Home » Eclipse Projects » EGit / JGit » Newbie: EGit hangs eclipse IDE(The whole eclipse IDE hangs when I try to create a new Git repository)
Newbie: EGit hangs eclipse IDE [message #661671] Fri, 25 March 2011 19:25 Go to next message
I am trying to start using EGit.
I have Windows 7 32 bits with Java SDK 1.6.0_24.
I have freshly installed eclipse-java-helios-SR2-win32, and I have installed EGit from the http://download.eclipse.org/egit/updates-nightly site. I have installed:
Eclipse EGit 0.12.0.201103251413
EGit Mylyn 0.12.0.201103251413
Eclipse JGit 0.12.0.201103251413
I then try to follow the tutorial to Create a Repository for the HelloWorld project, but when I click on the "Create Repository" button the whole IDE hangs(displays Not Responding in the windows title bars) until I manually kill it.
I tried also with EGit version 0.11.3, same result.
Actually, the eclipse IDE hangs also if I try to open the Preferences | Team | Git | Configuration page, or if I try to clone a remote EGit repository (git://git.eclipse.org/gitroot/ecf/org.eclipse.ecf.git).
Has anybody encountered a similar problem? Am I doing anything wrong in the way I install EGit???
Thanks in advance for any suggestion.
UPDATE:
I found the cause of the problem: I have cygwin\bin in the path, but I only installed the eclipse version of Git, and this situation breaks org.eclipse.jgit.util.FS_Win32.discoverGitPrefix() quite badly. The funny thing is that the developer suspected this to happen, as indicated by the comment he/she wrote:
// This isn't likely to work, if bash is in $PATH, git should
// also be in $PATH. But its worth trying.
[Updated on: Fri, 25 March 2011 22:42] by Moderator
Re: Newbie: EGit hangs eclipse IDE [message #661776 is a reply to message #661671] Sun, 27 March 2011 14:28 Go to previous messageGo to next message
Wuoh great. I'm looking for about 3h after a solution for this problem. After removing the cygwin paths from PATH everything works. But how can I use Cygwin parallel?
Re: Newbie: EGit hangs eclipse IDE [message #661813 is a reply to message #661776] Mon, 28 March 2011 01:47 Go to previous messageGo to next message
Cygwin.bat sets PATH for you. That is how most people use it, I guess.
I have tested this code with cygwin in PATH and don't see the problem,
however a patch has been posted that allows you to set the git prefix
manually, thus avoiding the process that hangs.
http://egit.eclipse.org/r/#change,2939
-- robin
Re: Newbie: EGit hangs eclipse IDE [message #661863 is a reply to message #661813] Mon, 28 March 2011 06:47 Go to previous messageGo to next message
Hi Robin
Thanks for answering, but I can't follow you. How can I avoid the crash? By starting Eclipse with "-Djgit.gitprefix=PATH"?! Path to where?
When will this patch being released?
Btw. it's "c:\cygwin\bin\" in %PATH% that makes eGit crash.
simon
[Updated on: Mon, 28 March 2011 06:48] by Moderator
Re: Newbie: EGit hangs eclipse IDE [message #662012 is a reply to message #661863] Mon, 28 March 2011 17:05 Go to previous messageGo to next message
On 2011-03-28 12.47, Simon Staeheli wrote:
> Hi Robin
The path to where the directory obove the one that contains git.exe (if
any). If C Git is not installed you can point it to basically any
directory. JGit is looking for ${jgit.prefix}/etc/gitconfig, which may
or may not be present. Unix users rarely use it, but Git for Windows
puts some values there at installation time, which is the reason we
want to know where the system-wide configuration file is.
I guess it will be merged soon. Look at Gerrit. When it's been merged
the next nightly build will contain the fix.
> simon
Can you try this command from a cmd window:
bash --login -c "which git"
That might help us figuring why EGit hangs for you.
-- robin
Re: Newbie: EGit hangs eclipse IDE [message #662054 is a reply to message #662012] Tue, 29 March 2011 02:43 Go to previous messageGo to next message
ah cool thx. that makes it more clear..
C:\Users\xyz>bash --login -c "which git" which: no git in (/usr/local/bin:/usr/bin:/bin:/cygdrive/c/Windows/system32:/ cyg drive/c/Windows:/cygdrive/c/Windows/System32/Wbem:/cygdrive/ c/Windows/System32/W indowsPowerShell/v1.0/:/cygdrive/c/Program Files/Intel/WiFi/bin/:/cygdrive/c/Pro gram Files/Common Files/Intel/WirelessCommon/:/cygdrive/c/Program Files/ATI Tech nologies/ATI.ACE/Core-Static:/usr/local/bin/:/usr/bin:/cygdr ive/c/Program Files/ QuickTime/QTSystem/:/cygdrive/c/Program Files/OpenVPN/bin)
Re: Newbie: EGit hangs eclipse IDE [message #662194 is a reply to message #662012] Tue, 29 March 2011 12:07 Go to previous messageGo to next message
On Mon, 28 Mar 2011 23:05:37 +0200, Robin Rosenberg
>> Hi Robin
Sorry - I'm new to egit too and have exactly the same problem. I've
got round it for the moment by removing cygwin from the path when I
launch Eclipse (I uses a modified version of start.bat from the Qt
Eclipse Integration package to do that).
I guess I was wondering when the next 'proper' release in the P2
repository will be; I'm not a huge fan of using nightly builds :-)
Re: Newbie: EGit hangs eclipse IDE [message #662256 is a reply to message #662194] Tue, 29 March 2011 17:49 Go to previous messageGo to next message
>>> Hi Robin
For cutting edge features you may have to. The EGit plugin is still
in incubation mode, which means it lacks features and has bugs. In
order to ship working releases someone needs to test stuff, or
bugs *will* ship. If you don't test it, who will?
So I think you should verify a nightly build and say "yes works" and
then perhaps go back to using a release. Usually the latest release
has more bugs than the nightly build, but on rare occasions they don't
work at all.
I do not think you should use all nigtly builds for your Eclipse,
because then some plugin will most certainly be broken. Pick the
ones you care about, do regular updates and report bugs. Have a
spare Eclipse with the latest working release so you can continue
working until the nigly works again. You can use the same workspace for
both Eclipse instances (but not simulatenously).
-- robin
Re: Newbie: EGit hangs eclipse IDE [message #662329 is a reply to message #662256] Wed, 30 March 2011 05:23 Go to previous messageGo to next message
On Tue, 29 Mar 2011 23:49:41 +0200, Robin Rosenberg
Fair point :-)
>work at all.
Thanks for that. I'll think about doing that; it's the sort of thing
I've done in the past but not for a while. In the meantime I'll see
how things go with my current workaround - I seldom use cygwin while
using Eclipse as our main development build system is external to
Eclipse so I might be able to manage that way for a while.
Re: Newbie: EGit hangs eclipse IDE [message #663073 is a reply to message #662012] Sun, 03 April 2011 04:49 Go to previous messageGo to next message
Robin Rosenberg wrote on Mon, 28 March 2011 17:05
Probably a stupid question, but "Change has been successfully merged into the git repository." means that the patch is available in a nigthly build?
[Updated on: Sun, 03 April 2011 04:50] by Moderator
Re: Newbie: EGit hangs eclipse IDE [message #663081 is a reply to message #661671] Sun, 03 April 2011 07:05 Go to previous messageGo to next message
Yes.
Re: Newbie: EGit hangs eclipse IDE [message #668167 is a reply to message #661671] Wed, 04 May 2011 05:47 Go to previous messageGo to next message
I've installed the nightly build now (v 0.12.1) and I've still the same problem. As soon as I put 'c:\cygwin\bin\' in my PATH Eclipse crashes during the start because of my git projects. If I choose another workspace without git projects it works without any problems..
[Updated on: Wed, 04 May 2011 05:48] by Moderator
Re: Newbie: EGit hangs eclipse IDE [message #669471 is a reply to message #668167] Tue, 10 May 2011 09:11 Go to previous messageGo to next message
any ideas?
Re: Newbie: EGit hangs eclipse IDE [message #673226 is a reply to message #668167] Sun, 22 May 2011 19:17 Go to previous messageGo to next message
0.12.1 is not a nightly build but the latest EGit release. Install the nightly from [1].
[1] http://download.eclipse.org/egit/updates-nightly
Re: Newbie: EGit hangs eclipse IDE [message #674548 is a reply to message #662256] Fri, 27 May 2011 06:24 Go to previous messageGo to next message
Hi Robin
Just following up on this as it's been a little while. Are you able to
confirm that this fix went in to the 0.12.1 release of EGit?
If it did, does the fix allow us to have c:\cygwin\bin in our windows
PATH _without_ adding the -Djgit.jgitprefix=<path> or is it essential
that we add that if we have cygwin in the PATH.
John
>>>> Hi Robin
>work at all.
>-- robin
Re: Newbie: EGit hangs eclipse IDE [message #674699 is a reply to message #674548] Fri, 27 May 2011 18:50 Go to previous messageGo to next message
> Hi Robin
> Thanks
> John
That path is merged, as can be seen in Gerrit. I cannot reproduce the
issue, but it you can place add -Djgit.fs.debug=1 to the eclipse.ini and
start Eclipe from the command line or by runniung eclipsec to see a
stdin/stdout window. That debug option is there exclusively in order
to resolve this issue. As soon as Eclipse hangs copy the text from the
console window and update the relevant bug report.
Other than that the workaround is the one you mention until the issue
can be diagnosed, or a better way to determine the cause has been found.
-- robin
Re: Newbie: EGit hangs eclipse IDE [message #675402 is a reply to message #674699] Tue, 31 May 2011 07:50 Go to previous messageGo to next message
On Sat, 28 May 2011 00:50:28 +0200, Robin Rosenberg
>> Hi Robin
>> Thanks
>> John
Thanks for that. I'll try it out. The main reason I asked rather than
tried it was that it's rare I use EGit, especially in the way that
causes this issue so...
Thanks again.
John
Re: Newbie: EGit hangs eclipse IDE [message #895125 is a reply to message #661671] Wed, 11 July 2012 14:22 Go to previous message
It's a quick fix and please follow the following steps:
1. Eclipse Help Menu
2. Eclipse Marketplace
3. Find "Egit - Git Team Provider"
4. Install it
Now you are done Smile
Enjoy
Previous Topic:How can i get the list of commited Files
Next Topic:Getting the changed text / old version of a file
Current Time: Sun Jul 27 08:59:44 EDT 2025
Powered by FUDForum. Page generated in 0.06971 seconds
