How to convert a jpql filter condition to Expression [message #669663] |
Wed, 11 May 2011 01:25  |
I have the following scenario, i'm describing it in pseudo code as the concept is what i'm interested in.
There is an entity:
@Entity
MyEntity {
Somewhere in the application i create a string:
String my_jpql_condition = " name like :pName ";
then in the core of the application i'd like to do :
ReadAllQuery query = new ReadAllQuery(MyEntity.class);
Expression where = .....
some_way_to_add_my_jpql_condition(where , my_jpql_condition )
query.setSelectionCriteria(where);
I believe there is somewhere in the JPA implementation a way to achieve this either:
translate my_jpql_condition into an expression or translate it into an sql where then append that to my query.
Any hint if this is possible and where to look for ?
Thank you
Re: How to convert a jpql filter condition to Expression [message #670298 is a reply to message #670045] |
Fri, 13 May 2011 08:51  |
Thank you James,
I was kind of afraid of this answer ...
I have a view-model declaration as shown below where the annotations create some descriptors at start-up
used by a service runtime engine (create fetch groups, filter, sort, query, save, etc).
For decent situations a base service does all the job, for complex ones specific services are mapped.
As some situations are too complex for jpql i prefered to use directly the native api in the engine.
What i'd like is to declare here in a way or other (in annotation or some statics or whatever )
the default where per view-model and some filter rules per field.
In order to increase flexibility i thought some jpql fragments would be the most interesting option
(i wouldn't create a custom service just because of an average filter rule )
I wouldn't mind to use expressions but i don't see how in this context.
@DsModel(entity = Employee.class,
sort = { @SortField(field=EmployeeDs.fLASTNAME) }
public class EmployeeDs extends AbstractDsModel<Employee> implements
IModelWithId, IModelWithClientId {
public static final String fID = "id";
public static final String fFIRSTNAME = "firstName";
public static final String fLASTNAME = "lastName";
public static final String fEMPLOYERID = "employerId";
public static final String fEMPLOYERCODE = "employerCode";
@DsField
private Long id;
@DsField(path = "employer.id", join = "left")
private Long employerId;
@DsField(path = "employer.code", join = "left")
private String employerCode;
@DsField
private String firstName;
@DsField
private String lastName;
Thank you
[Updated on: Fri, 13 May 2011 09:22] by Moderator
FUDForum. Page generated in 0.04314 seconds
