Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Possible to clone browser control?
Possible to clone browser control? [message #668267] Wed, 04 May 2011 14:14 Go to next message
Context: We are using the SWT Browser control to programatically navigate web sites. When a given page has a list of links, we click one, listen for the BeforeNavigate event, abort the current navigation, create a new Browser control, and then navigate by setting the URL in the new Browser control. This leaves the page with the original list of links intact so we can click the next link and repeat the process.
This works fine for many sites, but doesn't work well in certain cases (e.g. when link doesn't generate HTTP request because it is internal javascript).
Question: Is it possible to somehow clone an existing Browser control instead of creating a new one? The cloned Browser would need to contain not only the existing page content, but also any registered DOM event handlers (e.g. javascript) and possibly any other dynamic state created by the browser.
Gary
Re: Possible to clone browser control? [message #668382 is a reply to message #668267] Thu, 05 May 2011 09:29 Go to previous messageGo to next message
Hi Gary,
I can't think of a way that this would be done. With Browser.evaluate()
it's possible to execute some javascript that can query for specific aspects
of the current page's state, but there isn't a generic way to just create a
clone of the whole thing.
Grant
"Gary" <ghirschhorn@fetch.com> wrote in message
news:ips4i3$b80$1@news.eclipse.org...
> javascript).
> the browser.
> Gary
Re: Possible to clone browser control? [message #668436 is a reply to message #668382] Thu, 05 May 2011 12:32 Go to previous messageGo to next message
Thanks for the reply.
I was hoping that I could mimic the functionality of the "Duplicate Tab" action in IE. This seems to do what I want, but I am not sure how it is done.
I notice in the SWT source code (IE.java) that the underlying Windows Browser object being manipulated by code like the following:
	int[] rgdispid = auto.getIDsOfNames(new String[] { "LocationURL" }); //$NON-NLS-1$
	int[] rgdispid = auto.getIDsOfNames(new String[] { "GoForward" }); //$NON-NLS-1$
Do you have a reference to the Windows documentation where the API ("LocationURL", "GoForward") is defined? Is it the WebBrowser Object at http://msdn.microsoft.com/en-us/library/aa752085%28v=VS.85%2 9.aspx?
Perhaps there is some clue as to our Duplicate Tab works in the browser control?
Thanks again,
Gary
Re: Possible to clone browser control? [message #668640 is a reply to message #668436] Fri, 06 May 2011 10:05 Go to previous message
Yes, the link to MSDN you have is the correct one.
The WebBrowser control may or may not expose the functionality for doing
this (a quick glance doesn't find an obvious way). However for something
like this to become Browser API it would also need to be supported by the
Mozilla and WebKit implementations. If you only care about embedded IE and
are able to find a way to do this then you could hack your swt to expose its
"auto", and then go from there via COM invocations. It would be interesting
to see the solution if one is found.
Grant
news:ipuj0e$e6$1@news.eclipse.org...
> done.
> //$NON-NLS-1$
> //$NON-NLS-1$
> control?
> Thanks again,
> Gary
Previous Topic:DND images and offset not working?
Next Topic:Converting points using 'toControl' and 'toDisplay' gives wrong location on ubuntu10.10
Current Time: Sat Jul 26 11:46:42 EDT 2025
Powered by FUDForum. Page generated in 0.23641 seconds
