Home » Modeling » BPEL Designer » The [action] cannot be processed at the reciever(problem with invoke block using BPEL designer and Apache ODE)
The [action] cannot be processed at the reciever [message #669759] Wed, 11 May 2011 08:29 Go to next message
I'm creating BPEL Workflow with Eclipse BPEL plugin and Apache ODE (BPEL engine).
Apache ODE is running with Axis2 on Tomcat 7.
I've deployed my Workflow and a Web Service wich is used by my workflow. I've tested my Web Service, and all it's OK.
When I test my Workflow with "Web service explorer", I have a timeout error.
And the Tomcat server throw the error :
[WARN] triggerActionNotSupportedFault: messageContext: [MessageContext:
logID=urn:uuid:9AEEEA7E64BAE6D4E31241008449207] problemAction:
[ERROR] The [action] cannot be processed at the receiver.
org.apache.axis2.AxisFault: The [action] cannot be processed at the
receiver.
at
org.apache.axis2.addressing.AddressingFaultsHelper.triggerAd dressingFault(AddressingFa \
ultsHelper.java:373) at
org.apache.axis2.addressing.AddressingFaultsHelper.triggerAc tionNotSupportedFault(Addr \
essingFaultsHelper.java:336) at
org.apache.axis2.handlers.addressing.AddressingInHandler.ext ractActionInformation(Addr \
essingInHandler.java:522) at
org.apache.axis2.handlers.addressing.AddressingInHandler.ext ractAddressingInformation( \
AddressingInHandler.java:239)
[ExternalService] Fault response: faultType=(unkown)
<?xml version='1.0' encoding='utf-8'?><soapenv:Envelope xmlns:soapenv="schemas.xmlsoap.org/soap/envelope/"><soapenv:Header xmlns:wsa="ww.w3.org/2005/08/addressing"><wsa:Action>ww.w3.org/2005/08/addressing/fault </wsa:Action><wsa:RelatesTo>uuid:hqejbhcnphr69l37j4dnai</wsa:RelatesTo ><wsa:FaultDetail><wsa:ProblemAction><wsa:Action>selezione/monitorMagazzino </wsa:Action></wsa:ProblemAction></wsa:FaultDetail></soapenv:Header ><soapenv:Body><soapenv:Fault xmlns:wsa=".w3.org/2005/08/addressing"><faultcode>wsa:ActionNotSupported </faultcode><faultstring>The [action] cannot be processed at the receiver.</faultstring><detail /></soapenv:Fault></soapenv:Body></soapenv:Envelope>
ERROR [INVOKE] Failure during invoke:
INFO [BpelRuntimeContextImpl] ActivityRecovery: Registering activity 11, failure reason: on channel 21
ERROR [ODEService] Timeout or execution error when waiting for response to MEX {MyRoleMex#hqejbhcnphr69l37j4dnac [Client hqejbhcnphr69l37j4dnab] calling {ht tp//gestione}BPELGestione.process(...)} java.util.concurrent.TimeoutException: Message exchange org.apache.ode.bpel.engine.MyRoleMessageExchangeImpl$Respons eFuture@6e92992c timed out(120000 ms) when waiting for a response!
Do you know this problem ? can you help me to solve that, please?
Thank you in advance!
Re: The [action] cannot be processed at the reciever [message #669811 is a reply to message #669759] Wed, 11 May 2011 11:34 Go to previous messageGo to next message
Hi Alessandra,
This question is probably best posted on one of the ODE newsgroups or forums, but...
how have you defined the web service address in your WSDL? Your service endpoint should look something like:
http://<server>:<port>/ode/processes/BPELGestione
and you should be able to see your WSDL (using a web browser) here:
http://<server>:<port>/ode/processes/BPELGestione?wsdl
HTH
Bob
Re: The [action] cannot be processed at the reciever [message #670277 is a reply to message #669811] Fri, 13 May 2011 06:55 Go to previous messageGo to next message
Yes, the endpoint of the service is something like: //<server>:<port>/ode/processes/BPELGestione, and the endpoint of the invoked service is the EPR of the deployed process(using Axis2)...
The BPEL workflow is deployed correctly (if I visit the //<server>:<port>/ode/..) I find the instances of my process..And the single service works correctly..
The problem is while I invoke the service in the workflow..It can be really a timeout error, and I have to increase Apache_ODE timeout? (mex.timeout)
Thanks Smile
Alessandra
Re: The [action] cannot be processed at the reciever [message #675901 is a reply to message #670277] Wed, 01 June 2011 17:14 Go to previous messageGo to next message
Ummm...I guess it's possible. I don't know what your service does or if timeout is an issue here...
I'm assuming you've read this: http://ode.apache.org/endpoint-configuration.html ?
Re: The [action] cannot be processed at the reciever [message #810618 is a reply to message #675901] Thu, 01 March 2012 05:27 Go to previous messageGo to next message
hi,i have the same problem of Alessandra can you help me please.
How did you solve the problem?
Re: The [action] cannot be processed at the reciever [message #810619 is a reply to message #670277] Thu, 01 March 2012 05:29 Go to previous messageGo to next message
No Message Body
[Updated on: Thu, 01 March 2012 05:30] by Moderator
Re: The [action] cannot be processed at the reciever [message #1691998 is a reply to message #669759] Sat, 11 April 2015 14:05 Go to previous message
The same error has occured with me, the problem was with the web service itself, I had an empty constructor plus the methodes wich causes a problem, the solution is to delete the constructor.
Previous Topic:BPEL Installation Problem
Next Topic:load BPEL file as an ecore model
Current Time: Mon Sep 15 14:43:30 EDT 2025
Powered by FUDForum. Page generated in 0.04375 seconds
