Create automatically an edge between two nodes [message #668607] |
Fri, 06 May 2011 08:10  |
Hi there,
I want to create automatically an edge between the two nodes thanks to an action in a popup menu. I manage to get references of my two nodes and give its as parameters to my LinkCreateCommand. LinkCreateCommand::canExecute() return true, but when I try to execute the command, I got this error concerning the line "cmd.execute()" :
Quote: | !MESSAGE Unhandled event loop exception
!STACK 0
at org.eclipse.emf.workspace.AbstractEMFOperation.inheritedOpti ons(AbstractEMFOperation.java:252)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:138)
at am.diagram.part.EncloseObjectAction.run(LinkAction.java:138)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
Does anyone have an idea to fix it ?
My code :
public class LinkAction implements IObjectActionDelegate {
private ISelection selectedElement = null;
public void selectionChanged(IAction action, ISelection selection) {
action.setEnabled(false);
if (selection instanceof IStructuredSelection == false || selection.isEmpty()) {
return;
selectedElement = selection;
action.setEnabled(true);
public void run(IAction action) {
EObject source = null;
ArrayList<EObject> targets = new ArrayList<EObject>();
if (selectedElement != null) {
for (Iterator<Object> i = ((IStructuredSelection) selectedElement).iterator (); i.hasNext ();) {
Object k = i.next ();
if (k instanceof aaaEditPart)
source = ((aaaEditPart)k).resolveSemanticElement();
else if (k instanceof bbbEditPart)
targets.add (((bbbEditPart)k).resolveSemanticElement ());
if (source != null && targets.size() > 0) {
CreateRelationshipRequest request = new CreateRelationshipRequest(xxxElementTypes.Link_4001);
LinkCreateCommand cmd = new LinkCreateCommand(request , (EObject)source, (EObject)targets.get(0));
if (cmd.canExecute()) {
try {
cmd.execute(new NullProgressMonitor(), null);
} catch (ExecutionException e) {
e.printStackTrace();
Nicolas
Re: Create automatically an edge between two nodes [message #669381 is a reply to message #668607] |
Tue, 10 May 2011 03:10  |
I solved my issue by adding the two following lines :
request.setSource(source);
request.setTarget(targets.get(0));
It works but I've to refresh manually the editor to see the modification.
How can I refresh automatically my model and my editor please ?
Nicolas
FUDForum. Page generated in 0.09474 seconds
