Home » Modeling » GMF (Graphical Modeling Framework) » Adding a compartment to my node(According to GMF_Tutorial_Part_2)
Adding a compartment to my node [message #671213] Tue, 17 May 2011 03:11 Go to next message
Hi all,
I'm following this tutorial in order to add SubSystems into my node System.
My ecore model is actually :
RootElement <>---->[1] System <>---->[*] SubSystem
I managed to add a compartment to my System and add SubSystems into, but I can't drag and drop my new SubSystem into. I can't resize it either. If I add a second SubSystem, it will be placed below the first one. Can't move neither.
How can I modify this behaviour please ?
My GMFgraph :
<gmfgraph:Canvas xmi:version="2.0"
    xmlns:gmfgraph="http://www.eclipse.org/gmf/2006/GraphicalDefinition" name="systemModel">
  <figures
      name="Default">
    <descriptors
        name="SystemFigure">
      <actualFigure
          xsi:type="gmfgraph:Rectangle"
        <foregroundColor
            xsi:type="gmfgraph:RGBColor"
            red="220"
            green="220"
            blue="250"/>
        <children
            xsi:type="gmfgraph:Label"
            name="SystemNameFigure"
            text="&lt;...>"/>
      </actualFigure>
      <accessors
          figure="//@figures.0/@descriptors.0/@actualFigure/@children.0"/>
    </descriptors>
    <descriptors
        name="SubSystemFigure">
      <actualFigure
          outline="false">
        <layout
            xsi:type="gmfgraph:FlowLayout"
            vertical="true"
            matchMinorSize="true"
            forceSingleLine="true"
            minorAlignment="CENTER"
            majorSpacing="0"
            minorSpacing="0"/>
        <backgroundColor
            red="250"
            green="250"
            blue="190"/>
      </actualFigure>
    </descriptors>
  </figures>
  <nodes
      name="System"
      figure="SystemFigure"/>
  <nodes
      name="SubSystem (SubSystemFigure)"
      figure="SubSystemFigure"/>
  <compartments
      name="SubSystemCompartment"
      collapsible="true"/>
  <labels
      name="SystemName"
      accessor="//@figures.0/@descriptors.0/@accessors.0"/>
</gmfgraph:Canvas>
Nicolas
[Updated on: Tue, 17 May 2011 03:12] by Moderator
Re: Adding a compartment to my node [message #671219 is a reply to message #671213] Tue, 17 May 2011 03:25 Go to previous messageGo to next message
In the class xxxcompartementEditPart you have:
* @generated
public class xxxxxcompartementEditPart extends ListCompartmentEditPart {
you should modifiy to:
* @generated NOT
public class xxxxxcompartementEditPart extends ShapeCompartmentEditPart {
Rahma
[SOLVED] Adding a compartment to my node [message #671235 is a reply to message #671219] Tue, 17 May 2011 04:41 Go to previous message
That works very well, thank you very much Wink
Nicolas
Previous Topic:GMF - Drag Drop on Connection
Next Topic:Open Editor from DB
Current Time: Sat Jul 26 02:40:42 EDT 2025
Powered by FUDForum. Page generated in 0.04244 seconds
