Home » Language IDEs » PHP Development Tools (PDT) » PDT word completion fails with PHP singleton(PDT word completion fails to find methods of a PHP singleton instance.)
icon5.gif  PDT word completion fails with PHP singleton [message #669834] Wed, 11 May 2011 14:09 Go to next message
I have a basic singleton class, similar to the one shown in the PHP documentation:
// Based on Example from
// us2.php.net/manual/en/language.oop5.patterns.php#language.oop5.patterns.singleton
class Example {
    private static $instance;
    private function __construct()
        echo 'I am constructed';
    public static function singleton()
        if (!isset(self::$instance)) {
            $c = __CLASS__;
            self::$instance = new $c;
        return self::$instance;
    public function myMethod() {
        return 'This is my method';
The code I write to get an instance of this class is:
$myExample = Example::singleton();
Using PDT, if I try to use its word completion to find the method myMethod in this instance, it fails. That is, if I type the following in the editor:
$myExample->
And immediately after the "->", I press the key combination for word completion (ctrl-space on my computer), Eclipse tells me "No Default Proposals".
How can I make word completion work? Do I need to configure Eclipse differently? Do I need to write my singleton a different way?
[Updated on: Wed, 11 May 2011 14:17] by Moderator
Re: PDT word completion fails with PHP singleton [message #670306 is a reply to message #669834] Fri, 13 May 2011 09:22 Go to previous message
I received an answer to this problem by posting to stackoverflow.com. See:
stackoverflow.com/questions/5982323/eclipse-pdt-word-complet ion-fails-for-php-singleton-instances#
stackoverflow.com appears to be a more active and knowledgeable forum for Eclipse discussions than the Eclipse forum is. (And it doesn't have the limitation of posting five messages before I can use actual links in my messages.)
Previous Topic:[Solved] Spell checking isn't working
Next Topic:Saving .sql always opens Save As
Current Time: Sat Jul 26 20:30:30 EDT 2025
Powered by FUDForum. Page generated in 0.04598 seconds
