Home » Eclipse Projects » Eclipse Platform » Small CommandContributionItem improvement
Small CommandContributionItem improvement [message #668336] Thu, 05 May 2011 05:22 Go to next message
This class has supports for creating buttons, but doesn't use the command image.
Here is what I propose:
public void fill(Composite parent) {
if (command == null) {
return;
if (widget != null || parent == null) {
return;
// Buttons don't support the pulldown style
int tmpStyle = style;
if (tmpStyle == STYLE_PULLDOWN)
tmpStyle = STYLE_PUSH;
Button item = new Button(parent, tmpStyle);
item.setData(this);
if (workbenchHelpSystem != null) {
workbenchHelpSystem.setHelp(item, helpContextId);
item.addListener(SWT.Dispose, getItemListener());
item.addListener(SWT.Selection, getItemListener());
//////////////////////// BEGIN CHANGES
if (icon != null) {
icon.setImage(icon.createImage());
//////////////////////// END CHANGES
widget = item;
update(null);
updateIcons();
bindingService.addBindingManagerListener(bindingManagerListe ner);
I hope you like this improvement.
David
Re: Small CommandContributionItem improvement [message #668359 is a reply to message #668336] Thu, 05 May 2011 07:52 Go to previous messageGo to next message
> command image.
> if (icon != null) {
What are you trying to do here? images for the contributions are set on
the item in the updateIcons() method.
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
Re: Small CommandContributionItem improvement [message #668380 is a reply to message #668359] Thu, 05 May 2011 09:51 Go to previous messageGo to next message
You're right Prakash!
But in 3.6, updateIcons() only handles MenuItem and ToolItem's.
So my proposal is now:
protected  void updateIcons() {
if (widget instanceof MenuItem) {
} else if (widget instanceof ToolItem) {
                //////BEGIN CHANGES
                else if (widget instanceo f Button) {
                        Button butt on = (Button)widget;
LocalResourceManager m = new LocalResourceManager(JFaceR esources
.getResources());
try {
button.setImage(icon == null ? null : m.createImage(ic on));
} catch (DeviceResourceException e) {
icon = ImageDescriptor.getMissingImageDescriptor();
item.setImage(m.createImage(icon));
// as we replaced the failed icon, log the message
Re: Small CommandContributionItem improvement [message #668383 is a reply to message #668380] Thu, 05 May 2011 09:54 Go to previous message
I don't know why, but my previous code was clipped:
       //////BEGIN CHANGES
        else if (widget instanceof Button) {
              Button button = (Button)widge t;
LocalResourceManager m = new LocalResourceManager(JFaceR esources.getResources());
try {
StatusManager.getManager().handle(
new Status(IStatus.ERROR, WorkbenchPlugin.PI_WORKBENCH, "Failed to load image", e)); //$NON-NLS-1$
disposeOldImages();
localResourceManager = m;
       //////END CHANGES
Previous Topic:Rename Java Package programmatically
Next Topic:Refresh Workspace
Current Time: Tue Jul 22 23:59:51 EDT 2025
Powered by FUDForum. Page generated in 0.05256 seconds
