column expand will unknown reason [message #668595] |
Fri, 06 May 2011 07:28  |
i have two table, each column in the table is set to 0.25 inch, but in run time, one table show as normal but in another table, each column is expanded and so much wider than the first table, what is the reason?
Re: column expand will unknown reason [message #668666 is a reply to message #668599] |
Fri, 06 May 2011 11:58  |
Can you reproduce the issue with the sample db? Try select * from
prodcutlines and use the text column to try and reproduce. If you can
do this post the sample here.
Jason
On 5/6/2011 7:36 AM, tong123123@yahoo.com.hk wrote:
> above is the attached xml file, the column in table "average memory
> utilization per hour" is expanded with unknown reason, in fact, without
> expand, the column width is also enough to show the content.
FUDForum. Page generated in 0.09317 seconds
