Home » Modeling » Epsilon » [Epsilon] Supported comment markers for eol languages
[Epsilon] Supported comment markers for eol languages [message #670319] Fri, 13 May 2011 10:00 Go to next message
Through the Epsilon Book comments in the source code are declared by usinng "//" or "--". However I can not seem to find a concrete description of the supported comment markers. I have used Java style multi-line comments "/* ... */" and they also seem to be supported. However, when using this style, the editor fails to correctly detect the closing "*/" when creating the comment or editing it and the rest of the source code is highlighted as comments. IF I save the file, the parser does not complaint so I guess the comments are being parsed correctly. If I close and reopen the file the highlighting is fixed and comment coloring is kept correctly until the "*/".
Is this a bug in the eol editor/tokenizer,or are Java style comments not fully supported?
Horacio
Re: [Epsilon] Supported comment markers for eol languages [message #670386 is a reply to message #670319] Fri, 13 May 2011 14:54 Go to previous messageGo to next message
Hi Horacio,
I have looked at the ANTLR grammar used by EOL and it seems it is a bug in the EOL editor. EOL accepts -- and // for line comments, and -* *- and /* */ for block comments.
Could you file a bug for /* */ and post the number here? I'll take care of it. For the time being, -* *- should work.
Antonio
Re: [Epsilon] Supported comment markers for eol languages [message #671166 is a reply to message #670386] Mon, 16 May 2011 20:05 Go to previous message
Antonio,
I opened the bug as requested: https://bugs.eclipse.org/bugs/show_bug.cgi?id=346016
Horacio
Previous Topic:setMaximumSize
Next Topic:Model Transformation Round-trip
Current Time: Sat Jul 26 03:12:06 EDT 2025
Powered by FUDForum. Page generated in 0.28297 seconds
