Home » Archived » M2M (model-to-model transformation) » [ATL] Problem with UML-Reference
| [ATL] Problem with UML-Reference [message #66818] |
Mon, 26 November 2007 14:33  |
Originally posted by: marfei.cs.tu-berlin.de
Hi all,
I've written a simple tool which transforms models programmatically using
ATL. When I run the tool with the Family2Persons example files, all works
fine und I get the desired result.
But when I try to transform my special model (EMF), I get some warnings
while loading the output model and when the transformation runs an exception
is thrown.
The output model is a simple ecore-model that represents UFA (UML for
aspects). It references the uml model in some parts e.g.:
OTuml.ecore:
<ecore:EPackage xmi:version="2.0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="otuml"
nsURI="http://objectteams.org/otuml" nsPrefix="otuml">
<eClassifiers xsi:type="ecore:EClass" name="Role"
eSuperTypes=" platform:/plugin/org.eclipse.uml2.uml/model/UML.ecore#//Clas s ">
<eStructuralFeatures xsi:type="ecore:EReference" name="baseClassifier"
eType="ecore:EClass
platform:/plugin/org.eclipse.uml2.uml/model/UML.ecore#//Clas sifier "/>
<eStructuralFeatures xsi:type="ecore:EReference" name="callinMethod"
upperBound="-1"
eType="#//CallinMethod" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="methodBinding"
upperBound="-1"
eType="#//MethodBinding" containment="true"/>
</eClassifiers>
When I try to load that model, I get a lot of warnings, e.g:
26.11.2007 19:08:44 org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel
addReferencedExtentsFor
WARNUNG: Resource for org.eclipse.emf.ecore.impl.EClassImpl@125d06e
(eProxyURI:
platform:/plugin/org.eclipse.uml2.uml/model/UML.ecore#//Oper ation) is null;
cannot be referenced
WARNUNG: Resource for org.eclipse.emf.ecore.impl.EClassImpl@d4d66b
(eProxyURI: platform:/plugin/org.eclipse.uml2.uml/model/UML.ecore#//Clas s)
is null; cannot be referenced
(eProxyURI:
The transformation stops with the exception, that some parts of the model
could not be found, e.g:
26.11.2007 19:08:44 org.eclipse.m2m.atl.engine.vm.SimpleDebugger error
SCHWERWIEGEND: ****** BEGIN Stack Trace
SCHWERWIEGEND: message: no type named 'Model' in metamodel 'OT'
26.11.2007 19:08:44 org.eclipse.m2m.atl.engine.vm.ExecEnv printStackTrace
SCHWERWIEGEND: A.main() : ??#22 null
SCHWERWIEGEND: local variables = {self=OTmapping : ASMModule}
I suppose, that error occures because of the missing uml reference. I
already referenced the "org.eclipse.uml2.uml_2.1.1.v200707311200"-JAR-file
in my project but it still doesn't work.
Have anyone an idea how to fix this problem?
Thanks in advance,
Marko
| Re: [ATL] Problem with UML-Reference [message #66823 is a reply to message #66818] |
Mon, 26 November 2007 15:08   |
There's a failure in my last post, instead of output model, I mean output
_meta_ model.
"Marko Feistkorn" <marfei@cs.tu-berlin.de> wrote in message
news:fif733$r1a$1@build.eclipse.org...
> Hi all,
> exception is thrown.
> OTuml.ecore:
> xmlns:xmi="http://www.omg.org/XMI"
> eType="ecore:EClass
> upperBound="-1"
> upperBound="-1"
> </eClassifiers>
> (eProxyURI:
> (eProxyURI:
> Thanks in advance,
> Marko
| Re: [ATL] Problem with UML-Reference [message #66843 is a reply to message #66840] |
Wed, 28 November 2007 11:39   |
Hi Quentin,
when I launch my transformation via the Eclipse "Run as"-Dialog everything
works fine. I think the problem is, that the referenced UML parts are not
found while loading my output meta model ( see attachment).
I used the following code to load my output meta model:
AtlEMFModelHandler objEMFHandler =
(AtlEMFModelHandler)AtlEMFModelHandler.getDefault(AtlModelHa ndler.AMH_EMF);
ASMModel objOutputMetaModel =
objEMFHandler.loadModel(strOutputMetaModelName, objEMFHandler.getMof(),
urlOutputMetaModel.openStream());
When I load the output meta model
(objEMFHandler.loadModel(strOutputMetaModelName....), I got the descriped
Warnings:
28.11.2007 17:22:48 org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel
(eProxyURI:
(eProxyURI:
WARNUNG: Resource for org.eclipse.emf.ecore.impl.EClassImpl@1f03691
(eProxyURI:
Because of the missing references, I suppose the following exception is
thrown:
28.11.2007 17:22:48 org.eclipse.m2m.atl.engine.vm.SimpleDebugger error
28.11.2007 17:22:48 org.eclipse.m2m.atl.engine.vm.ExecEnv printStackTrace
SCHWERWIEGEND: local stack = []
SCHWERWIEGEND: A.__matcher__() : ??#1 null
SCHWERWIEGEND: A.__matchUFMModel2OTModel() : ??#34 244:14-244:22
SCHWERWIEGEND: local variables = {self=OTmapping : ASMModule,
s=IN!Featuremodell}
SCHWERWIEGEND: local stack = [TransientLinkSet {}, TransientLink {rule =
'UFMModel2OTModel', sourceElements = {s = IN!Featuremodell}, targetElements
= {}, variables = {}}, TransientLink {rule = 'UFMModel2OTModel',
sourceElements = {s = IN!Featuremodell}, targetElements = {}, variables =
{}}, 't']
SCHWERWIEGEND: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to allow
continuation after errors).
28.11.2007 17:22:48 org.eclipse.m2m.atl.engine.AtlLauncher launch
SCHWERWIEGEND: no type named 'Model' in metamodel 'OT'
java.lang.RuntimeException: no type named 'Model' in metamodel 'OT'
at
org.eclipse.m2m.atl.engine.vm.SimpleDebugger.error(SimpleDeb ugger.java:185)
at
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:85)
at
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:81)
at
org.eclipse.m2m.atl.engine.vm.nativelib.ASMModel.newModelEle ment(ASMModel.java:73)
at
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:209)
at
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:325)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:161)
at
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:133)
at
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:91)
at
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:230)
at
at
at
at
org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:289)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:161)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:105)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:81)
at de.diploma.atl.transform.ATLTransform.transform(ATLTransform .java:237)
at de.diploma.atl.transform.ATLTransform.transform(ATLTransform .java:267)
at de.diploma.atl.transform.test.Main.main(Main.java:65)
Thanks in advance,
Marko
"Quentin Glineur" <quentin.glineur@obeo.fr> wrote in message
news:fik383$t8o$1@build.eclipse.org...
> Hi Marco,
> Do your transformation works when you launch it in the regular way (ANT
> or launch config) ?
> Quentin GLINEUR
> Marko Feistkorn a
Attachment: OTuml.ecore
(Size: 3.55KB, Downloaded 241 times)
| Re: [ATL] Problem with UML-Reference [message #67668 is a reply to message #66843] |
Thu, 29 November 2007 11:16   |
Hi all,
I found a solution for my problem. A fellow student told my, that I have to
put the uml.ecore into the same folder like the referencing model. I tried
and to my surprise it works. As it is only a workaround I would really
appreciate, if somebody had a straight forward solution.
Marko
news:fik5m1$ned$1@build.eclipse.org...
> Hi Quentin,
> everything works fine. I think the problem is, that the referenced UML
> parts are not found while loading my output meta model ( see attachment).
> Warnings:
> (eProxyURI:
> (eProxyURI:
> (eProxyURI:
> thrown:
> s=IN!Featuremodell}
> targetElements = {}, variables = {}}, TransientLink {rule =
> targetElements = {}, variables = {}}, 't']
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks in advance,
> Marko
>> Hi Marco,
>> or launch config) ?
>> Quentin GLINEUR
>> Marko Feistkorn a
| Re: [ATL] Problem with UML-Reference [message #67752 is a reply to message #67668] |
Thu, 29 November 2007 18:49  |
EMF can find related XMI files using relative URIs, provided it knows
the URI of the loaded model.
However, you load your target metamodel using an InputStream, not a URI.
Therefore, if you do not additionally do a setUri on the resource, EMF
may not be able to find related files.
Frédéric Jouault
Marko Feistkorn wrote:
> Hi all,
> Cheers,
> Marko
>> Hi Quentin,
>> Warnings:
>> (eProxyURI:
>> (eProxyURI:
>> (eProxyURI:
>> thrown:
>> s=IN!Featuremodell}
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Thanks in advance,
>> Marko
>>> Hi Marco,
>>> or launch config) ?
>>> Quentin GLINEUR
>>>> output
>>>> _meta_ model.
>>>>> Hi all,
>>>>> using
>>>>> works
>>>>> OTuml.ecore:
>>>>> eType="ecore:EClass
>>>>> upperBound="-1"
>>>>> upperBound="-1"
>>>>> </eClassifiers>
>>>>> (eProxyURI:
>>>>> (eProxyURI:
>>>>> (eProxyURI:
>>>>> model
>>>>> printStackTrace
>>>>> printStackTrace
>>>>> Thanks in advance,
>>>>> Marko
Current Time: Tue Nov 04 15:02:43 EST 2025
Powered by FUDForum. Page generated in 0.03308 seconds
