Home » Archived » BIRT » Which occurs first
Which occurs first [message #671107] Mon, 16 May 2011 15:15 Go to next message
Hi All,
Quick question.
In Data Set processing, which occurs first:
Filtering of the Dataset or Computing the "Computed Columns"?
Asked differently, can I use a Computed Column in a Filter?
If it matters, we are using version 2.5.2.
Mark
Re: Which occurs first [message #671124 is a reply to message #671107] Mon, 16 May 2011 15:47 Go to previous message
You can use a computed column in a filter. Generally the filter will
occur first but if you use a computed column in the filter I believe the
computed columns will be generated first.
Jason
On 5/16/2011 3:15 PM, Mark Victory wrote:
> Hi All,
> Quick question.
> Columns"?
> Mark
Previous Topic:Plugin not visible in Report Designer View
Next Topic:IHTMLImageHandler not used when rendering images embedded using <IMAGE> tag
Current Time: Wed Jul 23 14:52:50 EDT 2025
Powered by FUDForum. Page generated in 0.03302 seconds
