&
> M2[K=`(JNQZ$P"(!`=@F,NZ)>&]2=N0!\U54L!("Y``+DE*3GGTCV_WIUC.U(
> M:8:&OK#8(<1PLM``'"```B```B#@B,!&OJ'UC@#];X'9([H$.G;VUU`40%5R
> M_2V9_[3XE_X9S__S)Z+&<@"R_^F,1O1H)!:)TD*`V>NTXW_1?;]?IT5C6E-4
> MB_Q,"P&P':"C'D%F$"@$`F1.]^@4W'Y`C:Q,>R2\802WWQ)^@8; "\;GUD96M
> M<18C[U[(DLA*VD^4_>)-Z#WJ*K8?[%`3VIID06CYXI;PZK4;/Q&@BAYF:C@L
> M#!63K[2TP/AFH\</MC\1U<2?GH]H+'T0/`+&HP'PR[L0!BIT`(&B(7#S#0VB
> M"X#T-MR05<;>I($@^263WS`L8M>TSXB-%Z!HV@]%<T(`7J&<8$8E(%`*!,Q >
> M@"5_]2T[=3M]]0JMLCI0::R_34;>)HQG;ANS;?0L05IS2[$`Q@Y@OICQ7$#:
> M#K`IHB_O-N"X3Q=LY`)8^.6-=Y]2"IC0!A``@2P16+_)-1-OA/8;#@:*ZM]0
> MGR^^8=/^Y$($RF;<IN\DGHGVR-YPS:;J*3Z)NP#Z;=))K_#[V%995,Z(!6`Q
> MMTE?0/*_]K=,#V;DLWJ300\;#FF?@"QQ@5@0`($2(C#AMM7<!6"L:ZIHWPO`
> M^-JA0``_N2:300%TK%^ZRU<!4)HY"@#&7@F-#C0%!$``!')*0%XAD@P$.'?W
> MMCOV^_5_%Y_45+^DLH+BTWP)6G^;2"0#9^FW<SQ@;,$=]],CN6DKL`2]343H
> MJ>!]!NS[Z*0;/AK\^+O^#5$`"[^\[J;C<MHD5`8"(%"$!)AA;_P8)J. </(T4
> M\F\;XDH6NI\6)S$#?>,I>7).LO1X-!I?T[:BL<WWA_._A@N@"$<%5`:!TB&0
> M=`'4:5UKC;T`:&J%'J4:"`8JDM]6O@JMBAR-E88C@!VT60G[%K,*.-)UXZ[Q
> M-%0<(+`Q@3C-TN$``1``@;0$VH/_VZ?AV!*S"CU^YEZQQR[HE+:TF&'IROCX
> MYUO^]I$O&J(G=2?W`J"%`'`!.(*(S"!0K@2RYP*8OW"5KW'YK'(%BW:#``@4
> M!($>.[>UNP#\(8V>"4A[K29_<6E!GT:/7J6-`2K7V_^T_\J&HS(9&+7104\$
> M,)[/1,%)<`(41-\6E!)P`114=Q2",NMMO$+0!3H4`@'ZPT%_@(PG>M.N7LF=
> MM,FMS!;?&KMJT<.^*</Z?6>,Q6KK#WKR-CD.*NAO5M#(PYP(M/A?.MA >``N_
> M;/SI]X707.@``B!0M@3@`BC;KD?#0:!0"+2[`$B=KIK6W$A3_K0*J7W'DXIJ
> MIJ6Q_7+RT(TP`0H6X$X!6ANUT0:E\MM":27T``$0*#`"8;@`"JQ'\JY.!6D0
> MT*)6`X/"TU@ROTG[?]->V?26>Q?)1T`IAJ<@^1>*=LNF_6O('<`>,EA9K <4[
> MP`60]TZ&`B```L;O:D0!8!R```CDE\!&+H#0:N.+R?B/OUAKMV$ =`+M*/A "E
> M_2*_[4'M!4D`6]469+?D4ZF-?8?YU`1U%PZ!+.YH':K3:$/OX!)Z(D#C#Z, *
> MI\G0!`1`H`P)P`50AIV.)H-`81'8]'!_E]UZ-*]8O7ABM+`T@S8@``(@``( @
> MX!&!'L?XM:7?:LV+&G\:[9%(B`$!$``!-P1,2VG="$$9$``!$``!$``!$``!
> M$``!$``!$`"!0B=@$04PY:./):U'[K\?);)7ND47+IIE*9;)D<2RNAQ5P84[
> M+>BH%C%S*DJN^;C6Q$:K;-`0&YX-^>8AX;1S78P?%_#YH,VP.G>?*1 >]D*&>
> M9D321R"3P8`H`!<C$$5```1```2*BP"B`(JKOZ`M")0P`8LH`/93GE[9R1K/
> M$UVSL!0K"N>2>:5F,SM5[9FK)UJ>*FVTH:12W%$>%QQ8W]D45)<IJ2HVW+60
> MM,UGM8CFL;J%J9[3M?[,G+8GG+:-EH/?42E'.BAB46<B?034"RJV$=E```1`
> M``1```1```1```0\)Y!^(8"BY>!4LRR)=:J&5_D+LSF>V*A>(2I).879[R6)
> M&HT"`1```1```1```1```1#(G$`:%P"?V3-/\5&*ZWD_L:!9#KLKOCIJ)R^8
> MJA:Q1C%SAC5*2J:JA37-1C<I@VNM5/0Q*^,(-<]LV8E2/[H8+98N##-8IH;E
> M6.69S:,B$_5$Q<2@%<5NM<'ECK_X>3$/:3.?M'JZ5D,<43;P,Y&/LB```B``
> M`B```B```B```JX)I'0!I#*TN#GA*`@YE:U(M8C+#41#SG5L/S//1/7$M]( M
> M,;.+&LVVG"4?2:54NE%9L_(NM#*/!G.K+>M2'T:LX3Q<7QH,8G7F%JG7DK8A
> MEAG$P<85LP$KP5%43W)/V`PY,VKS9R>33Q,?(1)V:9A9CLQ4`T,1`C?X^6!@
> MC67%Q0MWD-750$X0``$0``$0``$0``$0``$5`BE=`*)E;AGMG,KZM:]5,OC -
> MF;,16<VM-6ZRNIB1MFR737/4^:CG5.G15'I:UL+(N*`A#8^T0M)F4&R:I##O
> M66Z"VHP?F\:Z4\_L!>`D5<!F/M33?IHX5;&N5"-!L0ND;)ZXJ-Q5C5(@``(@
> M``(@``(@``(@``).":19"&!O4*E;()9F@U-=,\DO6FM,[<P-,$O[2DQ4K,5S
> M?<R@S-$6+$^J=$>HS4*X`2S.`RO2,`\5T4/A2&%)#9NR3KM`,O69SJ(01WHZ
> MHIUY9J>-35NCY`I)FQ\90``$0``$0``$0``$0``$\D4@_7:`]IJYF$#FQF?.
> MVLR4-,_9>JA`*@[J?-1SJJLMAF>KE\H\IXW'(7/AECX"2X>.4SO<41 <49H^K
> MXY7T=]1V<RWP`JB31TX0``$0``$0``$0``$0R",!7^/R65+UX@QG*G.=_^)7
> MGTLWVQBLK&B?2W/U_%9:0.9961M1HEBIL2YJY+JIU&AV1D@DTV9 PY)&1PK^Y
> M'T2L5.+O"#7/G*H368UB+Z>5+PTY7IRWQ:RPZ.FPG)\WJ\&*2+0=#6;S1T`:
> M/):.)S,-\VA44</F0RI6P1O.NL"R+U*IG;:G[#\[-B-9U(K5LNGA_BZ[]6A >
> ML7KQQ&C:>I$!!$``!$``!(J10(]C_-K2;[7F18T_C2Y&_:$S"(!`R1 "P<`&4
> M3-O0D+P0D$(/I+<Y4ZE`U,A9>]-6E*^.2*L87``JB)`'!$``!$"@V`G`!5#L
> M/0C]0:!D"-A%`?!&JDQ+IB5B&6GLB62J6A3NE<RT+3)G,,_-NA "221%+R"0P
> METQ2A7LX:I<G#<GCJ)#T]YR_4\C9L/\]Z2,V*A`%X.C3@<P@``(@``+%2``N
> M@&+L->@,`B5)`%$`)=FM:!0(%!,!N`"*J;>@*PB```B`@"L"<`&XPH9 "(``"
> MWA/(=#M`[S6"1!```1```1```1```1```1```1``@2P0@`L@"U`A$@1```1`
> M``1```1```1```1```0*CX!/U_7"TPH:@0`(E!&!ZEWGXHD`9=3?:"H(@``(
> ME"4!OA!`;[R\+`&@T2```H5"`'L!%$I/0`\0*%L"V`N@;+L>#0<!$` "!\B&`
> MO0#*IZ_14A`H<`)8"%#@'03U0``$0``$"I1`C]/BXBEJ2>EIE69ETV:SS. "Z
> MH+OJ4`H$0``$0``$0*!D""`*H&2Z$@T!@6(E@"B`8NTYZ*UI9(HW/A=@),1K
> M138NBKBN2U$E9`,!$,@2`40!9`DLQ&9(H**R0^>NFV4H!,6+A<#*AMFD*EP`
> MQ=)?T!,$2I8`7``EV[5ET##)AG=JTCO-+]K_[LJ609^@B2!0H`3@`BC0CBE 7
> MM43+OWG-HFBDM5Q)E&.[L1"@''L=;0:!@B*`KZ&"Z@XHXPD!'JC/H_U3+1G@
> M5KVY"-U27RR@GM.3!D(("("`8P)^OQ9K<UP*!4`@"P28_4^6/\T)TPG[/PN,
> M"UHD?GL7=/=`.1```74"/7IO36>[096\YF_5A2`G"&1.0#3F:9D`G7S&GK\5
> M:V%W639*YRL+6![IK:5ZDH3,FP`)(``"(``")4F`C/_NO;9B]C\L_Y+L8I5&
> M82&`"B7D`0$0R"*!S0[W=]JM1_.*U8LG1C.LAMG\C<MGT2M=LPL<()`Y@ <7U
> MRS1MPS-T^_7MRV2F6@C`TRTW"S#?Y5X#:6<!RVA_<V:S)HOKZS-O-22```B8
> M"/A\/GW3/NW?`([X]#@NJ"WX3&MM;/QIM*."R`P"GA#@D?\Y-O[G-R:^GK/L
> MM^5-GK2BE(3TZ-)AV%9]MMNT*O>-@@L@]\Q1(PB`P$8$X`+`@"AP`F1.^_T5
> MF_3N8=8SK0M`-,XM+7\Q1L#L+S"[`&PV(,3N``4^D*!>:1"H;VB,QZ/ <#ZC>
> M*+@`U%DAI^<$>.1_CF?^?UP27M(8'K']H$%]+?Z&>M[,XA+8L'KM!]-G;=JC
> M*O=>`"P$**ZA`FU!``32$*"9?W/\O[1&P+#*UB\3D-8+F-^">)D36+)LF=\?
> ML+3_)3*6YCKEX1'^CDB*KH&T!?D*`AX@D+8(,H``"+@CT+=7CT"@DKX9W!5'
> M*1#(/8%\V?_4TJ]G+SMP^-:P_RT[O5==)X)#B'(_)!`%D'7F';H.^GGNS/"Z
> M.2V^SM^U;-VYIFKKWK6[]^^R=N7<K->-"D"@D`A,?>$<2W6.?_XI#Q <",!<`
> M?V76OK0T(%6*.;V0^$&7_!"@)0#]^O:QK%NRM\48?I9?6MXO!?"+;T4;WN8I
> M@^8BK!9CG%OM(Y`?9*@5!,J`P))E]4Z7`R`*H`S&12$V,8_V/^& X][6?)YQW
> M5"%R*1B=KG]LTI^/WB;'ZEBX`!J6KOIUX9*]]]H[GLAHS<8WKQZQRS%O9-Z >
> MGV8M5Q>R[=:][3.;I:4M8BE0D5*BNM>OW_Q]6.>YOU7O_4M\QX9(M\:62&-3
> M\Y".JP[??2_?NE_5FT8Y%2OE,D6+*YXP(CZB"1^]AN/&*QV'C'DDK0).*VU:
> M\NVEL[?PZ0F_3_?[?`E?X-ZMYW7NLV/:BEQD4-?MR^4+/IS[UHQ%O];$>_AJ
> MX\-Z#]MOR*[;]^CEHE+%(NJZI1(8_.\?G_FR^^!!/:JJ@T.V[-MI^Y/35NVT
> M4D\Z2[W2#MVWLFQ"]Q%SL^H"H$IY7("]+T`,'\`^`FG'6YEDH%4`+B)^+ >$X
> M"M1WE+E,^@+-!('"(>#BFP$N@,+IOO+1)&?V?RJ[#RZ`M(/-0Q>`M "4659WJ
> MUZS%0H!?%_XZ9]:W77M83WJD;0;+0./@H'.GT:MB?OMLNX\806?//GWVVIM <
> M$_))Z2R#8EU[[K47/RO\(7(*./(RL%I4*.F1M3.FOM"U,OQC]>BE-8?6U0W8
> MJG>G_G6U/;IT'M)AZ>?3WJ```46=U2N5!!Y^R2?L/.*R*70>>_E'=)YRU8=T
> MAF+&Q%':0Z6E7,@?/VJ^:-:6UW6?^OK)N]Y\8&+,(/V@S?7+WDH \^-IW:2MR
> MD4%1MX>_>'OBM.?J!GURX1';'+Y+UT,';[6F;<Z#GS[Y\6\_NJA4L8BB;JFD
> MD?T?[M#O3^//^=V8HVNW/FW.7*6=O1Q5ZE5G*59ZS)W??OS3DD&[G:X (,)-L
> MTEH`-K>O:-*SG(J9,U$29<N-`)NE5PG49X_W4WD00+DQ1'M!``1```34" >32
> M_G=G][W]P+[F4[V!R"D1X!-=E"Y>FT%9N`"&[W[0GZ^>H,724#WIK]^? <N_,
> M4^__X91[9ISWR-QQKRQ[9$KK]PU=Z9SVXN'1J/%;AUZGO71XYMV32.@)7:^ O
> MKX];'93.,BA69&1>?_;NTZ]KYPKF"%`LSK*I4&K\[0,MM.PS_;!E@=U[=:H9
> MW*VZ5Z?*[AV"'2L#?;J$]@X]/./;5SROE`OLT'5P6\\]IDY_^;]?OGW/1[\^
> M,77QI_-7AV,)1S4JMI3)/..#-6=MKMV^Q2];[;RGIOEVZ+G[#S']X(& )X.^V
> M^*RI:L(;SD(>5/14Z87Y:U=.7S9MG[[==^UPS>$#;ZSHM79%Y.=!W>N&]^OZ
> MCZ]?I[LJ%;G(HZ);*K',_N^V_ZE'_&65'FX;-F!N.)3N`ZD\+#WO+,6 6OGKU
> MSOMNN^F\:<_2!_6)EZ8^].PG=-[QR'O7W^-!K)"+#K(O@J<)>HX4`MEC_U0,
> M>\5L0`H"(``"(``".2.PW]BW][ODW7TO_>^^EW^R[Y533[EZ\OV3&KZL[Y&A
> MW<=G*^EBX.#MJ3FOW[=?SAI5>A4I>@$L7``5_J:5#;-7KIIM#V6+?7;?:M_=
> MMQNY^]`#]MKMP.&[[[G#;KML,7BSNC7_V?W0/[YRZ!]?]846'GK6JX> >]?(G
> M?S\D0[X).N*&[1HW_M]^QN+M%Y3.,ZA4I"</HT@BL6G_+8=L.WR7W?97*2CF
> M4:'TWZ;A\ZJV[>E;&O`EM$0+%9_UU1>S5[[0W/3:1W/^\\HRWX?3WW=4KTJE
> M3&`BV/.[+QX^<NMUO3NNU6KZ]>[<85U$>^>'Q2]^^ND*NM*T6"P6CBMM!JE8
> MZ;3?UD1C^A'#AV\6UQZ<^.B*AADK/O_7M7N.F*/1:@"MNO].;R[S3Y_VCJ/V
> MILVLHMO#7_V[:Z5_1?.:RGB_2E^7T[?]OWZ#JF<VS%B^IGF36M\+/[R7MA9W
> M&51TLY0LVO^3;JB)MZY+M*Z=-[]110W%2KWM+,5**0K@DY^6#-[]](2 NG77B
> MB`M/VY?.*R\8=?/EWL0*$1]FMXM!4`P:"PK@&P1P\UZZ$#/P*`#X`E0&'O*`
> M``B```B```@4#@&:_^_>:ZO.73?S\/E_B;Z[GW#NJ:>=_X=S+CSADK''GG7E
> M^;\_>I_0>\,._>/+9.[IK0L./=.X<&3WQ1+^6$+WG?!H+&Z\5M9V'Y3T`CQ_
> MYT$23'H:IWAD#[6[BJA4]E1R)%EQ+8"%$4@K>__WOYD!?Q?[^G[Y=-KL3Z;]
> M.&7:C`\^__*CZ5,__V':-[\L6+*F]Q%?O7CO82_^]7?:VN]>NO=W+_WU\'W/
> M>-> 1ZN;,-,-/YCJE1V-Q?E)``+LV+-[DH5@+.1&^F_G3U]_._'SJ]`^F?#; Y
> MG0\H1;$LSY:6$NT"\'%#]R^;A_X2WL*W9EK=D@=;&MZO[-7Q;V\\_OC4 >Z[_
> MY+._?+7HW97-CNI-6RF39BQ`F/XB+4#XI?J@A97'=*[;/+D`H;I'Y]K!'1= ]
> M\>6;S>M:HE&E6662IECI8W.UOQY*V7VQ05L,WS[QW_D?+?`O6=OX_2/O+_3-
> M"W9=WC1\96C!;_,=M3=M9A7=EBS])=X2HX>1MD4-+TQ0JSESVT=_M\>. <3VL
> M^3HO6.:Q2NHCQ+)UW/ZGNZ_?T"'1NHY<`*V_3A^SFU*T@@H0DNQM9RE62E$`
> M>VZ]Z9QIS]*'[>F7IO[?LY_0>=?_O7?3/:^G[6C%#%(,OQC,SV/[Q3SVB:Q2
> MK`A0A(]L(``"(``"(``"!47`0_N?VN6OG_:OQY][_M%_//GP2P\\],K3=S_Z
> MYFN?5H_Z^L5[#Z=37_?#2_<=GM;NN_O16T1$D;@O$M-;_G%N)&Z\;K+/^(K:
> M[EMLL6UUP+#OQ(.F;PT;9_WAH<DMB7)7$2N5]T/1_C=ZTZRKXLK>Z[;X^WTW
> M'/?7ZXZ][Z83;[YL](6G[WOL83OW&]ASV\V[C[YV8;@MIK7-#[7%1NY [@B4.
> M-BG'3WMDR2``PTJGN6MV).U_XY6N*9V%!M@(80O^Z>S4I0M)VW:;(3OMN.WN
> MN^Z\[]XC1AVT'Z50.L^CTG]I*3WP]GVM\41S*+J\5>_8.K>QZKC5D1W>6=1U
> M1?3F1XZ;2E6L""WM4'M@9.;"^8\\]\&32K'0:2MEFO,%"+\%]NG;N6I0]QIC
> M`4)M1<>JRGZ=HGN'_V_F-R]'HY'H^DT![=NK6&G`Y_/[M.G+IO;J/6ROS7Z_
> MP+]P07#Q=9<\-/C-=WJ_,K';EQ.U'YY>N#!EW(&C\<`55M%MY:KX@B4-O]6O
> M:(VTLH(^K6HS[<AY2WYK6-7:I+>E[>[LZ296_?$_;J?S_65;?#2[POB. "X?B
> MK6L3+6O;?OVJ8NV\V$%/I=63,J@`H6R6G16LJ#DJ.%7[Z&HM&/0 %_3:=)6FB
> M6"E%`7PQ:\F09!3`Z<>/./>T?>G\\_FC_G+YD2I-4\DC]93BUXN*9.0!`1``
> M`1```1``@:(@D*4M`"[?[M__>N*2?SW^IW\]>N[X`WZ\[Z'+3CYEGP&;=Q]Z
> MV1*R^R@*@.R^4>=_:(](]^FB%Z"AI8H6*=?^X?':4Q\/1Q,=__#XD$<WW >3`
> MAY:U5!<(:K+M/70W9+M1XFY6]CM;N=\+@"(WJ!D]*C<ZNU9H`2T1\,5/&3]3
> M\_E/'_^Y[K.V^J0).GLB9.JS2?XU*Q:S<W7#(OY*Z2I1`&S+0+8+P$\_S_GN
> M^Y^F??7M)Y]-?>^_'[-$1WL*IEW__,7<Z3OV6AA/K&P++:I/K(UIL5_JU_RX
> MO'G>LN95C<:,;L_J378<M&O-1]/6/O[JDA]GJHR)M)4R(;0`8;:^/2U`,-XD
> M6H*^Y`*$QG\VA?[=O@#A^RGA6"P:5]H.4+'2@$_[<+Z_.N#_?L4W'\U[?]M@
> ML+*BBNI_Z!]/T+G53COTZ-5[_K>_I&JFH_'`A:CH%M6B+=5MZZI"9/JSX]T?
> MWKOPQ6N6K(O'*J,JV+.G&Z^=C/_-]OQ3OQ$7]AU^;J^=SWSVK\^1_6_ ,_\^;
> MKF[_DS05()3-LK,>_>":_E7ZYEMM10]RH-4;\^:K1C0I5DI1`+MMO>E/4XTH
> M@&?_/?7QYSYYY.\?W_OH>[?\U?LH`#[5CXW]5$8X\H``"(``"(`` "("`"@%F
> M^M$AVH"'CUO^]"/W;S?LF+02?%K@T-%'WOW8K2QG*.8/Q?2E3_Z1SO:+I_X8
> MCFGAF-)J92:$A>Z+UV(*SR#FD1(5C7Q+L;Q>WG:>S7R1ED_.,E@\%%"Q[JDO
> M7SWH]$D]:1#X-!_%/A!YG?I`J_)'@C[::SY2L6BBOLD?OIXT?M!^UZ:2R9_ "
> M;5,I3<YOL]T.E&'UFJ;%BQ>:<_;K-Z"NJ[%LX><?9Z9ZPA\)&;;KKJ3A3S_/
> M'C)D2Z8O.YAW9\Z<N=MN8SRQ[.OI7[E[3*"DV#/?OO?&CR_MN\V0P;VZ]^[ <
> MK5_TT%]75M[V36NGE4MN]W^[Y*>9$S;O]=>S[QCQS[_][]$G9HP<?OI]URN2
> MM\^FU_2XX+4EG6LJM^E1,;1VUHX57[;5C9B[=I,;7AJSKKIQY9IXK*5BZ[[ #
> M7SS[P1<?.7?,V'L]J92$G/=1,[E1#J*G`?H#[RU8/&K!,X.'5$Y^L=.]SSY >
> M>?)C<\Y?\N[TGK._F]G8L'SB/^[.9#PX5?BV_[WPY:_3J@.^B_8]_\B=C_C/
> MS'?O>W]BV!^JZ]*M>5ULY&9[_6E/I1TK5<:J4]U8?F;_TT4L$HN$P^&V <*0M
> MM&#:,R>-[.3(_E>OW;*SYBW0%\Z/_N8_QT_+LGS^0?J'5UQQKKK,M#DI "N#:
> M,?N,&7/M#_][EF=FG\3^>WGV4,"T:B`#"#@EX.+17TZKR$;^A]ZR^'.9C8H@
> M$P1*GL#8T0/,;73QS8"'`I;\4"F$!F8I!(":]O+#9^USY>>]DJ;??Y^[[J!3
> M;V/6'S]>F;#7<7]Z6H(@/13PKL=N_MWA1U&>=]Z:=.7Y-]YV[>]/OO)E0Z*N
> M#7[JIWEG;\.*OW#/<=?=]J8D2C34>>`]);+K5!<\W3*/F,BK$XOP#))\\2TK
> M:*^&946LH(</!50?@18N`,6G?'_\TK5;G_EJWRJCZS>8TQJY`*(5OE#`%P[\
> M]F2LWQF?/'?53H?=H*Z0.2=9[T.VWI;UNMC?4DZZ-6?63S8N@!V'[DQ%YOX R
> MS[#Y#;^%,6J-?^N/(5MN3I??S_A6Q060EE*G[EO^[;__FK;BLRTWJ1Y4UVU (
> MY2$+5U7?\J/^N\;O;_YF\N,_?QVZ\[GI>I<;IKS4_,;+7XS84<4%D+92TO^^
> M#_[Q7<L1U965@[IU.*;C6SOV63W;U^>#W^9]\=N4.?7+R`6P?-7:P[;YZX/'
> M'O32DY><>^D]:;M&I5(2\M7BM4_,U0)#*.S#KWU0->BWZQ/!JK;Z+A. >>I3Y
> MA[Z<,F76]S^2%V#<?5>DK50Q@XINM.?_->_?7^%KNY3,;)__YK=OC0<3?;OU
> MC":"_UB\_;)E"UA=??H,C%UPDF*]*ME4=",Y9/\S:9OL=GZ$CK90N#4 <#H47
> M3W_NC-U6*L;_<WT4*[7L+)]?#VC]Y_L.I,X:D'B__P#_B2><YV%+292OSO "R
> MT?'\OZ>&0I%X0J?FMK2T/?+RMIUVZ]&\8O7BB4IQ&2I:(0\( >$7`Q0]]KZK.
> M1`ZY`,:=-2H3"2@+`B!`!,8]_1Y<`!@)Q4(@>_:_\>/M_G,.ONZ3OA2AKVL/
> MW_]P_Z[RP]16SY]RZJ5/2*S,+H##1U.P`-G\^N2W)[7,^^K$/[_4>Y<CEW_S
> M^K9_G_73F*W/>./,OQ_QMY?^>N*X.^4H469UF^US7J.E$>ZA"R!51<9/W'2 >
> M"#&/A"@O+@#W>P%$DD^5IXAB=E+L,+U2S#E9>WY?PD\;X/L"";UR9;.Q_WR&
> M!VT'2$L!C,4`"?W+Z=_2.>VK;]A)B<:6`,:=--LPT`9X=`X<T'_0P`$#!_:G
> M"WJE:WZR#(JJIEW_O';EW.-VWOFN8^Y?W7;^7S\YF/:>8T<D%@^M64<7/S6$
> MOET2:HTXL'G25DIB:0'"]GT6Q?55;6%C`<);J[1/EOW8I,WE[>I=/7A@WZUI
> MMMFKEC(Y_?5Y<>KY7_V!>5IPR_B<P6=O^[BQP4%K--'E],=;H_K!3\\][H(+
> M%2M5S*8"9%"G[A<./RFJU_SC^]>?^^Y?F_09T+_/P-9H8-S(RQY]]-$M;[V'
> MG72M6*EB-A7=2-3N/>8<?>Z.QUQVX8+/'HZ%HM%0-!:)Q".T/:KNU/XG:8J5
> M6G;6PL#9\_T'T0=XH/[^S[-\(P^0]V)-U7#%2BD*X,M92[8=8>P%<,IQ(\XZ
> M==]S3M]O[+FCKKW,L[T`%+L&V4``!$``!$``!$"@Q`@P^S][C6J-5GSVW*W_
> M?F+"OY^<0+4<=>;-_#SZ+..Z+6KL9F5_D,GH]P4G3WXMX`N.'GU<[:#ABQL^
> MI2+AN&''T=:`_#65'//B?+Y'8+K*,[TO562Y30!+E/P4F5:<A?+N]P((K7 <!
> MD-G/C'_F"ZCPT[/F8K[Z27J_D^/^NI:PZHIBF]8EMP,TS/SIW\PX[)`#^+G]
> MD$VG?SV#/^'/GD\X$E$Y%2$KKG_VK?OUUD,'W_:[05IPP[86_@K#>U+M=[QU
> MI$JEA^\T^HLY?]VNU[.[#)Q<M5FPTZ:5W;K[JO7`T.J^HVJ/[%MU0-^Z'7;O
> MUS5,+-2V`U2IE)K3>[.=S@G\-^H/)!;X](5Z3>7@]_Y$@3V&"^#71\[J^\@/
> M]-H:<?SD!?ON4-1MO_[;W7'PI3T[]EZZ:C4Y(WY;MN!?]3MTNN>)HXXZ=.X-
> M5["3KAMONB/XR(N*`R!M-A7=0N^>N<DQQ_EJ]]:T74^Z^KF%_WN<=FF,DI <H
> M+N^#FK8ZED&ETE2=11];\NL.3+P_:[;OG',']^YA!,6H'(J5TEX`NVR UZ??_
> M,_8"^.?+4Q]\_+W;[WN=ONHO>_,<E5J0!P1```1```1```1`P)(`G_^G)[M'
> MUV^`[2VKEFAP[]-N./7<Z^GL7-TB6G]DV)`EN"ZBL,N8GJ!-IWTQ_<U)+P3\
> MP2.//'G&YU._?N<*,OZGG;0E.0(F'O(4<P38'):VM^)Z?J=,S,8\JXC'ITOU
> MLOP%\H``F\:ZWPO@Y:=OWN>B?PSNT+X(A.W"X//%@[YF_])_Z9L<$=.[4Q3`
> M,W?]X;BS;G2*6\Q/"P$&#-XR*5R;\=T/_?OW9W=7-M;3:TMK=.A.V[,(@(7S
> MYMHL!.@W8+!9#7._+EXX3V4A@-,6K6JJ_&%9*RT$.'#9MS?_;](SO_W TTY6/
> M?Q#J^MR/+\?>>5UQ(8!*I5U[;/',)R]^OOA_V_:NZ=>CSM\6KERYI'MH76.D
> M[NZ5IT>C+<.Z1?ZX0V\2-?G?XR^Z/.6R?)6ZS'FF??'F$Q\<4A'\)5`1H!4!
> MW1>]?MX]#VTR_,CNE]RY:[<[GS[\Z<>NN-C#A0#NE*12/YPQ9NBA1SUZQ_WG
> M7W,I$\*N9[PS:?N_/^-:K*."HOV_ON!7$R^_H\<VQRV;^>)IUWO<-6D[*Z'Y
> M!\;?,^S_\S8?L>O!CMJBDIGO!?#=%\^*7^U_>G',?R9>[\E"`"Q^5ND(Y#$3
> ML(SRY=E2+01@C]ZA@W:=%*\E^>(3>G()7UP((/U`R<M/$Q[`21#XKS=1$VFY
> M7UI6YF693'+:@JDR.%7`IB*GHISF=]U&3PIZHJVB$#YTS>M^/6F+BA`L!% "A
> MA#QY)Y#5)0"L=1/&77;V79,W)]-/TQZX_X%++KV$;0-G+`FGE=4^[=J+#KM^
> MW'T2"O-"@....N/EEY^Y_,(;[GS@QI-.IFVG]%=>>Z[IUZ]YP6!REE1:""!]
> M&XC?(:E6BYO7C_.5`JPN\6VJQ>8V?Z?,7@#)-R'^L3-_F_'VYF4A@/N]`/[Q
> MV*T'7_;<%LEQD%Q9K_L33?Z5%/N=T'L=GM"[ZGH%C89';CWM#^=ENA=`_T%;
> M,$S?S_QQIYUV9-<K&I;0Z]+ZE3ONL!U+^6W^+S8N@*;6F$W`!N^&+AV "*BX`
> MQ4777.R:M=7?+UV7H0M`O=)$AT%W3_GMLWDKC@[^^\2J?T]<=_YGO@-(F6[A
> MF;NL>B^0:%^=H>("4*^4-;:Q<<Z''[[_VV^!^?/]/2N;3[_C@<U'',U <``\?
> M\M2SUUSBH0O`J6Z\.\@%,'7&@A%#!](K2V37].J5"R"M;O&53_3:AAZ9N >MZ
> MK;[26SY[\/J/:92ZMO_35LH)F#MKT&!ML_[Z`0<>W+.;A;-,*BB^5:\TTJ5]
> M+P"Q^&F/GO3%\[=XY0+`XF>;GL(M2P*I?M_SS#9[`8B[A-KL&*JRF:A*'J:2
> M8DYI+P#+Q9"9#PD7L8[F!9-<#75IW*$@_3B3%H(Z;:"Z`JDDV[3.7AF;JC/7
> MRBF'M/D55;+/YD*(9;^GU3;##'`!9`@0Q7-`(`?V/[7B+S=<>=&];PRI-1IT
> MQST/7W.%L95U^Y'<&6[L>4?<>JL\@R6Y`/[ZZ*W''W/FXP_?0H'H <5T_]Z(;
> M6;CX2Z\^?>7Y?_&$E>)WBR=U24*DJA4UR8L+P/U>`!55-5/^[]R_/_RGKZ?^
> M._+;0\$53_M7O]<0V_:3C[]_]*[K[QYW[CWCS_SKN#-;8\',$;-G_K'G`L;;
> M5K+SEU]_Z];)B*X7[]K41<'5W>KHZ&J<7=>_=NW:C5+I;3)%/0!; <?TSUZ<U
> M%%K5W!KW!RJ#1I!,1>>Z4&+#$HGE,:7E$NJ5^EOGWW+HX)M_MU5@TP-O\S_V
> M<^TA!VS9:\)A6[_ZYW,NN6P"6?[L5.D:]4J9M!X]AIQPPI^NN.+\AQ\V]I,G
> MF_^FD?TO^N[AW3_J2-<J-:KG<:J;*'GDR*'TEE[9R:[5JTZ;,ZUNO@ZT/R79
> M_ZSK#?L_MG1-)O8_24E;J:2VV%E77'[NB<>?Y]3^=U3IP]<?]?#U1S]\PU$3
> MZ>(&=AZ]MBF4%B8R@``(@("90"9S_N!9O`30[\7;=]`\&P1R8_^3YO2@OK] >
> M?-1Y?S3.^3^_SR[:S[.-BXC"D_SB/GIX?,4%8V\^;^S-?QI[<]`?I.4``7_%
> M*<>>=_>CMV3.ATVV2[%OF8M5E,`W`B`%%.U_1<F>9[.(`J#MV_KTZ4/K@E >N
> MFNUY?2X$TD(`]5(V$_B*<E1"`$@?IY3>^WSA_!6M,]LJ-V]MV&?Q[/G]-IW;
> M<\C2EMCA*V;%ZY?6G7C$7D.-X'S[PVFEZ>0IW<]+I4J:.>\%+I;6_,^8^HZY
> MEJ$C#O7JN0!YX5:DE?8[U-=YCYZ9/Q$`6Z`K?G"03220C2@`*?B?S=OSQ0)4
> M.[T5=3"O*6`91#EB<2;!/AQ`,0K`'$O)%+.)G[3<BHF5,L^!JZ1P%)91WZ(R
> MO!912:D*48C4.G-,9JIFBKTC:<4GHNT54VP+@V;)W!RP*C9'A):J7:E4Y7)L
> MVL(52Q4H:Q-`FU9S<Y-MOI3$_I5`\2$GD4DE7VJOS?!0^8IP\:P0/!00?WT\
> M)Y`S^]^UYE(4P-V/W=RT=+%..XC3(H+VA\K34M0`Q?XGM#@]6OSF6SS>G]NU
> MYCDKF)<H`/=[`>2,"RH"`1`H;0+9<`%(#N#LS1J)%:G48N\5MOR)7]J]G_?6
> M9>@"$/7G=KOZ!2_.W00NREHR-+L`>#;SLNI4AKHX7,UY1)N?&^=2*+[9R+24
> M8UE<,2<WQ<V^`$ME1+6Y>JE6$-@3,'^<TY*4BJ3*[TY)=6FB\6S9=LGP3M6M
> M8KIBVVVZU7(D6W:!F#-5OYO'IYFJ?0JK!0L!\OXM#052$2A\^Y\T?_+=7\\ _
> M9O\NM37H1TL"32UMC[[ZT=F'J&["[15&BX4`7HF&'!```1#(%P'VPY1 >V2%Y
> M!#+1RM*YH%Z+O9M`Q8F0B?(HZSD!LMC9*4HF>UZ:M%>O5RK+9OL5U__;U\(_
> M%)+YY.&G0_JL<=O,]<`F"?;JV4NV*9Y6LGJ7*>94K)$QM&QU6@DV96V4M!0K
> M1A8P.UE=)7.GI-5<D:&'V=RQ\E`!B`*!3`B0\=^]UU;T",#F-8NRM/]_)NJ)
> M97?9JN_D+WZ87]_HE<!2DM.P>BW!(42Y;Q2B`'+/'#6"``AL1"`;40#L-ZMY
> MMC-S]-(DGEB1^9:+ZCP1XJ+>LBV2810`-_ZYE6XVU\VW4N6Q-/4MEQ6D[:]4
> M"P'L/Q<J$ZHJ$E@>RYQ2%9(_PG)6V=Q8%<GJ'U45E2P_Z2I5F%'8--FF%IMO
> M!K/^-BFL"GI-%?A@5B]5,Z5TI]D4O^O2?I.K#%K>**>LJ""B`-)^VR!#+@FP
> MF7^JL?"-?XYE?F/BZSG+?EO>E$M015%7CRX=AFW59[M-JW*O+5P`N6>.&D$`
> M!/+I`I!^_G)51'\!2Y2L$5%I<9K+\C>E97'1*.)3:JGJQ2C)#8'LN0!L+/^T
> M+@!'92U!J>P%D-8<LK>T17LUK=UH;Y2RXJEL.1M+VUR*IZ1MG4U.WAP57X.Y
> M[>IM\59)=6GF!J:RYRW]!9)?P_)M*KPV#A?+D0P70&Z^"5%+41`HBLC_HB`)
> M);$0`&,`!$" @9`G0;T=V2.$`4HRK&,;/,HLIW&YGB=RVEW[W2[]KQ2JX3&[ V
> MFVOA*27;&277,#8Y;WZ50O?%#"Q_JJA^OAV`:/^+V/CB`DEF6K1LX/'AQZ]Y
> M++3DTN*#F6<0A[>E*'L=N`+F"ZF@^(&U5(_7+C:*E1(5XT:II>:29/&M2(E]
> MV*6O$?%3+*%@;>'*\*:9E>&WS%5;*F,C06RX5#:5JKQ%8@/%,2"E2[AXC388
> M;=J>JH&60TCJ93-P<QO-728J8SGXQ2XS?UC2?KZ0`02R2H#%_+.S* "+_LTH#
> MPKTB@"@`KTA"#@B`@$L"65T(P`T`_NM<_/'-?@Y*L_V2OT#,(UUSF9(%E:H*
> M7ES4BO^X%]5PB1+%G!/()`K`:6V>+.E7K-3=`S*DSXMB7<A6+`3,WX>2Y5\L
> M#<F!GIQ5-A8"K)I]E*_]D<`;'!3&U88G1*]_4$3[?2G[QG>3[J^-F:S/T)XL
> MWTW^,=JXZ@WEC;J$`AN7E02+2@MUR<5-=:U/2/[?YJ[\R&RI#HMV"4VSNKNA
> M0M/=%#JMUU#2<J/<IC98MZO]-\/&?$U]9S&ZBRCF/P>?353A "0&X`#S!""$@
> M``+N"635!9#\-6"W*4`V7`#2KVH;@Y^K)ZGAGB9*.B3@V@60:L,_:6M`KH[X
> MY#^'.KK)[L(%P"=481:Z(5XD9<0P!W2T2J=EPP70^--HE:J1!P1```2R1``+
> M`;($%F)!``0*A0"/R1<5DL)]LZ%K#JK(AMJ0J4B`/PM`NDA5W/+9`8IUY29;
> M^P*8Y&H7'*5*@/<R[/]2[6*T"P1```32$K"+`FAH6/'3CS^E%8$,(`` "()`)
> M@5/O'-EYCY[-*U8OGAC-1(XX[2G-9[*W/-*>7].%>>;3LJQZ<2Y3K(X5%R6G
> MJI=EPZ_S3$:"H[*NHP`<U9+[S"ZB`'*O)&H$@<(GD(TH@)<?[E3X#8 >&(``"
> M14U@V^VV[=6K9ZHF6+L`N/$_<O_]"K_Q7-M`GV,*7]O\:AA?]BI3P'Y8Y%?)
> MDJQ]RD<?4[N*X@.5>_Y96@B@V!#8VXJ@2C5;";L`2K7+T"X0R#&!L:,'F&M<
> M7%_?KZ^SIWGW."ZH+?A,:VW$0H`<]R"J`X$R),!,CU06GX4+@%G4Q6*K,&U]
> MO6#\.QO;>@-\`<Z(>9*;/HW%\LGRI+V*0O+H`L#B9\4^*N%LI>H"*.$N0]-`
> MH!`(P`50"+T`'4``!.P)D.EAZ060]P(H1OM?[WET0M=Q.B)`T-A)#A0:'-3O
> M^`CE@`#9_\PGAZ-`"&#Q<X%T!-0``1```1```1```1#PE@"9'F3KF0V]C5P`
> MJ>S_!5]=-.O]L]DY8^:MWFKF6AK3-M;]Z'A"P^F:``&DTW)PN.X:%+0A` "\`
> MA@<(@``(@``(@``(@``(@$`."%AZ`39:"&#I`ICTYME;5VLC3CJ*J3CUQ4FS
> M0MI1OW\R!QK;5\&TC=2U*\8R3_O@B=T//(<7?.R?D]GU>:<<EG>% "UR!RM63
> M2$-O]PAX\\N&W^_6J\`;GGOUBGTYP(3;[K&!=OUU5UC>M2GUR"=7 >K4=8.Y[
> M$S66``'+A;Z\72["?4N`"9H``B!@3\#%-P/V`L"@`@$0,!/P_'<U52']&C <O
> M!]C(!6"V3&C^/[0F1/;_U/-',(U'//K.U!>G5'>M'KCKQ#SV(K/_0UV.DG3X
> MZJ,G=MV_W07PQ(N3-]MUA[VV[I%H"__I]R\\_Y\+\JAPL51=W30I0R]`EVY;
> M1./QE]Z?1DV^8?S]M]YT*5W`$2`-@*+V`M!7U;WW/V$YI/]\Z3DV+H!4I6I V
> MF>.)"Z!8/F70L[@(N/BA7UP-A+8@``(N"+CX9H`+P`5G%`&!DB?@^ >]JRU_C
> MDNF1Q@5`(0!CQAAF-G<!)+T`4Z<\.F7H\2EG`GOTWIKW%CT)V=QS+(/E+ <5N
> M9BZ`EDY'2OF_^?C)7?8[FR4^_:__['O\@<?NO5E;<WB/_G?\_>WS+87OOE-7
> M,7W:=VL4=9"R27+HKJ(H5E`QLR/=9KQW`\L_=-2&Y1N6B:+8VK6O9^(%H)E_
> MLOQ)X.*O7F%B^^UZ++V2+X`Y`KKU'+)JQ1Q>(Q\MTGB@=$K)?*BD&GYBNN)0
> M]%"9\G0!I!J]7D4!./IT(#,(*!)P\4-?43*R@4`!$H@GXM%0.)Z(Y?W1I+%(
> M./=\@I55K%+:+)8.OR]045T5\`?,FKCX9H`+(/<=BAI!H/`)N'8!V#3-/"'G
> MP`7`0P!8!4(@@.$"Z#HP9!,(P.PW*L4O)"W3IJ?*P.0P%\#:6MD%,./3#2L4
> M9BS?=.2)!YTPLE_;VNCPWK?][4UK%P!)VV/GKO_[=@V3+%Y+.MO<,I=-FUD4
> M[BBS^E#^_K\WL'E7\@;M>)#A!3"G6$KKU.+&"[#3X=>1-&[YFR4S7\!W;]^F
> M.!A8-ON1H$Y#S"G*="3?468;W8K=!6#3-$0!N!N3*%6P!%S\T"_8MD`Q$$A+
> M(-3:ZO?[)[XUZ]^?S)V[I"EM_E+-T*NNP]%[#1Y_ZB[4P&!%I;F9+KX9X`(H
> MU=&"=H%`)@1<+P1P%)/KP`5`F__1$H"1"R9UG=%U9!_MTA$C>?.F3)FAS5IC
> M'PB0`Q=`4X<C).+??_;4CGO_D24^^\H[PT;M>>".O6/AR)'#_^^I-\Y+U3U[
> M[5+W^3>K^5WI;=IT]0R*"F0RC,2R/WSP%SXXR`M`M\2WVQ]XBTU%75K?<!0+
> M0/:_C?$O5D2.`,D+8&]7>V5UBSJXENFZH(2ZJ%T`[L:GC8\3"P'<(46IW!!P
> M\4,_-XK9U_+06PL+00WH4/@$I+TP6EO6/OJ?7^<NB_SIF+WV&SJX\/7/DH8_
> M+5A.3PP=TJ?JXF.V1Q1`EB!#+`B`@&L"3F,''+@`V"J`HR9-8<J9O0!3IBRX
> M=*SUOH#F*``IB%K,0,*YOT`"D2H4G$4!K*J670`_?O'4=GNVNP!(U+E'/<8$
> M/CXII?U/=_<=7O?)]`TN`/Z6+N@NN\6NV5LQ7518+"B6DB3P(KQ2J4:Q4K$Z
> M21\;37@5/W^TP0O`$\D=L,W^=O8_R]DMY,`+P$(`%`\5%X`T0L1!(HX*<5R)
> M:P>8)N*X$J/][<>GN))%E$/7&6K%=8`+0!PJ<`$H?G"0+2\$BM<%8+_-85Y@
> MHM)"(T"N(K,+X,!KWWG\ZI/+V?Y/=I/^\8QYY][YXM2'3J0'3YL[SL4W`Z(`
> M"FW\0Q\0*%X"&;H`-GHHH$1A8*@KI;QSU#OTNF;H&GZ70@`>?732K%D+1HX <
> M../?UKM_,V-),K2XY<9%L0R2G<]2F/TF99`T3"1TZ:0,8LJCKY[+3G-.,44J
> MQ=Z2O3WERU5TT@6]I0M*9V_%=$D.W66&.DMGI=@U*\[E<,GLEEBC6*E8G:0/
> MOV73NJWVNYG-__.#WE*B/1!VM['R]^H/"Z2E_G12((#]R;*E_;Q)1K@T2,11
> MD>J6M+S?O-J?C4^NB3D_'X0VXU9R1G!E4FF5MN'(``(@``(@``)Y)$!;`%#\
> M_[X[#22[-WG$R_.,Q^.[#^E-*/R!BCQV!ZH&`1``@6P0L',!5'==0U6 &M#LF
> M'35RRL"C^$(`,O[_]*=/Z5RP8(&V==?['VK??D_2CUORE,XL)?/D*MU*E <ZE
> MV61(),ARWNA,VM(;SA=>?Y>=YIQBBE2*O?UPZJJ1NW6CD]]-E<Y%408J1: <H
> MD,NA"Y93$LA3Q%*6>2SUL6\:$RX=:8OP#`U!52\`;?7'=@%D!UOV;[ZF/ "I/
> M!U#<G\]F7/%19]'^9)(X/ED>+DVQ]E22*3WMJ+8I6X:W=,WP@F5^,.R`GSE)
> M2``!$"A;`K0''K4]3KL"TG^&_5^>1SP2#D4B(4+!@'AV>"K,,ZT@ "`1`H,P(
> MV+D`0GT&3GUQ$@$)C9S$3C.<D2.'4BS`.T]<9,^-3]N:LS%+S,;HLLD03^C2
> M:?S=6I_XTIOOTD,!3SIM_Q..V_/"XQXW9^8I8BE*9&\/&-'M_2]6TLGOIDHW
> MRZ%28G6LU>9LDN2T>9@^7+BDMF4#YWYZH[17!+VE1!L:TJUZ_VCU6(#,/SZ6
> M?J)48FW&E:(FF5O[EA6E'=6*ZB&;(P(V@1N.Y-B,-^F6^G!5S^F)JA"2`P*B
> MRZG`'4^B:TS%39:7X5K@#',PH@JJ"D]F_BLKJ_C)!+*WG@C/JA##_1&/Q6.Q
> M@NH4*`,"(``"7A&P<P$,W>&&688#=,/!O`!;;SWPJ:?VH7/@P('TEKP`V@*+
> M)_\Y4C'M#P[+#/91`*3`H(&]]A@^8)>=!M"US=2W>/?@/;N_^]E*E;EZLTQ)
> M#JN1":23+C*,`N`")3FIFC;O\YO$_?_XB@!*I%OJL0!+M!QY`?C*$4>#QR8S
> M7TMBDX</+?M5)RY42CNJ7<@LZB(T`BW/HFX4E"];`J++R7-GHK??'EQ5ZBSQ
> MVK+OV#>AMPJ(7[.I!HSG#,MV9'K2\/7S_^Y7`517=VAM7<M/>DLRZ6WREY)[
> ML;DK2W-,";@`/!E-$`("()`5`IG\KO:)?W3-6Y31CH#,SA\Q;@&]5D\YZJ@[
> M1BZ;-+#/4;,F73.5M8:V!E@V==FAYTSDC>-_[$7A+%'Z82$NI6;%I6SF#"P;
> MVPYPD7ZX1'3!M\_P%.FA@/>]8+U@X7?[]!"%_.?31OZ6W:(4NF"O_*V8SO)+
> M<J2</`.7PS*(!>UOB1*D4A($_O:WJ>/X0P'[CQA'Z>:45&7-Z9OYWK9_1H#X
> M4`!:",`?$"!=F_<"%.MB8T8<0M)PLGQK'E=<IMFM8/YI*PTS\UAUK974%JY5
> M&6X':#/2-CU4Z[)'K^85JQ=/C*H/2,N<O+NY&2-VKGGPF.]*?4VUF'N?56T >
> MI6).LQPFRG,_5X;$4#PM`9M-O[+7FYE+EK9Y$P7:"\^\:C-2Z8.9BGDVJD[;
> MOV6>P7([P/ZGO]3ZWDU),BY7:77HT+FUM=F2K<VMPND+VA`A%@U'0FT]CWMH
> MS1L7Q:(;3X@E%76Y'>#"S[26QL:?1A=.8Z$)"(!`.1!P\$0`AH-Y`8RI_N0Q
> MYIFALQXUKK<^?\8S8V:8[?_<0&0N@`5QV06PZ+MG-MMI#-/AS??>%Q\* >,\_
> MK%T`N5%8K&7T?CW>^GB#HR%["BSY<AP3ONEN[1=T;9FHJ,/`@)T7@#\4@(Q_
> MOA>`^5IR`2A6[2Y;AC\H,RQNHS-<`"(<;UT`3#+W/UK:'N9$1RE<>='10(DJ
> M0MR-9)3*(P$5%X#8]>((E&;44[F<V.#AX];>C<[D2_G-4^@J+@!1/4M7EXW7
> MC&DK.4S%SYVY.;P34WG_Q4]N'GN\K*I.[0*X43?,?Y<N@-K:+BTM398DZ19+
> MYQE8"GO+"HHI+#-/297!VU[C+H!>QT^$"\!;MI`&`B"0%P*2Z6&W$(#I=]3O
> MG]1FK9GRZ!2R]NDMF?UD_%<?.F/,P&=>//]^:?X_QTVR?R+`X0<==.\?7CA\
> MA_N/'/Y_=SWW1Y4]\'.0A^Q_HD2O.:BK[_";V"G699FHJ,R\Z&'V^P*PQP&P
> M89#J.C>#A'Z89FC`LY^VYI"!W.B/6EP38!LQN"[NKB`;;[PLLW`R'('N-$&I
> M'!,0NY[U.#M%VUA,Y'?%;+R@:-A+871I\[MH.`]+D6QR[@[PMCE,K+E2WGP 7
> M34"1+!$@&YCL?]<':96J+-U:MVX-G63,4QYZ%=^R=#%%RF.9P;6>Z0IFB2[$
> M@@`(@$">":1W`9""0X^_ATYR!)#-3^>A4\><OVS,E"D+#IWP7S'^/_=-,:]F
> M[[O=&6+B'7__(SO5U[UG.^>D#U:P,]L594G^+V'#"T">)`K$$'M<7`7`[']^
> M5[KFP0)9'3"9VX'\MV]6]83PTB"`T5(:_>BB%9E_U7"KV,;AR)U*3$/S++H+
> MS;-71-+6LB+):Y8]92#9'0%Z(F`F9](%8"V!WV(7:]>NZMBQ*YU2.MU*E4+I
> M4I%,5+4OZXX>2H$`"(!`@1-0<@&P-I`7P+#YUY^7CGTR[VU3G+M&-F\)S&G[
> M'9WF<``*_E<Y\SYLH``(9(D`-^&D2=TL50>QA4,@P\"3M-/@Y@S <"U`X$+@F
> M:9M#.>$U*\".$U5*-SV>YG[2>K<^^"UVT:E3M^;FE71*Z<DPA'8A=) >RL9PL
> MG15A;[-Z%'@W03T0``$0<$?`@0O`7059+:7^9#OD])S`SRV'BN$`M,)?_<SJ
> MJ(#PLB5@7KLAIO"92?.R;=%T)WKB6RF8WSQ/RU=3F\6RCD@EO&R["0W/G( "T
> M`C]S@?F2@)56^2*?MEXRM#,YFYI6=N[<793`WR8->^-D%]);RQ0J2P+I%`O2
> MM51%)@JG*IL6%#*```B`0#$2*&X70$+7<.:1P(_K#J63.0+,2P.*\?,`G8N:
> M@'E>44JQ?$M-YK'<J3(P+.:0;ZF@.9LY0X;3Q47=026FO-GEE,K-).4T>X5X
> M07%N/]7N$FF]3I:<S;I9^J=4O&89-L>LOV7S2VRT%&%SC+T`,CF;FAJ[=.G.
> M3WI+TNAM$@63K-%;GHU?L`PL9_*U/2<316_%(DS4^FP6%YDTP?5NB$78W5`9
> M!$"@O`BD>2A@P<)@3P28V7Q(P6I8AHKMT/E=UFK[9P>6(1ESD_%$`)&)5T\$
> M,,\HNK:WN2C7$C#.2X:`BT=_%4+;S3N]%X)6T*'0"*1Z(D#3V]<8ACB;E,_K
> MT;5KSS5K-NP])+W-DFJT04`L&HF$0IN>\AB>")`ER!`+`B"02P)I'@J82U4R
> MKVO&&K@`,J?HO82A7=M]`=Z+AL12)/"'._?KLD>OYA6K%T^,EF+[T*;B)N "5
> M"\!^MS_/&<$%X#G2DA28R@6PYJVK"V0.O&O77A+Y-6L:LMT7 >B(1C83)!]#O
> ME"?6O#$V%FTSU^CBFZ''<4%MX6=:2^/+#W?*=A,@'P1```0D`B/WWX^GR%$`
> MWZP:!5X@``(@D$L"?WTB#!=`+H&C+D<$7/S0=R0_2YGA`L@2V!(3F\H%T/C:
> MGVG!/C769S0X^5(V!S4\$:<@@##]-_",9YK>N#@:;?76!:`W7EXV.-%0$` "!
> M@B#PRDN/BRZ`XMX+H""(0@D0``$0``$0``$0*`D"/LW7JZ[#S%\6MZUK:EF[
> MNF7MFM9U978:36YJ:UG[TX+EA,(?")9$QZ(1(``"(+"!@'44P(0+!@(2 "(``
> M".2&0/4NLQ$%D!O4J,4%@>*-`G#16!0I0P)C1P\06QT.M8W_YW>+&]: >O,^@
> M88/KRA"($?Z@Z[\L6_O(?^8,WJS;W1?\KJW%>&:A=+CX9N`+`1`%4(;C "DTN
> M7@(K&V87K_*D>?=>6]&K%`4`%T!1]RF4!X%2(``70"GT8NFVP <4/_=*%@9:5
> M/H%X/!8(!!^8]/V+'\Z>NZ2I]!N<HH4T_W_"?D/N.']4P!]L66NQ^X"+;P:X
> M`,IV.*'A14T`+@"7W3?UGA&\Y(@KIKJ4@F(@``(E2L`K%P`M:BU10FA6=@E(
> MLZ"9S_5E5UU(!X%L$O#Y_/Y`13!8'0A6TC6M"\C75@#^0&4V&VHM.Q&/K+_A
> M]_F,9R*TM:Z,QWCBAE)P`>2^=U`C".2%`%P`;K"_==E6H^_;$#XAO4TET4??
> MN\*1R6-IF"B20!>9R''3>)0!`1!0(."A"V#<6=C05($XL@@$QCW]'EP`&!$@
> M``)."<`%X)08\H-`D1(H=Q?`ZY_^,/6GW\R=-V+;_D?NL[UEI]+\_[#3SZ-;
> ML=90:W-+VYKFUJ9UJV9_(69.%1<@6NPVUKN]8<_O<D=`D0X^J`T")4P`+H`2
> M[MS";QI<`(7?1]`0!`J0`%P`:3L%O[UM$(F3G9BA-(,JJ,%3DBX`!T\$(/O_
> M]O,.,Y^6?@'>EQ4==Z2SIM=NW;?8O]_P(X<<^(<1%SXLGN(R@50?%3:'G_:[
> MQB8#/EV9T$-9$``!$``!$``!$``!$%`DP";A\//;$A>'`S[V?#*T_A3':GEF
> M<^`"($"T24PB89S4)70=CT=#;>O2@(NU4@P`/P^Z:<G)=]9?]$##F0\VMB <Z
> M!$]5\P'!+OBK>:"(O@/^,6,21"&2!/-;4;)8EM6.`>JP#Y$=!')!@'\V+3^A
> M&7YRU8LK?C_8"%2O*Q=8A3H4FY9CK5`="(``")0G@<+Y3B9-"M "X+1P^!0B'
> MVU/E^=DIPU8[<P%$HY'D$292]-JRKFG5BGH;:K&$KD6:^-GOY)^Z;S%XKY&[
> M''/8\)$'[KS=V0UTR\BC?+#O%&[8LX\07^=O&2P@)7()DA`FARD B "11KE!20
> MWBJW`QE!``2R2R#M9U/]#[#ECP;UXHHY;;+92\C7;QI&.(^U9W<`03H(@``(
> MY(J`RA>I2AX5?57D>)@GK:BT&11-4Q4YA<:'-2WS/_$J;5?)4SA\V*^+M'`\
> M'!M>\5%A6"!YG+D`:/Z_IJ:VIJ8C:=^A0\<N77M&(B'6$GK8H/1*;Z/1A.@ "
> MZ-.O:_/JM=,_^>'%M[^;_,%/';IUIKN12$*=!1\34I%4Z:))KUZ+94XIB$ "2
> MK/@K/T,=4!P$0,`I`7PVG1)SE!]X'>%"9A```1`H$P)I'?%EP@'-=$T@C],,
> MKG4NHH+.7`#Q>'S-FL:5*XV9_X;EBQ8MF!V+MC\HY=@3SZ5$\97>1L+D`FCF
> M)TVR[[;?#G^^X(`_G[O_,2?LW:-O-W(!&&X"Y8-_H4@E;-(]]`)P42PNP'/)
> MRAB0$01`(`T!\2^'I?].+"]%VHMOF6-8<@]+^5D&,4\J"3S=)K_YR\VF=E$]
> MLU9<<\MZ>=E4\E-E$,4R;9E\+L>RH)0HY9<DV,NT[!1\)-0)]#@MSD_U4F).
> M*NZN8*I2DD"FGDT5GBO@;7,@#00<$5#QI:KD4:E418XG>52$D,(JV;S*4U!\
> MV)^YM$U+F\%#AH7#AY-)ZP4H-#XJ#`LDCS,70//J%8W+%JU8:CP7@"Y6-]:O
> M:UYMTY)H+*%%UVXXM40T'&MMB[:%H^%(E#86T*+-$047@,J'))4:TJ] ;U]S-
> MOY+Y[^"T`]1UI2@(`B#@FH#TP61?(^9/JY0NO65_7<2_,3P#5\Q&`O_ >8/5R
> M!41-S`+-DE/5Q=5+U3J;>J5;K`I)21NQ'`O/P]F*DKGF]IHP:5R"O4QSI[@ >
> M).59L/&Y@/%'_+D`G>YL:2;!PX,+9/K8RZ<\KC5/I;,[#AX2@"@0R)R`BCF4
> M> 2W%*Z&4^%#PM?G,L&M*B4^&*,JAN#,7P*H52QN6SF]8,O_C= UY84;^0WMJ[
> M`&(Q76MKW'"NGSG?0#:T,DYY3(<X7R3:_^P'(DL19YPLTYE4\9;XUD:L.,64
> MJKCXRSL3#T4Y##*T$03R1<#L!;#T"8HSTJ+)JJZV*$&TA%/]0;6L4:4Z_HUD
> M^;5I[_&T*6M3M6M5[9N3);$J#)&G-`AX[H8H#2QH!0@4`@'^YP: _D+/7'11Y
> MS<^1^^^7O8IR+QGC)P?,';@`1FS;_Y_36]^84S5Y0:?_+.A,YSL+N[P]KY;2
> M4REZU%TS)CW_'C\CX0C%U#*+WWCU:9.>>Y_RF(NSZ2!^B!E8(C/FV:OY0OH1
> MS_.P]+1BI0R6Q<4J4OW*ST'_H0H0``%+`M+TN\UG/]5W@B.PYB^-M-:X],6B
> M6)U-R(#E-YLHUJ:L^(7&W:SVT!053I4MK;89RD=Q1P38'#@/OQ?C\,7 I <7XM
> M7E@FLMK-X?U2NE26J\&SF2?G+?.8Y9C;(BTN,+<1@0".Q@PR@X`]`7S)IQTA
> MF9L/]+QZ=E)=G__OJ[0U%E$&C)]L=Y8#%\"1^VQ_^WF'F4]*M]&2+'Q^ZC5=
> M.];5=.M>TZU;=>?N-36=JBSM_VRW&?)!``3*@4`J(UPQW=Z&MP1H#B "RY^RB
> MBK0=EZ',5&Z"#,6F4CM+8M-20@9N\/-%`2RZG@78VZ\1$.WM3%83\%[@`KDR
> M[):E<#$/5Y6O"Q#UE]HB2I/:*-6+X0$"(``"A4^`6?XX0,`=`5_C\EF\Y)2/
> M/OYFU2AZ.^&"@?;B:/T)V_G/Z=%SVR?[U`8"/E]37)__]9E.BR,_"(!`Z1&H
> MWF5VESUZ-:]8O7AB-)/6/?36PG%G&=]@=(C+A;BCG1F<[*TY3,`R&\\I >NNY
> M'![B*$H6BYA-7+%V<XWFF$F;NJ0V2CIP#NQ"JC=5E(2HL*6J-F(MV?(.%6LT
> M4Y7N2AV4ZFWF4R@D>=S3[XT=/<!FX"VNK^_7MV\F(S./91?7+UL?>V=HP1O "
> M;&!1,9XB3H:S/'SMO;AB7UJ-;\YIKD(2)680:Q=%\2*I5)54DO+;BV4 RI >HH
> MA7H\CUV&J@N&@/$5NVF?E)]]%]\,/8X+:@L_TUH:]<;+"Z:94*18 "9`MQN/_
> M)]QVS[WW/U&L+2EXO8O=V]*]UU;$6!PPQL\J=RZ`@N\L*`@"(%`T!++A`BB:
> MQA>2HI(#(I=K.'-9EX2\A%T`9*+X_16;].YA'F7V+@!+[X#98D\EQ.PRX`J(
> MM_+H`K!Q#132)Q*ZY)E`?4-C/!Y-Y0',Q`70^-/H/+<-U1<_`;+KF%''[/]B
> M-U.+OT,*MP66+@`'"P$*MV70#`1```1`(&,"-*G.-@)@AR=S["I*L1``+`I0
> M8:6>9\FR97Y_P-+^5Q0BQN=;3NF+ACV[YK'WJ?*GS:"H&[*!0`X(].W5(Q "H
> MI(]2#NI"%2#@E`#9_!21#?O?*3?D9P1<1@&X7@@`[B```B`@$4`4`(9$'@F4
> M:A0`+0'HU[>/)5AI[3WED5+86S$60)JQ%PU^RYPV+@/+90620/Z6ZR8]-9!7
> M:JDY=T987I@3Q:T$\C@4475A$EBRK-YR.4`F40`O/]RI,!L+K4``!,P$BOV !
> M"U@(@%$-`B!0B`3@`BC$7BD;G4K7!5#$6QB4S>A#0XN`0"I3/Q,7P+BQZXJ@
> MY5`1!$"@\`A<//:<+EU[TBH_1=56KUI:UVT3RNS-7@".H@"FWC.":SGBBJF*
> M&B,;"(!`F1#PT`50)L303&\)E.1V@"[L$V^I0AH(E`8!N`!*HQ_1 &qu
Re: cannot override report parameter list from rptlibrary [message #671598 is a reply to message #671388] Wed, 18 May 2011 08:38 Go to previous messageGo to next message
the xml of the rptdesign. the parameter group from rptlibrary is
<parameter-group name="Date Range" id="1716" extends="TivoliCommonReporting_v1.Date Range"/>
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.15" id="1">
    <property name="author">IBM Tivoli Common Reporting</property>
    <property name="createdBy">Eclipse BIRT Designer Version 2.2.1.r221_v20070924 Build &lt;2.2.0.v20070924-1550></property>
    <property name="units">in</property>
    <property name="includeResource">tcr_common/properties/DateRangeParameters</property>
    <text-property name="title">Sample Report with Date Ranges</text-property>
    <property name="comments">Licensed Materials - Property of IBM
5724-T69
IBM Tivoli Reporting
(C) Copyright IBM Corp. 2007 All Rights Reserved.
US Government Users Restricted Rights - Use, duplication or
disclosure restricted by GSA ADP Schedule Contract with
IBM Corp.</property>
    <html-property name="description">This sample report demonstrates use of a pre-defined date range parameter group  from the Tivoli Common Reporting library.
The Date Range parameter group combine a report period  parameter, which  is a static selection list  defining common reporting period ranges, such as last week, current week, last month, last 3 months, with optional beginning and ending dates. The report uses supplied scripts to determine what the actual beginning and ending dates are for the report, based on which parameters are entered.   The sample also includes pre-defined Text and Data report items which represent a localizable display of the user-selected Report Period.  These report items can be dragged from the TCR library onto a report layout in the Parameter grid so that the report output shows which reporting period was selected by the user, and which dates are covered by this reporting period.  Finally, the sample also demonstrates a use of the data-set beforeOpen() script which calls TCR Javascript functions to modify the data-set query so that records are filtered on the date range specified by the Date Range Parameter group.
In order to get the correct values for the dates,  use the  getStartDateFromGroupNames("Report Period", "Begin Date", "End Date" ) and getEndDateFromGroupNames("Report Period", "Begin Date", "End Date") methods.</html-property>
    <method name="initialize"><![CDATA[//
// Set up logging.  Uncomment next line to enable in Designer tool.
//importPackages (java.io);
reportContext.setPersistentGlobalVariable("logfileName", "DateRangeParm.log");
setupLogging();
logInitialize();
var valueis = reportContext.getReportRunnable().getReportEngine().getConfig().getResourcePath();
debugLogger(" resource path value is " + valueis);
if (valueis == null)
    var valueis1 = reportContext.getReportRunnable().getReportEngine().getConfig().getResourceLocator();
	debugLogger(" resource Locator value is " + valueis1);
	var xx1 = reportContext.getReportRunnable().getDesignHandle();
	debugLogger(" design handle in initialize " + xx1);
	var yy1 = xx1.getResourceFolder();
	debugLogger(" resource folder is " + yy1);
//	var xx = reportContext.getReportRunnable().getDesignHandle();
//	var yy = xx.getModuleHandle();
//	var valueis2 = System.getProperty("resourcePath");
//	debugLogger(" parameter resource path is " + valueis2);
// Add closeLogger(); to afterRender/afterFactory to close logger object.]]></method>
    <method name="beforeFactory"><![CDATA[var xx = reportContext.getReportRunnable().getDesignHandle();
	debugLogger(" design handle is " + xx);]]></method>
    <method name="afterFactory"><![CDATA[debugLogger("afterFactory");
// Close logger if it is enabled
closeLogger();]]></method>
    <method name="afterRender"><![CDATA[debugLogger("afterRender");
    <property name="theme">TivoliCommonReporting_v1.TCRTheme_v1</property>
    <text-property name="displayName">Sample Report with Date Ranges</text-property>
    <list-property name="libraries">
        <structure>
            <property name="fileName">tcr_common/lib/TivoliCommonReporting_v1.0.rptlibrary</property>
            <property name="namespace">TivoliCommonReporting_v1</property>
        </structure>
    </list-property>
    <list-property name="includeScripts">
        <property>tcr_common/scripts/ReportUtils.js</property>
        <property>tcr_common/scripts/Logger.js</property>
        <property>tcr_common/scripts/DateTime.js</property>
        <property>tcr_common/scripts/ModifyQuery.js</property>
    </list-property>
    <parameters>
        <scalar-parameter name="Customer Name" id="306">
            <text-property name="helpText">Select customer name from list or leave blank for all.</text-property>
            <property name="valueType">dynamic</property>
            <property name="dataType">string</property>
            <text-property name="promptText">Select customer name from list</text-property>
            <property name="isRequired">true</property>
            <property name="controlType">list-box</property>
            <property name="dataSetName">Customers</property>
            <expression name="valueExpr">dataSetRow["CUSTOMERNAME"]</expression>
            <expression name="labelExpr">dataSetRow["CUSTOMERNAME"]</expression>
            <property name="mustMatch">true</property>
            <property name="fixedOrder">false</property>
            <property name="defaultValue">%</property>
            <property name="distinct">true</property>
            <property name="sortBy">label</property>
            <property name="sortDirection">asc</property>
            <structure name="format">
                <property name="category">Unformatted</property>
            </structure>
        </scalar-parameter>
        <scalar-parameter name="Report Period" id="1714" extends="TivoliCommonReporting_v1.Report Period">
            <text-property name="helpText">Report will be filtered on the date range selected.  If no range is selected, no filtering on date occurs.</text-property>
            <property name="valueType">static</property>
            <property name="paramType">simple</property>
            <text-property name="promptText">Select desired date range for report</text-property>
            <property name="fixedOrder">true</property>
            <property name="defaultValue">L30</property>
            <property name="distinct">false</property>
            </structure>
            <list-property name="selectionList">
                <structure>
                    <property name="value">L24</property>
                    <property name="label">Last 24 Hours</property>
                    <property name="labelID">L24</property>
                </structure>
                <structure>
                    <property name="value">L7</property>
                    <property name="label">Last 7 Days</property>
                    <property name="labelID">L7</property>
                </structure>
                <structure>
                    <property name="value">L30</property>
                    <property name="label">Last 30 Days</property>
                    <property name="labelID">L30</property>
                </structure>
                <structure>
                    <property name="value">L90</property>
                    <property name="label">Last 90 Days</property>
                    <property name="labelID">L90</property>
                </structure>
                <structure>
                    <property name="value">L365</property>
                    <property name="label">Last 365 Days</property>
                    <property name="labelID">L365</property>
                </structure>
                <structure>
                    <property name="value">CW</property>
                    <property name="label">Current Week</property>
                    <property name="labelID">CW</property>
                </structure>
                <structure>
                    <property name="value">LW</property>
                    <property name="label">Last Week</property>
                    <property name="labelID">LW</property>
                </structure>
                <structure>
                    <property name="value">CM</property>
                    <property name="label">Current Month</property>
                    <property name="labelID">CM</property>
                </structure>
                <structure>
                    <property name="value">LM</property>
                    <property name="label">Last Month</property>
                    <property name="labelID">LM</property>
                </structure>
                <structure>
                    <property name="value">L3M</property>
                    <property name="label">Last 3 Months</property>
                    <property name="labelID">L3M</property>
                </structure>
                <structure>
                    <property name="value">YTD</property>
                    <property name="label">Year to Date</property>
                    <property name="labelID">YTD</property>
                </structure>
                <structure>
                    <property name="value">Y</property>
                    <property name="label">Yesterday</property>
                    <property name="labelID">Y</property>
                </structure>
                <structure>
                </structure>
                <structure>
                </structure>
                <structure>
                </structure>
                <structure>
                </structure>
                <structure>
                </structure>
                <structure>
                </structure>
                <structure>
                </structure>
                <structure>
                </structure>
                <structure>
                </structure>
                <structure>
                </structure>
                <structure>
                </structure>
            </list-property>
        </scalar-parameter>
        <scalar-parameter name="Begin Date" id="1715" extends="TivoliCommonReporting_v1.Begin Date">
            <property name="dataType">dateTime</property>
            <text-property name="promptText">Start Date</text-property>
            <property name="controlType">text-box</property>
                <property name="category">Custom</property>
                <property name="pattern">MMMM yyyy</property>
            </structure>
        </scalar-parameter>
    </parameters>
    <data-sources>
        <oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="SampleDataSource" id="153">
            <property name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver</property>
            <property name="odaURL">jdbc:classicmodels:sampledb</property>
            <property name="odaUser">ClassicModels</property>
        </oda-data-source>
    </data-sources>
    <data-sets>
        <oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" name="CustomerPayments" id="1584">
            <structure name="cachedMetaData">
                <list-property name="resultSet">
                    <structure>
                        <property name="position">1</property>
                        <property name="name">CUSTOMERNAME</property>
                    </structure>
                    <structure>
                        <property name="position">2</property>
                        <property name="name">PAYMENTDATE</property>
                        <property name="dataType">date-time</property>
                    </structure>
                    <structure>
                        <property name="position">3</property>
                        <property name="name">CHECKNUMBER</property>
                    </structure>
                    <structure>
                        <property name="position">4</property>
                        <property name="name">AMOUNT</property>
                        <property name="dataType">float</property>
                    </structure>
                </list-property>
            </structure>
            <property name="dataSource">SampleDataSource</property>
            <method name="beforeOpen"><![CDATA[// Next line allows query to run in Data Set Preview, by essentially commenting out debugger
dsDebugLogger = ((""+typeof(debugLogger)) != "undefined" ) ? debugLogger : function(s) {};
// dsDebugLogger("BEGIN beforeOpen: queryText=" + this.queryText);
dsDebugLogger(" value is " + valueis);
try {
  // Filter on Customer Name
  var cust_name = params["Customer Name"].value;
  dsDebugLogger("Customer Name=" + cust_name);
  if ((cust_name != null) && (cust_name != "")) {
    var condition = "cus.CUSTOMERNAME LIKE '" + cust_name + "'";
    ModifyQueryAddFilter (this, condition);
  // Filter on Report Period
  var report_period = params["Report Period"].value;
  dsDebugLogger("Report Period=" + report_period);
  if ((report_period != null) && (report_period != "")) {
     ModifyQueryAddDateRangeFromGroupValues(this, "pay.PAYMENTDATE", report_period, dateToString, params["Begin Date"].value, params["End Date"].value);
//  dsDebugLogger("END beforeOpen: queryText=" + this.queryText);
} catch (ex) {
  dsDebugLogger("beforeOpen: "+ex);
}]]></method>
                <structure>
                    <property name="nativeName">CUSTOMERNAME</property>
                    <property name="nativeDataType">12</property>
                </structure>
                <structure>
                    <property name="nativeName">PAYMENTDATE</property>
                    <property name="nativeDataType">91</property>
                </structure>
                <structure>
                    <property name="nativeName">CHECKNUMBER</property>
                </structure>
                <structure>
                    <property name="nativeName">AMOUNT</property>
                    <property name="nativeDataType">8</property>
                </structure>
            </list-property>
            <property name="queryText">SELECT cus.CUSTOMERNAME, pay.PAYMENTDATE,pay.CHECKNUMBER,pay.AMOUNT
FROM CUSTOMERS cus, PAYMENTS pay
WHERE cus.CUSTOMERNUMBER = pay.CUSTOMERNUMBER
ORDER BY cus.CUSTOMERNAME, pay.PAYMENTDATE,pay.CHECKNUMBER</property>
            <xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
  <Version>1.0</Version>
  <design:DataSetParameters>
    <design:parameterDefinitions>
      <design:inOutMode>In</design:inOutMode>
      <design:attributes>
        <design:name></design:name>
        <design:position>1</design:position>
        <design:nativeDataTypeCode>12</design:nativeDataTypeCode>
        <design:nullability>Unknown</design:nullability>
        <design:uiHints>
          <design:displayName>Select customer name from list.</design:displayName>
        </design:uiHints>
      </design:attributes>
      <design:inputAttributes>
        <design:elementAttributes>
          <design:defaultScalarValue>%</design:defaultScalarValue>
          <design:optional>true</design:optional>
          <design:masksValue>false</design:masksValue>
          <design:dynamicValueChoices>
            <design:dataSetDesign>
              <design:name>Customers</design:name>
              <design:odaExtensionDataSetId>org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet</design:odaExtensionDataSetId>
              <design:dataSourceDesign>
                <design:name>SampleDataSource</design:name>
                <design:odaExtensionId>org.eclipse.birt.report.data.oda.jdbc</design:odaExtensionId>
                <design:publicProperties>
                  <design:properties>
                    <design:nameValue>
                      <design:name>odaDriverClass</design:name>
                      <design:value>org.eclipse.birt.report.data.oda.sampledb.Driver</design:value>
                    </design:nameValue>
                  </design:properties>
                  <design:properties>
                    <design:nameValue>
                      <design:name>odaURL</design:name>
                      <design:value>jdbc:classicmodels:sampledb</design:value>
                    </design:nameValue>
                  <design:properties>
                    <design:nameValue>
                      <design:name>odaDataSource</design:name>
                    </design:nameValue>
                  <design:properties>
                    <design:nameValue>
                      <design:name>odaUser</design:name>
                      <design:value>ClassicModels</design:value>
                    </design:nameValue>
                  <design:properties>
                    <design:nameValue>
                      <design:name>odaPassword</design:name>
                    </design:nameValue>
                  <design:properties>
                    <design:nameValue>
                      <design:name>odaJndiName</design:name>
                    </design:nameValue>
                </design:publicProperties>
              </design:dataSourceDesign>
              <design:query>
                <design:queryText>select distinct CLASSICMODELS.CUSTOMERS.CUSTOMERNAME&#xD;
from CLASSICMODELS.CUSTOMERS&#xD;
order by CLASSICMODELS.CUSTOMERS.CUSTOMERNAME</design:queryText>
              </design:query>
                <design:properties>
                  <design:nameValue>
                    <design:name>queryTimeOut</design:name>
                  </design:nameValue>
              <design:resultSets>
                <design:resultSetDefinitions>
                  <design:resultSetColumns>
                    <design:resultColumnDefinitions>
                      <design:attributes>
                        <design:name>CUSTOMERNAME</design:name>
                    </design:resultColumnDefinitions>
                  </design:resultSetColumns>
                </design:resultSetDefinitions>
              </design:resultSets>
            </design:dataSetDesign>
            <design:enabled>true</design:enabled>
            <design:valueColumn>dataSetRow[&quot;CUSTOMERNAME&quot;]</design:valueColumn>
          </design:dynamicValueChoices>
          <design:uiHints>
            <design:promptStyle>SelectableList</design:promptStyle>
          </design:uiHints>
        </design:elementAttributes>
      </design:inputAttributes>
    </design:parameterDefinitions>
  </design:DataSetParameters>
</model:DesignValues>]]></xml-property>
        </oda-data-set>
        <oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" name="Customers" id="1684">
                    <structure>
                    </structure>
                </list-property>
            </structure>
                <structure>
                </structure>
            </list-property>
            <property name="queryText">select distinct CLASSICMODELS.CUSTOMERS.CUSTOMERNAME
order by CLASSICMODELS.CUSTOMERS.CUSTOMERNAME</property>
  <design:ResultSets derivedMetaData="true">
          <design:attributes>
            <design:precision>50</design:precision>
            <design:scale>0</design:scale>
            <design:nullability>Nullable</design:nullability>
          <design:usageHints>
            <design:label>CUSTOMERNAME</design:label>
            <design:formattingHints>
              <design:displaySize>50</design:displaySize>
            </design:formattingHints>
          </design:usageHints>
  </design:ResultSets>
        </oda-data-set>
    </data-sets>
    <page-setup>
        <simple-master-page name="TCR Master Page" id="1702" extends="TivoliCommonReporting_v1.TCR Master Page">
            <overridden-values>
                <ref-entry baseId="9" id="9"/>
                <ref-entry baseId="10" id="10"/>
                <ref-entry baseId="11" id="11"/>
                <ref-entry baseId="12" id="12"/>
                <ref-entry baseId="13" id="13"/>
                <ref-entry baseId="37" id="37"/>
                <ref-entry baseId="14" id="14"/>
                <ref-entry baseId="38" id="38"/>
                <ref-entry baseId="19" id="19"/>
                <ref-entry baseId="20" id="20"/>
                <ref-entry baseId="301" id="301"/>
                <ref-entry baseId="21" id="21"/>
                <ref-entry baseId="22" id="22"/>
                <ref-entry baseId="23" id="23"/>
                <ref-entry baseId="1659" name="NewData" id="1712"/>
                <ref-entry baseId="24" id="24"/>
                <ref-entry baseId="25" id="25"/>
                <ref-entry baseId="26" id="26"/>
                <ref-entry baseId="27" id="27"/>
                <ref-entry baseId="28" id="28"/>
                <ref-entry baseId="29" id="29"/>
                <ref-entry baseId="30" id="30"/>
                <ref-entry baseId="31" id="31"/>
                <ref-entry baseId="32" id="32"/>
                <ref-entry baseId="33" id="33"/>
                <ref-entry baseId="34" id="34"/>
                <ref-entry baseId="35" id="35"/>
            </overridden-values>
        </simple-master-page>
    </page-setup>
    <body>
        <grid name="Report Introduction" id="223">
            <property name="width">100%</property>
            <expression name="bookmark">"Report Introduction"</expression>
            <column id="224"/>
            <row id="225">
                <cell id="226">
                    <text name="Report Title" id="44">
                        <property name="style">main-title</property>
                        <property name="contentType">auto</property>
                        <text-property name="content" key="report_title"><![CDATA[Report Title]]></text-property>
                    </text>
                </cell>
            </row>
            <row id="231">
                <cell id="232">
                    <text name="Secondary Title_Parameter Group Heading" id="332">
                        <property name="style">secondary-title</property>
                        <list-property name="visibility">
                            <structure>
                                <property name="format">all</property>
                                <expression name="valueExpr">true</expression>
                            </structure>
                        </list-property>
                        <text-property name="content" key="secondary_title"><![CDATA[Secondary Report Title]]></text-property>
                    </text>
                </cell>
            </row>
            <row id="1686">
                <cell id="1687">
                    <grid name="Parameter Table" id="95">
                        <property name="style">parameter-table</property>
                        <column id="96">
                            <property name="width">20%</property>
                        </column>
                        <column id="97">
                            <property name="width">30%</property>
                        </column>
                        <column id="98">
                        </column>
                        <column id="99">
                        </column>
                        <row id="100">
                            <cell id="101">
                                <property name="style">parameter-name</property>
                                <text name="Parameter Name 1" id="214">
                                    <property name="contentType">html</property>
                                    <text-property name="content"><![CDATA[<div title="<VALUE-OF>getNLS("parameter1_tooltip");</VALUE-OF>"><VALUE-OF>getNLS("parameter1");</VALUE-OF><div>]]></text-property>
                                </text>
                            </cell>
                            <cell id="102">
                                <property name="style">parameter-value</property>
                                <property name="paddingTop">3pt</property>
                                <property name="paddingBottom">3px</property>
                                <data id="1683">
                                    <list-property name="boundDataColumns">
                                        <structure>
                                            <property name="name">Customer Name</property>
                                            <expression name="expression">if (params["Customer Name"]!="") params["Customer Name"]; else getNLS("ALL");</expression>
                                        </structure>
                                    </list-property>
                                    <property name="resultSetColumn">Customer Name</property>
                                </data>
                            </cell>
                            <cell id="103">
                                <text name="Report Period" id="1677">
                                    <text-property name="content"><![CDATA[<div title="<VALUE-OF>getNLS("report_period_tooltip");</VALUE-OF>"><VALUE-OF>getNLS("report_period");</VALUE-OF></div>]]></text-property>
                                </text>
                            </cell>
                            <cell id="104">
                                <property name="paddingTop">3px</property>
                                <data name="Report Period Value" id="1711" extends="TivoliCommonReporting_v1.Report Period Value">
                                    <property name="resultSetColumn">Column Binding</property>
                                </data>
                            </cell>
                        </row>
                        <row id="105">
                                <structure>
                                    <property name="format">html</property>
                                    <expression name="valueExpr">BirtComp.anyOf(params["Report Period"], "ALL", "")</expression>
                                </structure>
                            </list-property>
                            <cell id="106">
                                <text name="Begin Date" id="1679">
                                    <text-property name="content"><![CDATA[<div title="<VALUE-OF>getNLS("begin_date_tooltip");</VALUE-OF>"><VALUE-OF>getNLS("begin_date");</VALUE-OF></div>]]></text-property>
                                </text>
                            </cell>
                            <cell id="107">
                                <data name="Begin Date Value" id="1709" extends="TivoliCommonReporting_v1.Begin Date Value">
                                </data>
                            </cell>
                            <cell id="108">
                                <text name="End Date" id="1680">
                                    <text-property name="content"><![CDATA[<div title="<VALUE-OF>getNLS("end_date_tooltip");</VALUE-OF>"><VALUE-OF>getNLS("end_date");</VALUE-OF></div>]]></text-property>
                                </text>
                            </cell>
                            <cell id="109">
                                <data name="End Date Value" id="1710" extends="TivoliCommonReporting_v1.End Date Value">
                                </data>
                            </cell>
                        </row>
                    </grid>
                </cell>
            </row>
        </grid>
        <grid name="Section 1" id="162">
            <expression name="bookmark">"Section 1"</expression>
            <column id="163"/>
            <row id="168">
                <cell id="169">
                    <property name="paddingTop">10pt</property>
                    <table name="Table displaying data related to Bar Chart" id="380">
                        <property name="style">group-table-with-section</property>
                        <property name="canShrink">false</property>
                        <property name="dataSet">CustomerPayments</property>
                            <structure>
                                <expression name="valueExpr">setRowCount(Total.count());
isRowCountZero()</expression>
                            </structure>
                        </list-property>
                            <structure>
                                <expression name="expression">dataSetRow["CUSTOMERNAME"]</expression>
                            </structure>
                            <structure>
                                <expression name="expression">dataSetRow["PAYMENTDATE"]</expression>
                            </structure>
                            <structure>
                                <expression name="expression">dataSetRow["CHECKNUMBER"]</expression>
                            </structure>
                            <structure>
                                <expression name="expression">dataSetRow["AMOUNT"]</expression>
                            </structure>
                            <structure>
                                <property name="name">Payment Date</property>
                                <expression name="expression">row["PAYMENTDATE"]</expression>
                            </structure>
                        </list-property>
                        <column id="1691">
                            <property name="width">15px</property>
                        </column>
                        <column id="394"/>
                        <column id="1589"/>
                        <column id="395">
                            <property name="width">2.6666666667in</property>
                        </column>
                        <group id="1659">
                            <property name="groupName">CustomerGroup</property>
                            <property name="interval">none</property>
                            <expression name="keyExpr">row["CUSTOMERNAME"]</expression>
                            <structure name="toc">
                                <expression name="expressionValue">row["CUSTOMERNAME"]</expression>
                            </structure>
                            <property name="repeatHeader">true</property>
                            <property name="hideDetail">false</property>
                            <property name="pageBreakAfter">auto</property>
                            <property name="pageBreakBefore">auto</property>
                            <header>
                                <row id="1669">
                                    <cell id="1688">
                                        <property name="colSpan">4</property>
                                        <property name="rowSpan">1</property>
                                        <property name="style">section</property>
                                        <property name="paddingLeft">5px</property>
                                        <data id="1668">
                                            <property name="style">section-title</property>
                                            <property name="resultSetColumn">CUSTOMERNAME</property>
                                        </data>
                                    </cell>
                                </row>
                                <row id="1673">
                                    <property name="backgroundColor">white</property>
                                    <property name="color">white</property>
                                    <cell id="1689">
                                        <property name="paddingTop">0px</property>
                                        <property name="paddingLeft">15px</property>
                                        <property name="paddingBottom">0px</property>
                                    </cell>
                                    <cell id="1674">
                                        <property name="style">table-header-cell</property>
                                        <property name="borderTopColor">#000000</property>
                                        <property name="borderTopStyle">solid</property>
                                        <property name="borderTopWidth">1px</property>
                                        <text id="400">
                                            <text-property name="content" key="payment_date"><![CDATA[Payment Date]]></text-property>
                                        </text>
                                    </cell>
                                    <cell id="1675">
                                        <text id="1590">
                                            <text-property name="content" key="check_number"><![CDATA[]]></text-property>
                                        </text>
                                    </cell>
                                    <cell id="1676">
                                        <text id="401">
                                            <text-property name="content" key="amount"><![CDATA[<div title="Total number of orders placed">Total Number of Orders</div>]]></text-property>
                                        </text>
                                    </cell>
                                </row>
                            </header>
                            <footer>
                                <row id="1697">
                                    <property name="height">0.2395833333in</property>
                                    <cell id="1698">
                                        <property name="paddingTop">0pt</property>
                                        <property name="paddingBottom">0pt</property>
                                    </cell>
                                    <cell id="1699">
                                        <property name="borderBottomColor">#000000</property>
                                        <property name="borderBottomStyle">solid</property>
                                        <property name="borderBottomWidth">1px</property>
                                    </cell>
                                    <cell id="1700">
                                    </cell>
                                    <cell id="1701">
                                    </cell>
                                </row>
                            </footer>
                        </group>
                        <detail>
                            <row id="386">
                                <cell id="1690">
                                </cell>
                                <cell id="387">
                                    <property name="style">table-details</property>
                                    <data id="1585">
                                        <structure name="dateTimeFormat">
                                            <property name="category">Medium Date</property>
                                            <property name="pattern">Medium Date</property>
                                        </structure>
                                        <property name="resultSetColumn">Payment Date</property>
                                    </data>
                                </cell>
                                <cell id="1587">
                                    <data id="1591">
                                        <property name="resultSetColumn">CHECKNUMBER</property>
                                    </data>
                                </cell>
                                <cell id="389">
                                    <data id="1592">
                                        <structure name="numberFormat">
                                            <property name="category">Currency</property>
                                            <property name="pattern">#,##0.00</property>
                                        </structure>
                                        <property name="resultSetColumn">AMOUNT</property>
                                    </data>
                                </cell>
                            </row>
                        </detail>
                    </table>
                    <grid name="Information Message Dialog" id="1703" extends="TivoliCommonReporting_v1.Information Message Dialog">
                            <structure>
                                <expression name="valueExpr">!isRowCountZero()</expression>
                            </structure>
                        </list-property>
                        <overridden-values>
                            <ref-entry baseId="42" id="42"/>
                            <ref-entry baseId="43" id="43"/>
                            <ref-entry baseId="44" id="1708"/>
                            <ref-entry baseId="45" id="45"/>
                            <ref-entry baseId="46" name="NewImage2" id="46"/>
                            <ref-entry baseId="47" id="47"/>
                            <ref-entry baseId="52" name="NewText2" id="52">
                                <property name="content">&lt;b>&lt;font color="#444E68" style="bold">&lt;VALUE-OF>getNLS("msg_hdr_dataset_empty");&lt;/VALUE-OF>  &lt;/font>&lt;/b> &lt;br> &lt;VALUE-OF>getNLS("msg_dataset_empty");&lt;/VALUE-OF>  &lt;/br></property>
                            </ref-entry>
                    </grid>
                </cell>
            </row>
        </grid>
        <grid name="Description" id="322">
            <column id="323"/>
            <row id="326">
                <cell id="327">
                    <text name="Description Text" id="329">
                        <property name="style">description-text</property>
                        <text-property name="content" key="report_description"><![CDATA[Description text goes here. Enter a short description about the report.Description text goes here. Enter a short description about the report.Description text goes here. Enter a short description about the report.Description text goes here. Enter a short description.]]></text-property>
                    </text>
                </cell>
            </row>
        </grid>
    </body>
</report>
Re: cannot override report parameter list from rptlibrary [message #671599 is a reply to message #671598] Wed, 18 May 2011 08:40 Go to previous messageGo to next message
the library file is
<library xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.15" id="1">
    <property name="createdBy">Eclipse BIRT Designer Version 2.2.1.r22a_v20071101 Build &lt;2.2.1.v20071101-1439></property>
    <text-property name="title">IBM Tivoli Common Reporting Library v1.0</text-property>
5724-T69
    <html-property name="description">The Tivoli Common Reporting library contains the base styles, master page and report items used to meet the guidelines set for Tivoli reports.</html-property>
    <property name="theme">TCRTheme_v1</property>
    <parameters>
        <parameter-group name="Date Range" id="1663">
            <text-property name="displayName" key="report_period_group_header">Date Range: When both start date and end date are entered, report period is ignored</text-property>
            <text-property name="helpText" key="report_period_group_header_help">Either period of time can be selected (last 30 days, 3 month, 1 year etc.) or specified date range eg. 2-02-2008 to 5-06-2008</text-property>
            <parameters>
                <scalar-parameter name="Report Period" id="1660">
                    <text-property name="helpText" key="report_period_help_text">Report will be filtered on the date range selected.  If no range is selected, no filtering on date occurs.</text-property>
                    <text-property name="promptText" key="report_period">Select desired date range for report</text-property>
                    </structure>
                        <structure>
                            <property name="value">ALL</property>
                            <property name="label">All</property>
                            <property name="labelID">ALL</property>
                        </structure>
                        <structure>
                            <property name="value">T</property>
                            <property name="label">Today</property>
                            <property name="labelID">T</property>
                        </structure>
                        <structure>
                        </structure>
                        <structure>
                        </structure>
                        <structure>
                        </structure>
                        <structure>
                        </structure>
                        <structure>
                        </structure>
                        <structure>
                        </structure>
                        <structure>
                        </structure>
                        <structure>
                        </structure>
                        <structure>
                        </structure>
                        <structure>
                        </structure>
                        <structure>
                        </structure>
                        <structure>
                        </structure>
                    </list-property>
                </scalar-parameter>
                <scalar-parameter name="Begin Date" id="1664">
                    <text-property name="promptText" key="begin_date">Start Date</text-property>
                    <property name="isRequired">false</property>
                    </structure>
                </scalar-parameter>
                <scalar-parameter name="End Date" id="1665">
                    <text-property name="promptText" key="end_date">End Date</text-property>
                    </structure>
                </scalar-parameter>
            </parameters>
        </parameter-group>
    </parameters>
     <themes>
        <theme name="TCRTheme_v1" id="253">
            <styles>
                <style name="report" id="254">
                    <property name="fontFamily">"Verdana", "Arial", sans-serif</property>
                    <property name="fontSize">70%</property>
                    <property name="marginTop">0px</property>
                    <property name="marginLeft">0.5in</property>
                    <property name="marginBottom">0.5in</property>
                    <property name="marginRight">0.5in</property>
                </style>
                <style name="main-title" id="256">
                    <property name="fontSize">150%</property>
                    <property name="color">#444E68</property>
                    <property name="borderBottomColor">#444E68</property>
                    <property name="borderBottomWidth">3px</property>
                    <property name="marginLeft">0px</property>
                    <property name="marginBottom">0px</property>
                    <property name="marginRight">0px</property>
                    <property name="paddingTop">10px</property>
                    <property name="paddingLeft">0px</property>
                    <property name="paddingRight">0px</property>
                </style>
                <style name="section-title" id="257">
                    <property name="fontSize">125%</property>
                    <property name="fontWeight">normal</property>
                    <property name="borderBottomWidth">2px</property>
                </style>
                <style name="parameter-table" id="258">
                    <property name="borderBottomStyle">none</property>
                    <property name="borderBottomWidth">0px</property>
                    <property name="borderLeftStyle">none</property>
                    <property name="borderLeftWidth">0px</property>
                    <property name="borderRightStyle">none</property>
                    <property name="borderRightWidth">0px</property>
                    <property name="borderTopStyle">none</property>
                    <property name="borderTopWidth">0px</property>
                    <property name="marginTop">15px</property>
                    <property name="marginLeft">15px</property>
                </style>
                <style name="parameter-name" id="259">
                    <property name="fontWeight">bold</property>
                    <property name="paddingRight">5px</property>
                    <property name="textAlign">left</property>
                </style>
                <style name="parameter-value" id="260">
                </style>
                <style name="table-without-group" id="261">
                    <property name="borderTopWidth">2px</property>
                </style>
                <style name="table-header-cell" id="262">
                    <property name="paddingLeft">3px</property>
                    <property name="paddingRight">3px</property>
                </style>
                <style name="group-table-without-section" id="264">
                    <property name="borderRightColor">#000000</property>
                    <property name="borderRightStyle">solid</property>
                    <property name="borderRightWidth">1px</property>
                </style>
                <style name="table-group-1" id="265">
                    <property name="backgroundColor">#7E90BF</property>
                    <property name="color">#FFFFFF</property>
                </style>
                <style name="table-group-2" id="267">
                    <property name="backgroundColor">#ABC3FF</property>
                    <property name="backgroundImage">group_2of2.gif</property>
                    <property name="backgroundRepeat">repeat-y</property>
                    <property name="fontSize">110%</property>
                </style>
                <style name="table-group-3" id="269">
                    <property name="backgroundColor">#94ABE0</property>
                </style>
                <style name="table-details" id="277">
                    <list-property name="highlightRules">
                        <structure>
                            <property name="operator">eq</property>
                            <property name="backgroundColor">#F0F0F0</property>
                            <expression name="testExpr">Total.runningCount() % 2</expression>
                            <expression name="value1">0</expression>
                        </structure>
                    </list-property>
                </style>
                <style name="secondary-title" id="279">
                    <property name="borderBottomStyle">dotted</property>
                    <property name="borderBottomWidth">thin</property>
                </style>
                <style name="chart" id="285">
                    <property name="fontFamily">"SansSerif"</property>
                    <property name="fontSize">10pt</property>
                </style>
                <style name="description-text" id="286">
                    <property name="marginBottom">15px</property>
                </style>
                <style name="date" id="287">
                        <property name="pattern">MM-dd-yy hh:mm a</property>
                    </structure>
                </style>
                <style name="section" id="291">
                    <property name="paddingTop">15px</property>
                    <property name="paddingBottom">15px</property>
                </style>
                <style name="group-data" id="293">
                    <property name="paddingLeft">3pt</property>
                    <property name="paddingBottom">3pt</property>
                    <property name="paddingRight">3pt</property>
                </style>
                <style name="group-table-with-section" id="294"/>
                <style name="message-box-style" id="295">
                    <property name="backgroundColor">#EAECF0</property>
                    <property name="borderBottomColor">#7E90BF</property>
                    <property name="borderLeftColor">#7E90BF</property>
                    <property name="borderLeftStyle">solid</property>
                    <property name="borderLeftWidth">1px</property>
                    <property name="borderRightColor">#7E90BF</property>
                    <property name="borderTopColor">#7E90BF</property>
                    <property name="marginRight">15px</property>
                    <property name="paddingLeft">0pt</property>
                    <property name="paddingRight">0pt</property>
                </style>
                <style name="table-footer-cell" id="296">
                </style>
                <style name="group-1-spacer" id="1632">
                </style>
                <style name="table-cell-highlight" id="1661">
                </style>
                <style name="sub-title" id="1662">
                </style>
                <style name="multi-column-heading-secondary-header" id="1667">
                    <property name="fontStyle">italic</property>
                </style>
            </styles>
        </theme>
        <theme name="maximoTheme" id="1674">
            <styles>
                <style name="report" id="1675">
                    <property name="backgroundColor">#FFFFFF</property>
                    <property name="fontSize">x-small</property>
                </style>
                <style name="title" id="1676">
                </style>
                <style name="titlesub" id="1677">
                </style>
                <style name="reportheaderlabel" id="1678">
                    <property name="textAlign">right</property>
                    <property name="verticalAlign">top</property>
                </style>
                <style name="reportheaderdata" id="1679">
                </style>
                <style name="tableheaderrow" id="1680">
                </style>
                <style name="tableheaderlabel" id="1681">
                    <property name="fontSize">100%</property>
                    <property name="paddingLeft">4pt</property>
                </style>
                <style name="tableheaderdata" id="1682">
                    <property name="paddingLeft">2px</property>
                </style>
                <style name="tabledetailslabel" id="1683">
                    <property name="verticalAlign">bottom</property>
                </style>
                <style name="tabledetailslabelcell" id="1684">
                    <property name="paddingTop">2px</property>
                    <property name="paddingLeft">4px</property>
                    <property name="paddingBottom">2px</property>
                </style>
                <style name="tabledetailsdatacell" id="1685">
                    <property name="borderBottomColor">#808080</property>
                </style>
                <style name="tabledetailsdatarow" id="1686">
                </style>
                <style name="summarylabel" id="1687">
                </style>
                <style name="summarydata" id="1688">
                </style>
                <style name="footer" id="1689"/>
                <style name="chart" id="1690">
                </style>
                <style name="table-header" id="1691">
                    <property name="marginTop">2px</property>
                </style>
            </styles>
        </theme>
    </themes>
    <components>
        <text name="Begin Date" id="137">
        </text>
        <text name="End Date" id="140">
        </text>
        <text name="Report Period" id="126">
        </text>
            <column id="323"/>
            <row id="326">
                <cell id="327">
                        <text-property name="content"><![CDATA[Description text goes here. Enter a short description about the report.Description text goes here. Enter a short description about the report.Description text goes here. Enter a short description about the report.Description text goes here. Enter a short description.]]></text-property>
                    </text>
                </cell>
            </row>
        </grid>
        <text name="Secondary Title or Parameter Group Heading" id="332">
            <text-property name="content"><![CDATA[Secondary Report Title]]></text-property>
        </text>
        <text name="Section Heading or Sub-title" id="172">
            <text-property name="content"><![CDATA[Section 1 Sub-Title Text]]></text-property>
        </text>
        <text name="Report Title" id="1613">
        </text>
        <grid name="Warning Message Dialog" id="5">
            <property name="style">message-box-style</property>
            <property name="width">90%</property>
            <column id="6">
                <property name="width">0.5833333333in</property>
            </column>
            <column id="7">
                <property name="width">4.5208333333in</property>
            </column>
            <row id="8">
                <cell id="1584">
                    <property name="paddingLeft">10px</property>
                    <property name="paddingRight">10px</property>
                    <property name="textAlign">center</property>
                    <image name="NewImage" id="49">
                        <property name="source">file</property>
                        <expression name="uri">"tcr_common/images/minor-2.gif"</expression>
                    </image>
                </cell>
                <cell id="1585">
                    <text name="NewText" id="1586">
                        <text-property name="content"><![CDATA[<b><font color="#444E68" style="bold"> A123456W </font></b> <br>Message text warning user that something might be wrong.<br>]]></text-property>
                    </text>
                </cell>
            </row>
        </grid>
        <grid name="Error Message Dialog" id="1587">
            <column id="1588">
            </column>
            <column id="1589">
            </column>
            <row id="36">
                <cell id="1590">
                    <image name="NewImage1" id="1591">
                        <expression name="uri">"tcr_common/images/critical-2.gif"</expression>
                    </image>
                </cell>
                <cell id="39">
                    <text name="NewText1" id="51">
                        <text-property name="content"><![CDATA[<b><font color="#444E68" style="bold"> A123456E </font></b> <br>Message text telling user something is wrong with the product and action needs to be taken to fix the problem.<br>]]></text-property>
                    </text>
                </cell>
            </row>
        </grid>
        <grid name="Information Message Dialog" id="41">
            <expression name="bookmark">"Info Message"</expression>
            <column id="42">
                <property name="width">0.583in</property>
            </column>
            <column id="43">
                <property name="width">4.6770833333in</property>
            </column>
            <row id="44">
                <cell id="45">
                    <image name="NewImage2" id="46">
                        <expression name="uri">"tcr_common/images/information-2.gif"</expression>
                    </image>
                </cell>
                <cell id="47">
                    <text name="NewText2" id="52">
                        <text-property name="content"><![CDATA[<b><font color="#444E68" style="bold"> A123456I </font></b> <br>Message text providing some information to the user.<br>]]></text-property>
                    </text>
                </cell>
            </row>
        </grid>
        <image name="Collapse Icon" id="1633">
            <expression name="uri">"tcr_common/images/collapse.gif"</expression>
        </image>
        <image name="Critical Icon" id="1634">
            <expression name="uri">"tcr_common/images/critical.gif"</expression>
        </image>
        <image name="Critical Large Icon" id="1635">
        </image>
        <image name="Expand Icon" id="1636">
            <expression name="uri">"tcr_common/images/expand.gif"</expression>
        </image>
        <image name="Fatal Icon" id="1637">
            <expression name="uri">"tcr_common/images/fatal.gif"</expression>
        </image>
        <image name="Fatal Large Icon" id="1638">
            <expression name="uri">"tcr_common/images/fatal-2.gif"</expression>
        </image>
        <image name="IBM Logo" id="1639">
            <expression name="uri">"tcr_common/images/IBM logo Black.gif"</expression>
        </image>
        <image name="Information Icon" id="1640">
            <expression name="uri">"tcr_common/images/information.gif"</expression>
        </image>
        <image name="Information Large Icon" id="1641">
        </image>
        <image name="Minor Icon" id="1642">
            <expression name="uri">"tcr_common/images/minor.gif"</expression>
        </image>
        <image name="Minor Large Icon" id="1643">
        </image>
        <image name="Normal Icon" id="1644">
            <expression name="uri">"tcr_common/images/normal.gif"</expression>
        </image>
        <image name="Normal Large Icon" id="1645">
            <expression name="uri">"tcr_common/images/normal-2.gif"</expression>
        </image>
        <image name="Tivoli Logo" id="1646">
            <expression name="uri">"tcr_common/images/tivoli.gif"</expression>
        </image>
        <image name="Unknown Icon" id="1647">
            <expression name="uri">"tcr_common/images/unknown.gif"</expression>
        </image>
        <image name="Unknown Large Icon" id="1648">
            <expression name="uri">"tcr_common/images/unknown-2.gif"</expression>
        </image>
        <image name="Warning Icon" id="1649">
            <expression name="uri">"tcr_common/images/warning.gif"</expression>
        </image>
        <image name="Warning Large Icon" id="1650">
            <expression name="uri">"tcr_common/images/warning-2.gif"</expression>
        </image>
        <data name="Begin Date Value" id="1655">
            </structure>
                <structure>
                    <property name="name">Column Binding</property>
                    <property name="displayName">Begin Date Value</property>
                    <expression name="expression">getStartDateFromGroupNames("Report Period","Begin Date","End Date")</expression>
                </structure>
            </list-property>
        </data>
        <data name="End Date Value" id="1656">
            </structure>
                <structure>
                    <property name="displayName">End Date Value</property>
                    <expression name="expression">getEndDateFromGroupNames("Report Period","Begin Date","End Date")</expression>
                </structure>
            </list-property>
        </data>
        <data name="Report Period Value" id="1657">
                <structure>
                    <property name="displayName">Report Period Value</property>
                    <expression name="expression">getReportPeriodFromGroupNames("Report Period","Begin Date","End Date")</expression>
                </structure>
            </list-property>
        </data>
        <image name="Heat Chart Bad Icon" id="1668">
            <expression name="uri">"tcr_common/images/hc_bad_legend.gif"</expression>
        </image>
        <image name="Heat Chart Good Icon" id="1669">
            <expression name="uri">"tcr_common/images/hc_best_legend.gif"</expression>
        </image>
        <image name="Heat Chart Warning Icon" id="1670">
            <expression name="uri">"tcr_common/images/hc_fair_legend.gif"</expression>
        </image>
        <image name="Heat Chart Fair Icon" id="1671">
            <expression name="uri">"tcr_common/images/hc_good_legend.gif"</expression>
        </image>
        <image name="Heat Chart Critical Icon" id="1672">
            <expression name="uri">"tcr_common/images/hc_really_bad_legend.gif"</expression>
        </image>
        <image name="Heat Chart Unknown Icon" id="1673">
            <expression name="uri">"tcr_common/images/hc_unknown_legend.gif"</expression>
        </image>
        <label name="Style Package Version" id="1666">
            <text-property name="text">Style Package Version 1.2.0.2</text-property>
        </label>
    </components>
    <page-setup>
        <simple-master-page name="TCR Master Page" id="3">
            <page-header>
                <grid id="9">
                    <column id="10"/>
                    <column id="11"/>
                    <row id="12">
                        <cell id="13">
                            <image id="37">
                            </image>
                        </cell>
                        <cell id="14">
                            <image id="38">
                            </image>
                        </cell>
                    </row>
                </grid>
            </page-header>
            <page-footer>
                <grid id="19">
                    <column id="20"/>
                    <column id="301">
                        <property name="width">1.46875in</property>
                    </column>
                    <column id="21">
                        <property name="width">2.9479166667in</property>
                    </column>
                    <row id="22">
                        <cell id="23">
                            <property name="colSpan">2</property>
                            <data name="NewData" id="1659">
                                <property name="paddingTop">1pt</property>
                                    <property name="category">General Date</property>
                                    <property name="pattern">General Date</property>
                                </structure>
                                    <structure>
                                        <property name="displayName">Date</property>
                                        <expression name="expression">new Date()</expression>
                                    </structure>
                                </list-property>
                            </data>
                        </cell>
                        <cell id="24">
                            <grid id="25">
                                <column id="26">
                                    <property name="width">2.1145833333in</property>
                                </column>
                                <column id="27">
                                    <property name="width">0.2083333333in</property>
                                </column>
                                <column id="28">
                                    <property name="width">0.5625in</property>
                                </column>
                                <row id="29">
                                    <cell id="30">
                                        <property name="paddingLeft">50pt</property>
                                        <auto-text id="31">
                                            <property name="type">page-number</property>
                                        </auto-text>
                                    </cell>
                                    <cell id="32">
                                        <text id="33">
                                            <property name="contentType">plain</property>
                                            <text-property name="content"><![CDATA[/]]></text-property>
                                        </text>
                                    </cell>
                                    <cell id="34">
                                        <auto-text id="35">
                                            <property name="type">total-page</property>
                                        </auto-text>
                                    </cell>
                                </row>
                            </grid>
                        </cell>
                    </row>
                </grid>
            </page-footer>
        <simple-master-page name="maximoLandscape" id="1692">
            <property name="orientation">landscape</property>
            <property name="topMargin">0.5in</property>
            <property name="leftMargin">0.5in</property>
            <property name="bottomMargin">0.5in</property>
            <property name="rightMargin">0.5in</property>
            <page-header>
                <grid name="NewGrid2" id="1693">
                    <column id="1694">
                        <property name="width">5in</property>
                    </column>
                    <column id="1695">
                    </column>
                    <row id="1696">
                        <cell id="1697">
                            <image id="1698">
                                <expression name="uri">"tivoli.gif"</expression>
                            </image>
                        </cell>
                        <cell id="1699">
                            &l
Re: cannot override report parameter list from rptlibrary [message #671661 is a reply to message #671598] Wed, 18 May 2011 11:02 Go to previous messageGo to next message
The whole library did not come through. When you change the library are
you changing in the tcr_common/lib folder of the resource directory?
The resource directory is set in the preferences:
Window->preferences->Report Design->Resource
Jason
> rptlibrary is <parameter-group name="Date Range" id="1716"
> <2.2.0.v20070924-1550></property>
> <property
> of IBM
> 5724-T69 IBM Tivoli Reporting
> Designer tool.
> setupLogging();
> logInitialize();
> var valueis =
> var valueis1 =
> var xx1 =
> // var xx =
> <method
> <method
> <property
> <structure>
> <property
> <property
> </structure>
> </list-property>
> </list-property>
> <parameters>
> <property
> <property
> <expression
> <expression
> <property
> </structure>
> </scalar-parameter>
> <property
> <property
> </structure>
> <structure>
> Hours</property>
> </structure>
> <structure>
> Days</property>
> </structure>
> <structure>
> Days</property>
> </structure>
> <structure>
> Days</property>
> </structure>
> <structure>
> Days</property>
> <property
> </structure>
> <structure>
> Week</property>
> </structure>
> <structure>
> Week</property>
> </structure>
> <structure>
> Month</property>
> </structure>
> <structure>
> Month</property>
> </structure>
> <structure>
> Months</property>
> </structure>
> <structure>
> Date</property>
> </structure>
> <structure>
> <property
> </structure>
> <structure>
> Hours</property>
> </structure>
> <structure>
> Days</property>
> </structure>
> <structure>
> Days</property>
> </structure>
> <structure>
> Days</property>
> </structure>
> <structure>
> Days</property>
> <property
> </structure>
> <structure>
> Week</property>
> </structure>
> <structure>
> Week</property>
> </structure>
> <structure>
> Month</property>
> </structure>
> <structure>
> Month</property>
> </structure>
> <structure>
> Months</property>
> </structure>
> <structure>
> Date</property>
> </structure>
> </list-property>
> </scalar-parameter>
> <property
> yyyy</property>
> </structure>
> </scalar-parameter>
> </parameters>
> <data-sources>
> <oda-data-source
> <property
> <property
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> <property
> <property
> <property
> </structure>
> <structure>
> <property
> <property
> <property
> </structure>
> <structure>
> <property
> <property
> <property
> </structure>
> <structure>
> <property
> <property
> <property
> </structure>
> </list-property>
> </structure>
> <property
> this.queryText);
> var valueis =
> try {
> // Filter on Customer Name var cust_name = params["Customer Name"].value;
> // Filter on Report Period var report_period = params["Report
> Period"].value;
> this.queryText);
> } catch (ex) {
> }]]></method>
> <structure>
> <property
> <property
> <property
> <property
> </structure>
> <structure>
> <property
> <property
> <property
> <property
> </structure>
> <structure>
> <property
> <property
> <property
> <property
> </structure>
> <structure>
> <property
> <property
> <property
> </structure>
> </list-property>
> cus.CUSTOMERNAME,
> <xml-property
> encoding="UTF-8"?>
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:query>
> order by
> </design:query>
> <design:properties>
> <design:nameValue>
> </design:nameValue>
> <design:resultSets>
> <design:attributes>
> <design:valueColumn>dataSetRow["CUSTOMERNAME"]</design:valueColumn>
> <design:uiHints>
> </design:uiHints>
> </oda-data-set>
> <oda-data-set
> <structure>
> <property
> <property
> <property
> </structure>
> </list-property>
> </structure>
> <property
> <structure>
> <property
> <property
> <property
> <property
> </structure>
> </list-property>
> <xml-property
> encoding="UTF-8"?>
> <model:DesignValues
> <design:attributes>
> <design:usageHints>
> </oda-data-set>
> </data-sets>
> <page-setup>
> <overridden-values>
> id="1712"/>
> </page-setup>
> <body>
> <column id="224"/>
> <row id="225">
> <cell id="226">
> <property
> <property
> </text>
> </cell>
> </row>
> <row id="231">
> <cell id="232">
> <property
> <structure>
> <property
> <expression
> </structure>
> </list-property>
> <property
> </text>
> </cell>
> </row>
> <row id="1686">
> <cell id="1687">
> <property
> <property
> <column id="96">
> <property
> </column>
> <column id="97">
> <property
> </column>
> <column id="98">
> <property
> </column>
> <column id="99">
> <property
> </column>
> <row id="100">
> <cell id="101">
> <property
> 1" id="214">
> <property
> <text-property
> </text>
> </cell>
> <cell id="102">
> <property
> <property
> <property
> <data id="1683">
> <list-property
> <structure>
> <property
> <expression
> <property
> </structure>
> </list-property>
> <property
> </data>
> </cell>
> <cell id="103">
> <property
> id="1677">
> <property
> <text-property
> </text>
> </cell>
> <cell id="104">
> <property
> <property
> <property
> Period Value">
> <property
> </data>
> </cell>
> </row>
> <row id="105">
> <list-property
> name="visibility">
> <structure>
> <property
> <expression
> </structure>
> </list-property>
> <cell id="106">
> <property
> id="1679">
> <property
> <text-property
> </text>
> </cell>
> <cell id="107">
> <property
> <property
> Date Value">
> <property
> </data>
> </cell>
> <cell id="108">
> <property
> id="1680">
> <property
> <text-property
> </text>
> </cell>
> <cell id="109">
> <property
> <property
> Value">
> <property
> </data>
> </cell>
> </row>
> </grid>
> </cell>
> </row>
> </grid>
> 1"</expression>
> <column id="163"/>
> <row id="168">
> <cell id="169">
> <property
> <property
> <property
> <property
> <property
> <structure>
> <property
> <expression
> </structure>
> </list-property>
> <list-property
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> <structure>
> <property
> <expression
> <property
> </structure>
> </list-property>
> <column id="1691">
> <property
> </column>
> <column id="394"/>
> <column id="1589"/>
> <column id="395">
> <property
> </column>
> <group id="1659">
> <property
> <property
> <property
> <expression
> <expression
> </structure>
> <property
> <property
> <property
> <property
> <header>
> <row id="1669">
> <cell id="1688">
> <property
> <property
> <property
> <property
> <data id="1668">
> <property
> <property
> </data>
> </cell>
> </row>
> <row id="1673">
> <property
> <property
> <cell id="1689">
> <property
> <property
> <property
> <property
> </cell>
> <cell id="1674">
> <property
> <property
> <property
> <property
> <text id="400">
> <property
> <text-property
> </text>
> </cell>
> <cell id="1675">
> <property
> <property
> <property
> <property
> <text id="1590">
> <property
> <text-property
> name="content"
> </text>
> </cell>
> <cell id="1676">
> <property
> <property
> <property
> <property
> <text id="401">
> <property
> <text-property
> </text>
> </cell>
> </row>
> </header>
> <footer>
> <row id="1697">
> <property
> <cell id="1698">
> <property
> <property
> <property
> </cell>
> <cell id="1699">
> <property
> <property
> <property
> </cell>
> <cell id="1700">
> <property
> <property
> <property
> </cell>
> <cell id="1701">
> <property
> <property
> <property
> </cell>
> </row>
> </footer>
> </group>
> <detail>
> <row id="386">
> <cell id="1690">
> <property
> </cell>
> <cell id="387">
> <property
> <data id="1585">
> <structure
> <property
> <property
> </structure>
> <property
> </data>
> </cell>
> <cell id="1587">
> <property
> <data id="1591">
> <property
> </data>
> </cell>
> <cell id="389">
> <property
> <data id="1592">
> <structure
> <property
> <property
> </structure>
> <property
> </data>
> </cell>
> </row>
> </detail>
> </table>
> Message Dialog">
> <structure>
> <property
> <expression
> </structure>
> </list-property>
> <overridden-values>
> id="42"/>
> id="43"/>
> id="1708"/>
> id="45"/>
> id="47"/>
> <property
> name="content"><b><font color="#444E68"
> style="bold"><VALUE-OF>getNLS("msg_hdr_dataset_empty");</VALUE-OF>
> </font></b> <br>
> <VALUE-OF>getNLS("msg_dataset_empty");</VALUE-OF> </br></property>
> <property
> </ref-entry>
> </grid>
> </cell>
> </row>
> </grid>
> <column id="323"/>
> <row id="326">
> <cell id="327">
> <property
> <property
> </text>
> </cell>
> </row>
> </grid>
> </body>
> </report>
Re: cannot override report parameter list from rptlibrary [message #671828 is a reply to message #671661] Thu, 19 May 2011 02:25 Go to previous messageGo to next message
"The whole library did not come through", sorry, what does this mean?
for resource folder in eclipse preference page, I confirm it is correct.
the problem now is when I try to delete some property in the date range parameter, for example, delete the choice of "today" in date range parameter (date range parameter is extends from rptlibrary), then save, then reopen the date range parameter, I found the property (the choice of "today") has not been deleted.
is this a bug of birt designer 2.2.1 which cannot override the property of parameter in parameter group extends from rptlibrary?
Re: cannot override report parameter list from rptlibrary [message #671978 is a reply to message #671828] Thu, 19 May 2011 09:52 Go to previous message
Yes this does appear to be a bug in 2.2.1. It functions correctly in
later versions of BIRT. To get around it in 2.2.1 open the parameter in
the designer remove the choice item and then select the xml view. It
will all the items in the list locally to the parameter.
<scalar-parameter name="listparm" id="6"
extends="mylibrary.listparm">
</structure>
<structure>
<property name="value">value1</property>
</structure>
<structure>
<property name="value">value2</property>
</structure>
<structure>
</structure>
</list-property>
</scalar-parameter>
Remove the entries you do not want there. The above I could change to:
</structure>
<structure>
</structure>
</list-property>
</scalar-parameter>
This will de-reference the selectionList property so updates to the list
in the library will not show up in the report.
Jason
Previous Topic:Help with BIRT reports (Maximo)
Next Topic:Best way to design a Report
Current Time: Wed Jul 23 04:19:17 EDT 2025
Powered by FUDForum. Page generated in 0.55713 seconds
