Home » Eclipse Projects » Rich Client Platform (RCP) » toggle state not persisted
icon9.gif  toggle state not persisted [message #670810] Sun, 15 May 2011 13:29 Go to next message
Hi there,
I am using v3.5.2
Despite setting the persisted parameter to true, the state isn't stored between two sessions.
Here is how I define the command:
      <command
            defaultHandler="xyz.example.commands.menuColumns.NameHandler"
            id="xyz.example.commands.menuColumns.name"
            name="Name">
         <state
               class="org.eclipse.ui.handlers.RegistryToggleState"
               id="org.eclipse.ui.commands.toggleState">
            <class
                  class="org.eclipse.ui.handlers.RegistryToggleState">
               <parameter
                     name="persisted"
                     value="true">
               </parameter>
            </class>
         </state>
      </command>
And here some code of the menu contribution part:
<command
                     commandId="xyz.example.commands.menuColumns.name"
                     label="Name"
                     style="toggle">
               </command>
Any help will be appreciated!
Re: toggle state not persisted [message #670993 is a reply to message #670810] Mon, 16 May 2011 09:21 Go to previous message
There doesn't appear to be anything wrong with your XML, and a brief examination of the code seems to indicate that it was available in 3.5.x. Here's an example to look at:
      <command
            categoryId="org.eclipse.ui.category.edit"
            defaultHandler="org.eclipse.example.commands.MonitorCountHandler"
            id="org.eclipse.example.commands.monitorCount"
            name="Monitor Count">
         <state
               class="org.eclipse.ui.handlers.RegistryToggleState:false"
         </state>
      </command>
and then in the toolbar something like:
            <command
                  commandId="org.eclipse.example.commands.monitorCount"
                  icon="images/collapseall.gif"
                  style="toggle">
            </command>
The handler then uses org.eclipse.ui.handlers.HandlerUtil.toggleCommandState(Comma nd) to work with the command State object.
The example is at https://github.com/paulweb515/commandsEclipseCon2011 in the org.eclipse.example.commands plugin.
PW
Previous Topic:Problem exporting: A cycle was detected when generating the classpath
Next Topic:How to add functionality to an existing View using a PlugIn
Current Time: Sat Aug 30 23:22:51 EDT 2025
Powered by FUDForum. Page generated in 0.03407 seconds
