Home » Eclipse Projects » JFace » Drag and Drop with Button
Drag and Drop with Button [message #669999] Thu, 12 May 2011 07:43 Go to next message
Hi all,
so I implemented a drag and drop support for 2 treeviewer, I can transfer data between the both treeviewer by moving the element with the mouse. Now I want to add a button to also transfer the data. How can I do this?
Best regards
Re: Drag and Drop with Button [message #670001 is a reply to message #669999] Thu, 12 May 2011 07:45 Go to previous message
An use case: select the element in the left treeviewer, press the button. The element will be transfered to the right treeviewer.
Previous Topic:JFace TreeViewer
Next Topic:Can (Should) TableViewer be extended?
Current Time: Sat Jul 26 11:05:37 EDT 2025
Powered by FUDForum. Page generated in 0.30304 seconds
