Home » Modeling » GMF (Graphical Modeling Framework) » Loading Resources through Browse Registered Packages
Loading Resources through Browse Registered Packages [message #669505] Tue, 10 May 2011 03:02 Go to next message
In an EMF-generated editor, it is already possible to load an existing
resource through Load Resource > Browse Registered Packages. In my
generated GMF editors, I can also load an existing resource, but there
is no option to Browse Registered Packages -- only the filesystem and
workspace.
Is this a problem with my configuration, or expected behaviour? How can
I modify my editors to provide this option? I'd like to be able to
reference platform:/plugin/* resources in my model instances. If I
provide the platform:/plugin/* URI manually, the resource is
successfully loaded into the underlying model instance.
Any ideas would be appreciated!
Jevon
Re: Loading Resources through Browse Registered Packages [message #669531 is a reply to message #669505] Tue, 10 May 2011 11:31 Go to previous messageGo to next message
Jevon,
Comments below.
Jevon Wright wrote:
Well, that's not true of all generated EMF editors. It's specifically
added for the Ecore editor itself.
> In my generated GMF editors, I can also load an existing resource, but
> there is no option to Browse Registered Packages -- only the
> filesystem and workspace.
> can I modify my editors to provide this option? I'd like to be able to
Are these really references to Ecore models, i.e., references to
EPackage or EClass, or do you have instances of your specific type of model?
> If I provide the platform:/plugin/* URI manually, the resource is
There isn't a general way to browse all resources you might have bundled
up in your jars. In the case of Ecore, we're using an extension point
to register the packages and we can use the associated registry to find
them all. I doubt you have such a thing, yet...
> Thanks
> Jevon
Re: Loading Resources through Browse Registered Packages [message #669621 is a reply to message #669531] Tue, 10 May 2011 20:08 Go to previous message
Hi Ed,
Thanks for your reply. That makes a lot of sense!
However yes, in this case I am trying to refer to Ecore models, in
particular the XSD.ecore model as provided by org.eclipse.xsd.
After a bit of hunting I found the Ecore editor implementation of
LoadResourceAction --
org.eclipse.emf.ecore.presentation.EcoreActionBarContributor .ExtendedLoadResourceAction
-- and with a bit of modification to the diagram editor, this action
worked perfectly:
public class LoadResourceAction extends AbstractHandler {
public Object execute(ExecutionEvent event) throws ExecutionException {
ExtendedLoadResourceAction act = new ExtendedLoadResourceAction();
IEditorPart diagramEditor =
HandlerUtil.getActiveEditorChecked(event);
TransactionalEditingDomain editingDomain = ((DiagramEditor)
diagramEditor)
.getEditingDomain();
act.setEditingDomain(editingDomain);
act.run();
return null;
It's necessary to call setEditingDomain() directly, as
ExtendedLoadResourceAction only provides a single default constructor.
Thanks for your help!
Jevon
Ed Merks wrote:
> Jevon,
> Comments below.
> Jevon Wright wrote:
>> Hi,
> model?
>> Thanks
>> Jevon
Previous Topic:The "+" popup: how to remove it?
Next Topic:strange inheritance error
Current Time: Sun Jul 27 09:01:01 EDT 2025
Powered by FUDForum. Page generated in 0.05648 seconds
