Home » Eclipse Projects » Eclipse Platform » How to override Eclipse "File > Save" Action(Need help in overriding default Eclipse Save Action/Command)
How to override Eclipse "File > Save" Action [message #668445] Thu, 05 May 2011 12:55 Go to next message
I am trying to override the Eclipse File > Save menu action to add some functionality. I have tried the following things
a) Create a new action and add it to the global action handler
actionBars.setGlobalActionHandler(ActionFactory.SAVE.getId(), mySaveAction);
actionRegistry.registerAction(action);
b) Create a new handler and override the save command
<extension point="org.eclipse.ui.handlers">
<handler commandId="org.eclipse.ui.file.save"
  class="com.diagrams.ui.SaveFileHandler">
<enabledWhen>
  <with variable="activePartId">
  <equals
    value="com.diagrams.editors.MultiPageEditor" />
  </with>
</enabledWhen>
<activeWhen>
  <equals
  </with>
</activeWhen>
</handler>
</extension>
With both these approaches I have been able to override the Keyboard Ctrl+S functionality but the "File > Save" menu seem to work differently.
Would really appreciate any help, Thanks
[Updated on: Thu, 05 May 2011 12:55] by Moderator
Re: How to override Eclipse "File > Save" Action [message #668468 is a reply to message #668445] Thu, 05 May 2011 15:13 Go to previous messageGo to next message
File>Save is defined and added to the menu in the RCP apps
ActionBarAdvisor. In the Eclipse IDE, that's the IDE's
WorkbenchActionBuilder adding it as a Action (as opposed to command),
which you can't change.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: How to override Eclipse "File > Save" Action [message #668477 is a reply to message #668468] Thu, 05 May 2011 15:49 Go to previous messageGo to next message
Thanks for the quick reply Paul.
So, is there a workaround for adding some functionality to the eclipse WorkbenchActionBuilder actions for a specific type of activePartId?
Re: How to override Eclipse "File > Save" Action [message #668600 is a reply to message #668477] Fri, 06 May 2011 07:06 Go to previous messageGo to next message
In your own RCP app, you control the main menu/toolbar using your
ActionBarAdvisor. In the eclipse IDE, you can add whatever you'd like
to the main menu/toolbar using org.eclipse.ui.menus, commands, and
handlers. You just cannot change something that's added directly to the
main menu (as Save is done by the WorkbenchActionBuilder).
PW
Paul Webster
Re: How to override Eclipse "File > Save" Action [message #668601 is a reply to message #668477] Fri, 06 May 2011 07:07 Go to previous messageGo to next message
The best you can do is add an execution listener to the
ICommandService, and listen for the save command. The IDs are listed in
org.eclipse.ui.IWorkbenchCommandConstants
PW
Paul Webster
Re: How to override Eclipse "File > Save" Action [message #668649 is a reply to message #668601] Fri, 06 May 2011 10:58 Go to previous messageGo to next message
Thanks for your help Paul. I'll look into adding the execution Listener.
Re: How to override Eclipse "File > Save" Action [message #873442 is a reply to message #668601] Fri, 18 May 2012 04:51 Go to previous message
Hi , I'am trying to do the same thing.
I have tried the solution that Paul proposed and I have added an execution listener to the save command but unfortunately it was working just for the keyboard combination Ctrl+S. For the save from menus it doesn't work.
Maybe you can help me with other solution? or maybe it's a reason why it's not working for me . The code is listed bellow :
String commandId = "org.eclipse.ui.file.save";
ICommandService service = (ICommandService) PlatformUI.getWorkbench().getService(ICommandService.class);
Command command = service.getCommand(commandId);
command.addExecutionListener(new IExecutionListener() {
public void notHandled(String arg0, NotHandledException arg1) {
public void postExecuteFailure(String arg0, ExecutionException arg1){
public void postExecuteSuccess(String arg0, Object arg1) {
public void preExecute(String arg0, ExecutionEvent arg1) {
Previous Topic:How to use the RefreshProvider?
Next Topic:Why does getElement() always return null in PropertyPage?
Current Time: Mon Oct 27 14:05:24 EDT 2025
Powered by FUDForum. Page generated in 0.08530 seconds
