Home » Archived » Buckminster » Deliver no source files in p2 site
Deliver no source files in p2 site [message #668199] Wed, 04 May 2011 09:26 Go to next message
Hello all,
i have a problem: When i am building an p2 update site via hudson + buckminster the corresponding source feautres/bundles are also included. But i want a p2 update site WITHOUT sources.
Manually via Buckminster + Eclipse using a buckminster.properties file and set the cbi.include.source property to false all is working as expected.
Unfortunately not when i am building via Hudson. Maybe Hudson cannot link to the buckminster.properties file? Or maybe i have to add manually a command to buckminster in Hudson?
Thank you!
Lukas L.
Re: Deliver no source files in p2 site [message #668246 is a reply to message #668199] Wed, 04 May 2011 12:00 Go to previous messageGo to next message
Hi Lukas,
I assume you are using the Hudson Plugin for Buckminster?
The setting for that is in the 'Advanced Options' of the configuration.
You can either use the JVM arguments with -Dcbi.include.source=false or
you can specify the path to a properties file ('Global Properties File',
also in the advanced section) that will be passed to all commands you
are executing in the build step.
Johannes
Re: Deliver no source files in p2 site [message #668320 is a reply to message #668199] Thu, 05 May 2011 04:00 Go to previous messageGo to next message
Hi Johannes,
Thank you for your answer.
Yes, I am using the Hudson Plugin (version 3.6) for Buckminster.
I tried both using the JVM arguments with -Dcbi.include.source=false and
linking the properties file. However, the sources are always included.
This is my Buckminster Commmand:
import '${WORKSPACE}/org.plugin.my.buckminster/site.cquery'
build
perform -D target.os=* -D target.ws=* -D target.arch=* org.plugin.my.buckminster#site.p2.zip
And this is the value in JVM Arguments:
Lukas
Re: Deliver no source files in p2 site [message #668354 is a reply to message #668320] Thu, 05 May 2011 07:05 Go to previous messageGo to next message
Hi Lukas,
can you post the generated command line invocation of the job's console
output? Just to see if the command line correctly contains the property
(or property file) to determine if it's a bug in the plugin or buckminster.
Johannes
Am 05.05.2011 10:00, schrieb Lukas L.:
> Hi Johannes,
> build
> Best regards,
> Lukas
Re: Deliver no source files in p2 site [message #668360 is a reply to message #668199] Thu, 05 May 2011 08:06 Go to previous messageGo to next message
Job console:
[workspace] $ "C:\Program Files\Java\jdk1.6.0_24\bin\java.exe" "-Dbuckminster.output.root=C:\Program Files\Jenkins\jobs\p2 Updatesite\workspace\buckminster.output" "-Dbuckminster.temp.root=C:\Program Files\Jenkins\jobs\p2 Updatesite\workspace\buckminster.temp" -Dcbi.include.source=false -jar "C:\Program Files\Jenkins\tools\buckminster\plugins\org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_1400.jar" -application org.eclipse.buckminster.cmdline.headless -data "C:\Program Files\Jenkins\jobs\p2 Updatesite\workspace" --loglevel info -S "C:\Program Files\Jenkins\jobs\p2 Updatesite\workspace\commands.txt"
INFO: setpref 'targetPlatformPath=/C:/Program Files/Jenkins/jobs/Create Target Platform/builds/2011-05-04_11-02-38/archive//targetPlatform'
INFO: import '/C:/Program Files/Jenkins/jobs/p2 Updatesite/workspace/org.plugin.my.buckminster/site.cquery'
INFO: Import complete. INFO: build
As you can see -Dcbi.include.source=false is included.
Re: Deliver no source files in p2 site [message #668378 is a reply to message #668360] Thu, 05 May 2011 09:17 Go to previous messageGo to next message
All your other -D settings have " " around them... could that be it?
- henrik
On 5/5/11 2:06 PM, Lukas L. wrote:
> Job console:
> "C:\Program
> Files\Jenkins\tools\buckminster\plugins\org.eclipse.equinox. launcher_1.1.1.R36x_v20101122_1400.jar "
> INFO: Import complete. INFO: build ...
Re: Deliver no source files in p2 site [message #668379 is a reply to message #668378] Thu, 05 May 2011 09:29 Go to previous messageGo to next message
Am 05.05.2011 15:17, schrieb Henrik Lindberg:
Hmm, no, that should work since there is no spaces or anything in that
property.
To me it looks like a buckminster bug unless the cbi.include.source is
not valid as a system property and HAS to be in a properties file (but
you said that didn't work either?)
Re: Deliver no source files in p2 site [message #668394 is a reply to message #668199] Thu, 05 May 2011 10:29 Go to previous messageGo to next message
Here the console log with setting the "Global Properties File" property to:
${WORKSPACE}/org.plugin.my.buckminster/buckminster.propertie s
Here the code of my buckminster.properties file:
# Deliver no source files
cbi.include.source = false
target.os=*
target.ws=*
target.arch=*
Same result/problem when referencing the buckminster.properties file:
[workspace] $ "C:\Program Files\Java\jdk1.6.0_24\bin\java.exe" "-Dbuckminster.output.root=C:\Program Files\Jenkins\jobs\p2 Updatesite\workspace\buckminster.output" "-Dbuckminster.temp.root=C:\Program Files\Jenkins\jobs\p2 Updatesite\workspace\buckminster.temp" -jar "C:\Program Files\Jenkins\tools\buckminster\plugins\org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_1400.jar" -application org.eclipse.buckminster.cmdline.headless -data "C:\Program Files\Jenkins\jobs\p2 Updatesite\workspace" --loglevel info -P "/C:/Program Files/Jenkins/jobs/p2 Updatesite/workspace/org.plugin.my.buckminster/buckminster.properties" -S "C:\Program Files\Jenkins\jobs\p2 Updatesite\workspace\commands.txt" INFO: setpref 'targetPlatformPath=/C:/Program Files/Jenkins/jobs/Create Target Platform/builds/2011-05-04_11-02-38/archive//targetPlatform' INFO: import '/C:/Program Files/Jenkins/jobs/p2 Updatesite/workspace/org.plugin.my.buckminster/site.cquery'
Re: Deliver no source files in p2 site [message #668397 is a reply to message #668394] Thu, 05 May 2011 10:44 Go to previous messageGo to next message
Do you have any advisor nodes that may override things?
- henrik
> target.os=*
> target.ws=*
> target.arch=*
> Updatesite/workspace/org.plugin.my.buckminster/buckminster.p roperties "
Re: Deliver no source files in p2 site [message #668576 is a reply to message #668199] Fri, 06 May 2011 06:03 Go to previous messageGo to next message
Hi Henrik,
I have no advisor nodes in my site.cquery.
Strange behaviour ...
- lukas
Re: Deliver no source files in p2 site [message #668728 is a reply to message #668379] Fri, 06 May 2011 16:53 Go to previous messageGo to next message
Please try quoting. This is apparently on Windows and some windows cmd shells will actually split on '='.
- thomas
> Hmm, no, that should work since there is no spaces or anything in that property.
> To me it looks like a buckminster bug unless the cbi.include.source is not valid as a system property and HAS to be in a
> properties file (but you said that didn't work either?)
Re: Deliver no source files in p2 site [message #669946 is a reply to message #668199] Thu, 12 May 2011 03:27 Go to previous messageGo to next message
Sorry for the late reply.
I tried quoting, however without success ...
Global Properties File --> " ${WORKSPACE}/org.plugin.my.buckminster/buckminster.propertie s "
Re: Deliver no source files in p2 site [message #669996 is a reply to message #669946] Thu, 12 May 2011 07:07 Go to previous messageGo to next message
Hi Lukas,
are you sure buckminster actually creates new source bundles with every
run? Or does it just put "source jars" from previous builds into the
ZIP/p2 repository?
To rule out quoting and other issues, set the property when calling the
action, inside your script:
perform -D cbi.include.source=false ...#site.p2.zip
and see if this changes anything.
Regard,
Daniel
> s "
Re: Deliver no source files in p2 site [message #670254 is a reply to message #669996] Fri, 13 May 2011 04:55 Go to previous message
Hi Daniel,
Yes, I am sure that buckminster creates new source bundles with every new build. Before every new build I delete manually my old builds in order to exclude exactly this case.
I also tried this alternative:
However, without success.
Over again: I have this problem only building via Jenkins (Buckminster is installed automatically via Jenkins). Building manually via Buckminster from my Eclipse Environment works as expected - The sources are not included.
One remark: Roughly in a week I will migrate my Jenkins configuration from my local Windows System to a Mac OS System. Maybe this will solve the problem.
However, it is still a strange behaviour.
Lukas
[Updated on: Fri, 13 May 2011 04:58] by Moderator
Previous Topic:syntax for CVS tag in rmap?
Next Topic:SettingIgnoring Worspace's API Base Line
Current Time: Sat Jul 26 20:57:29 EDT 2025
Powered by FUDForum. Page generated in 0.06196 seconds
