Home » Eclipse Projects » JFace » Table Viewer - Can the extra padding on each table cell be removed
Table Viewer - Can the extra padding on each table cell be removed [message #669881] Wed, 11 May 2011 19:35 Go to next message
I have a table viewer with 2 rows and 80 columns created.
Each of the table cells would contain a maximum of 2 characters and based on this I am trying to remove the extra padding in each cell and could not figure this out.
Here is how the code looks like..
// Code to create the table viewer and columns
int style = SWT.BORDER | SWT.FULL_SELECTION | SWT.HIDE_SELECTION;
TableViewer tableViewer = new TableViewer(parent, style);
int maximumWidth = 80;
String tableColumnNames[] = new String[maximumWidth];
for (int i = 0; i < maximumWidth; i++){
tableColumnNames[i] = String.valueOf(i);
TableViewerColumn column = new TableViewerColumn(tableViewer, SWT.NONE);
column.getColumn().setWidth(30);
// Code to set text in to each cell
// tableViewer.setInput(model);
// Now that we've set the text into the columns,
// we call pack() on each one to size it to the
// contents.
for (int i = 0; i < tableViewer.getTable().getColumnCount(); i++) {
TableColumn column = tableViewer.getTable().getColumn(i);
column.pack();
Even with the above code, I see that there is lot of extra padding on each table cell. Is it possible to remove the extra cell padding in each table cell ?
Any other ideas ? Please help.
Pavan
Re: Table Viewer - Can the extra padding on each table cell be removed [message #670070 is a reply to message #669881] Thu, 12 May 2011 10:36 Go to previous message
Hi Pavan,
The only way to do this is to draw the item texts yourself, and to specify
their widths so that their columns will pack() tighter. The snippet below
demonstrates this at the SWT level (table1 is a typical Table, while table2
has the three custom draw callbacks added). TableViewer exposes the SWT
Table's custom draw functionality through its owner draw facilities, for an
example of using them see
http://dev.eclipse.org/viewcvs/viewvc.cgi/org.eclipse.jface. snippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippe ts/viewers/Snippet010OwnerDraw.java?view=markup .
Also, for more info on using custom draw in Tables and Trees see article
http://www.eclipse.org/articles/article.php?file=Article-Cus tomDrawingTableAndTreeItems/index.html .
public class Main {
static int COLUMN_COUNT = 5;
final Display display = new Display();
Shell shell = new Shell(display);
shell.setBounds(10,10,600,200);
Table table1 = createTable(shell);
table1.setBounds(10,10,200,150);
final Table table2 = createTable(shell);
table2.setBounds(300,10,200,150);
table2.addListener(SWT.MeasureItem, new Listener() {
public void handleEvent(Event event) {
/* ensure that the columns will pack() tightly */
int[] widths = (int[])event.item.getData();
if (widths == null) {
widths = new int[COLUMN_COUNT];
TableItem item = (TableItem)event.item;
GC gc = new GC(table2);
for (int i = 0; i < COLUMN_COUNT; i++) {
String text = item.getText(i);
widths[i] = gc.stringExtent(text).x;
gc.dispose();
item.setData(widths);
event.width = widths[event.index];
table2.addListener(SWT.EraseItem, new Listener() {
/* tell the native to table to not draw the foreground content,
we'll do it */
event.detail &= ~SWT.FOREGROUND;
table2.addListener(SWT.PaintItem, new Listener() {
/* draw the foreground content */
event.gc.drawString(item.getText(event.index), event.x,
event.y);
table1.getColumn(i).pack();
table2.getColumn(i).pack();
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
display.dispose();
static Table createTable(Composite parent) {
Table table = new Table(parent, SWT.NONE);
table.setLinesVisible(true);
new TableColumn(table, SWT.NONE);
TableItem item = new TableItem(table, SWT.NONE);
item.setText(i, "text");
return table;
HTH,
Grant
"Pavan K Immaneni" <forums-noreply@eclipse.org> wrote in message
news:iqf609$e5u$1@news.eclipse.org...
> SWT.HIDE_SELECTION;
> // contents.
> i++) {
> column.pack();
> Pavan
Previous Topic:Table Viewer - How to control the Page Up and Page Down behavior
Next Topic:Table Viewer - Can the extra padding on each table cell be removed
Current Time: Fri Jul 25 08:32:41 EDT 2025
Powered by FUDForum. Page generated in 0.03488 seconds
