Home » Archived » EGL Development Tools » is there an easy way to rebuild the source from EDT model
is there an easy way to rebuild the source from EDT model [message #669309] Mon, 09 May 2011 16:50 Go to next message
I would like to build back the original source code statement from the EDT model. I have looked at the reverse generation sample and on the surface it looks a bit complex for my needs.
Is there a simple way to turn
myInt int=0;
into EDT objects
and back into a string that looks like
myInt int=0;
without going through the process of implementing all the generators. I am currently getting lost in getting all LHS and RHS pieces that are involved in understanding fields and declarations.
Re: is there an easy way to rebuild the source from EDT model [message #669561 is a reply to message #669309] Tue, 10 May 2011 14:17 Go to previous messageGo to next message
Unfortunatly, I think the answer to your question is NO. You would need to set up visitors for the various elements that you are interested in, and you will need to understand how these pieces go together. A good way to understand what types of elements are involved is to look at the .eglxml file produced from your source. This will should give you a feel for what the classes are that make up the part. Start small with a library with a single field declaration and build from there.
Re: is there an easy way to rebuild the source from EDT model [message #670384 is a reply to message #669561] Fri, 13 May 2011 14:41 Go to previous message
Thanks Paul,
I'm wondering, does a requirement to be able to ask an EMF object for its "source block" or something along those lines make any sense to others?
Aaron
Previous Topic:problem compiling handlers and widgets
Next Topic:WHY "The type SQLRecord cannot be resolved" ?
Current Time: Sun Jul 27 07:39:44 EDT 2025
Powered by FUDForum. Page generated in 0.02965 seconds
