Home » Archived » BIRT » BIRT report without WebViewer(How to get Paging on the HTML page when we show report on the page.)
BIRT report without WebViewer [message #669683] Wed, 11 May 2011 03:25 Go to next message
I am using Ruby and Birt, and here I use BIRT apis to get the rptdesign and then I show the report result as html content on the Page.
Problem is I have thousands of records in that report and there is no paging coming in and which cause a lot of delay or Timeout issue. What is the way to add paging through APIs?
I checked the apis and saw Irender has paging but not sure how I can utilize that.
This is my code,
factory = org.eclipse.birt.core.framework.Platform.createFactoryObject (IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY)
engine = factory.createReportEngine(ENGINE_CONFIG)
design = engine.openReportDesign(report_name)
designHandle = design.getDesignHandle()
designFactory = designHandle.getElementFactory()
dsrc = designFactory.newOdaDataSource("DataSource", "org.eclipse.birt.report.data.oda.jdbc")
dsrc.setProperty("odaDriverClass", BIRT_CONFIG['oda_driver_class'])
dsrc.setProperty("odaURL", BIRT_CONFIG['oda_url'])
dsrc.setProperty("odaUser", BIRT_CONFIG['oda_user'] )
dsrc.setProperty("odaPassword", BIRT_CONFIG['oda_password'])
designHandle.getDesignHandle().getModuleHandle().getDataSour ces().add(dsrc)
@task = engine.createRunAndRenderTask(design);
#Set parent class loader for engine
@task.getAppContext().put(EngineConstants::APPCONTEXT_CLASSL OADER_KEY, CURRENT_THREAD.getContextClassLoader())
Shivani
Re: BIRT report without WebViewer [message #669802 is a reply to message #669683] Wed, 11 May 2011 11:01 Go to previous messageGo to next message
If you use a run task it creates a rptdocument file. You then can
specify what pages to render in a render task.
IReportDocument document = null;
//Open the report design
document = engine.openReportDocument("output/resample/mcb.rptdocument");
IReportRunnable irr = document.getReportRunnable();
IReportRunnable irrp = document.getPreparedRunnable();
String tst = document.getVersion();
System.out.println(tst);
IRenderOption options = new RenderOption();
options.setOutputFormat("html");
long pgcnt = document.getPageCount();
System.out.println(pgcnt);
//options.setOutputStream(arg0)
options.setOutputFileName("output/resample/mcb.html");
if( options.getOutputFormat().equalsIgnoreCase("html")){
HTMLRenderOption htmlOptions = new HTMLRenderOption( options);
htmlOptions.setImageDirectory("output/image");
htmlOptions.setHtmlPagination(false);
//set this if you want your image source url to be altered
htmlOptions.setBaseImageURL("http://myhos/prependme?image=");
htmlOptions.setHtmlRtLFlag(false);
htmlOptions.setEmbeddable(false);
}else if( options.getOutputFormat().equalsIgnoreCase("pdf") ){
PDFRenderOption pdfOptions = new PDFRenderOption( options );
pdfOptions.setOption( IPDFRenderOption.FIT_TO_PAGE, new Boolean(true) );
pdfOptions.setOption( IPDFRenderOption.PAGEBREAK_PAGINATION_ONLY, new
Boolean(true) );
pdfOptions.setOption(IPDFRenderOption.PAGE_OVERFLOW,
IPDFRenderOption.FIT_TO_PAGE_SIZE);
options.setActionHandler(new MyActionHandler());
IRenderTask task = engine.createRenderTask(document);
task.setRenderOption(options);
//task.setPageRange("1-3");
task.setPageNumber(3);
//task.setReportlet("chart3");
task.render();
task.close();
Jason
On 5/11/2011 3:25 AM, forums-noreply@eclipse.org wrote:
> APIs?
> This is my code,
> ces().add(dsrc)
> Thanks
> Shivani
Re: BIRT report without WebViewer [message #676445 is a reply to message #669802] Sat, 04 June 2011 09:23 Go to previous message
hi Jason,
I tried the way you have mentioned here but it does not show the links to go to next page in HTML it is giving me a single html where i am getting complete html in one go.
And I see a display like PDF but I want to implement paging on the Html but this way it gives everything in single html. Is this the way it will work. see the attached screenshot. This screen represent two pages, which comes in single HTML.
What is the way to implement in the way shown in screenshot 2 (expectedPaging.png)
I have tried following properties
htmlOptions = HTMLRenderOption.new(options)
htmlOptions.setHtmlPagination(true)
htmlOptions.setDisplayFilterIcon(true)
htmlOptions.setEmbeddable(true)
Can you also tell me how can I embed the HTML to my page I made is true but what is the step further to render it on the page?
Thanks for the help
Shivani
Previous Topic:Empty PDF report downloaded as attachment from BIRT enabled web application
Next Topic:BIRT Exception when starting/stopping GlassFish 3
Current Time: Sat Jul 26 21:13:34 EDT 2025
Powered by FUDForum. Page generated in 0.05766 seconds
