Home » Modeling » Graphiti » auto update policy
auto update policy [message #669687] Wed, 11 May 2011 03:05 Go to next message
today I tried to switch from the default update policy to auto update in all three cases.
I observed that only the update feature for the Diagram is called.
If I set the RECURSIVE_CHECK_FOR_UPDATE_ACTIVE to true it seems that all children are asked if they need an update. But the update
of the children isn't executed.
Am I supposed to do the recursive update calls explicitly?
Henrik
PS: I'm using Graphiti 0.8.0 (3.5.2011)
PPS: to change the preference setting I accessed it directly from the constructor of my DiagramTypeProvider
IEclipsePreferences node = new DefaultScope().getNode(GraphitiPlugin.PLUGIN_ID);
if (node!=null)
node.putBoolean(GFPreferences.RECURSIVE_CHECK_FOR_UPDATE_ACT IVE, true);
Is there a better way to do this?
Re: auto update policy [message #669815 is a reply to message #669687] Wed, 11 May 2011 10:07 Go to previous messageGo to next message
In case RECURSIVE_CHECK_FOR_UPDATE_ACTIVE is set and the method updateNeeded
of the feature returns true, the update method should be called, otherwise
that would be a bug.
Nevertheless, if you need to update any children inside the top-level
shapes, you would need to delegate explicitly.
Michael
"Henrik Rentz-Reichert" wrote in message
news:iqdc08$aie$1@news.eclipse.org...
three cases.
Henrik
if (node!=null)
Re: auto update policy [message #669979 is a reply to message #669815] Thu, 12 May 2011 05:46 Go to previous messageGo to next message
Hi Michael,
RECURSIVE_CHECK_FOR_UPDATE_ACTIVE is set.
Then in the case of auto-update updateNeeded() is called recursively (for all ContainerShapes). But update is called only once
(with the Diagram as context). Is that a bug?
I could change that to have the nested ContainerShapes be updated together with the top-level ContainerShape.
But in the case of manual update I preferred to have the updates on a finer granularity.
And could you please also answer my question in the PPS below?
Henrik
Am 11.05.2011 16:07, schrieb Michael Wenz:
> In case RECURSIVE_CHECK_FOR_UPDATE_ACTIVE is set and the method updateNeeded of the feature returns true, the update method should
> be called, otherwise that would be a bug.
> Nevertheless, if you need to update any children inside the top-level shapes, you would need to delegate explicitly.
> Michael
> "Henrik Rentz-Reichert" wrote in message news:iqdc08$aie$1@news.eclipse.org...
> Henrik
> if (node!=null)
Re: auto update policy [message #670270 is a reply to message #669979] Fri, 13 May 2011 06:26 Go to previous message
Hi Henrik,
sounds like a bug, would you please open a bugzilla? Thanks!
Sorry, I've simply looked over the PPS: no, currently there is no better
API, the intention behind this switch was so far only testing. But I
understand why you would need it, so probably we should consider to have an
API for that.
Michael
news:iqg9pk$hed$1@news.eclipse.org...
Hi Michael,
granularity.
Henrik
> Michael
> all three cases.
> Henrik
> if (node!=null)
Previous Topic:Inactive PE disappears
Next Topic:Block diagram editor
Current Time: Sat Jul 26 03:22:45 EDT 2025
Powered by FUDForum. Page generated in 0.13271 seconds
