Home » Eclipse Projects » Rich Client Platform (RCP) » Command Handler + KeyBinding = Freezing
Command Handler + KeyBinding = Freezing [message #668035] Tue, 03 May 2011 09:42 Go to next message
Hi, I am trying to catch a key combination and execute some code. In plugin.xml I define the command, the binding and the handler:
<?eclipse version="3.4"?>
<plugin>
   <extension
         point="org.eclipse.ui.commands">
      <command
            id="it.polito.softeng.momaapp.customgmfcode.InsertPortion"
            name="InsertPortion">
      </command>
   </extension>
   <extension
         point="org.eclipse.ui.bindings">
      <key
            commandId="it.polito.softeng.momaapp.customgmfcode.InsertPortion"
            schemeId="org.eclipse.ui.defaultAcceleratorConfiguration"
            sequence="M1+I">
      </key>
   </extension>
   <extension
         point="org.eclipse.ui.handlers">
      <handler
            class="MyHandler"
            commandId="it.polito.softeng.momaapp.customgmfcode.InsertPortion">
      </handler>
   </extension>
</plugin>
The binding appears under the Key Binding list in my RCP application but when I press ctrl+I the rcp application freezes (no error messages are shown in the console of the Eclipse IDE where I am developing the plugins). Any ideas?
Re: Command Handler + KeyBinding = Freezing [message #668054 is a reply to message #668035] Tue, 03 May 2011 10:26 Go to previous messageGo to next message
Is your handler being called? Place a breakpoint in your handler execute(*)
If it is truly frozen you can also follow steps from
http://wiki.eclipse.org/index.php/How_to_report_a_deadlock to find out
what your RCP/java is doing.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Command Handler + KeyBinding = Freezing [message #668055 is a reply to message #668054] Tue, 03 May 2011 10:40 Go to previous messageGo to next message
I tried using a JOptionPane.showMessage(...) and throwing an exception: it is not called.
Thank you for the link (http://wiki.eclipse.org/index.php/How_to_report_a_deadlock) I did not know it.
Re: Command Handler + KeyBinding = Freezing [message #668124 is a reply to message #668035] Tue, 03 May 2011 16:40 Go to previous messageGo to next message
This may sound a bit silly, but did you try changing the key sequence?
Ctrl+I is already defined in
org.eclipse.ui.defaultAcceleratorConfiguration for "Correct
Indentation", and unless you declare a custom scheme, I think that
setting is overriding yours.
Re: Command Handler + KeyBinding = Freezing [message #668237 is a reply to message #668055] Wed, 04 May 2011 11:33 Go to previous messageGo to next message
> it is not called.
JOptionPane is a Swing method, and has to run in the EDT. Your handler
would be run in the SWT UI thread (which is different), and if you just
call JOptionPane from the SWT UI Thread that guarantees bad behaviour.
1) actually debug your code or
2) put a sysout to print to the console.
PW
Paul Webster
Re: Command Handler + KeyBinding = Freezing [message #668310 is a reply to message #668124] Thu, 05 May 2011 03:17 Go to previous message
I don't think it overrides my binding because from the menu I can see that combination is associated with my command.
Maybe Swing doesn't work there but the exception is fired anyway... so I think I should get some reaction.
Previous Topic:CNF: Remove SOME popup options from the ones that are platform contributions
Next Topic:Implements my own search
Current Time: Fri Jul 25 17:30:53 EDT 2025
Powered by FUDForum. Page generated in 0.27577 seconds
