Home » Modeling » M2T (model-to-text transformation) » [ACCELEO] fonction standard (fonction prédefinis)(salut SVP quels sont les fonction prédifinis dans acceleo??)
[ACCELEO] fonction standard (fonction prédefinis) [message #671178] Mon, 16 May 2011 23:10 Go to next message
i need some standard functions to complete my work but i cant find any one just if you can give the function like hasNexte()
Re: [ACCELEO] fonction standard (fonction prédefinis) [message #671241 is a reply to message #671178] Tue, 17 May 2011 05:11 Go to previous messageGo to next message
The available operations in Acceleo can be found here and there.
Now, if you are in the middle of an iteration on a collection and if you want to know if there are other elements, you can use something like this:
[for (aString : String | mySequenceOfString)]
[if (i < mySequenceOfString->size())]not the end[/if]
[/for]
The variable named "i" is available inside of a for in order to know the current iteration on the collection.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Acceleo wiki: http://wiki.eclipse.org/Acceleo
Blogs: http://stephanebegaudeau.tumblr.com & http://sbegaudeau.tumblr.com
[Updated on: Tue, 17 May 2011 05:12] by Moderator
Re: [ACCELEO] fonction standard (fonction prédefinis) [message #671950 is a reply to message #671241] Thu, 19 May 2011 08:39 Go to previous message
thank you very much
Previous Topic:XPand Multiplicity
Next Topic:[xpand, uml2] Support for RSA 8
Current Time: Sat Jul 19 11:18:52 EDT 2025
Powered by FUDForum. Page generated in 0.05095 seconds
