Home » Modeling » Epsilon » setMaximumSize
setMaximumSize [message #669320] Mon, 09 May 2011 17:50 Go to next message
Could anyone tell me why the method "setMaximumSize" the example below is not working?
public class BoxFigure extends RectangleFigure {
* @generated
private WrappingLabel fFigureBoxLabelFigure;
* @generated
private RectangleFigure fBoxContentCompartmentFigure;
* @not generated
public BoxFigure() {
this.setPreferredSize(new Dimension(getMapMode().DPtoLP(150),
getMapMode().DPtoLP(100)));
this.setBorder(new MarginBorder(getMapMode().DPtoLP(5),
getMapMode().DPtoLP(5), getMapMode().DPtoLP(5),
getMapMode().DPtoLP(5)));
this.setMaximumSize(new Dimension(getMapMode().DPtoLP(300),
getMapMode().DPtoLP(200)));
this.setMinimumSize(new Dimension(getMapMode().DPtoLP(150),
createContents();
Thanks a lot!
Elvis
Re: setMaximumSize [message #669568 is a reply to message #669320] Tue, 10 May 2011 14:34 Go to previous messageGo to next message
We'd need a bit more information to help you. Could you please expand a bit more on what do you mean by "not working", and the rest of your code?
Re: setMaximumSize [message #670369 is a reply to message #669568] Fri, 13 May 2011 13:23 Go to previous messageGo to next message
Hi Antonio,
Thanks for the help, the issue is that I'm not able to use the method "setMaximumSize" the method "setMinimumSize" works correctly: can't reduce the element beyond what is allowed. Already the method "setMaximumSize(new Dimension(getMapMode().DPtoLP(300), getMapMode().DPtoLP(200)));" not prevent the extension of the element to the size of 600 x 400 for example.
Down the BoxEditPart (XXX.diagram.edit.parts):
* @generated
* @generated
* @generated NOT
this.setPreferredSize(new Dimension(getMapMode().DPtoLP(100),
getMapMode().DPtoLP(50)));
createContents();
* @generated
private void createContents() {
fFigureBoxLabelFigure = new WrappingLabel();
fFigureBoxLabelFigure.setText("Box");
this.add(fFigureBoxLabelFigure);
* @generated
public WrappingLabel getFigureBoxLabelFigure() {
return fFigureBoxLabelFigure;
Re: setMaximumSize [message #670385 is a reply to message #670369] Fri, 13 May 2011 14:41 Go to previous messageGo to next message
Hi Elvis,
Your problem seems to be specific to GEF. I think you'll get a much better answer if you ask your question at the GEF forum. You see, the Eugenia tool in Epsilon only generates the GMF models: the actual code is produced by GMF, and this code relies on the Graphical Editing Framework (GEF).
Re: setMaximumSize [message #671092 is a reply to message #670385] Mon, 16 May 2011 14:20 Go to previous message
Ok Antonio, I'll post there. thank you
Previous Topic:[eol] question about usage of native types
Next Topic:[Epsilon] Supported comment markers for eol languages
Current Time: Sat Jul 26 07:50:30 EDT 2025
Powered by FUDForum. Page generated in 0.07773 seconds
