Home » Archived » Test and Performance Tools Platform (TPTP) » Filter Set locations
Filter Set locations [message #67108] Wed, 19 April 2006 09:46 Go to next message
We have our launch prfiles under source control and Im looking to also VC
and to share out the Filter sets. Im seeing a line added to the launch
profiles such as
<stringAttribute key="org.eclipse.hyades.trace.ui.ATTR_PROFILING_SET"
value="New Profiling Set1145383182645"/>
and
<stringAttribute key="org.eclipse.hyades.trace.ui.ATTR_FILTER_SET"
value="org.eclipse.hyades.trace.ui.Subscription1145414654710 "/>
I cant seem to locate how they are stored and shared out when I select
other launch profiles and navigate to the Profile tab.
Jason
Re: Filter Set locations [message #67389 is a reply to message #67108] Fri, 21 April 2006 11:04 Go to previous message
Take a look at ProfilingSetsManager under the plug-in
If you're using TPTP 4.2i2+, then you might find the following document
useful:
http://www.eclipse.org/tptp/home/documents/tutorials/datacol lection/launch-extensions/extending-launch-configuration.htm l
"Jason" <jevans12@harris.com> wrote in message
news:7708cc96e253c0c342d467cb2433516f$1@www.eclipse.org...
> profiles such as
> and
> Cheers,
> Jason
Previous Topic:No Diagram in Manual test report.
Next Topic:AGR problems with Search dialog
Current Time: Tue Nov 04 07:34:10 EST 2025
Powered by FUDForum. Page generated in 0.04996 seconds
